Universalbox Universalbox Official support area |
03-10-2007, 12:35 | #1 (permalink) |
Junior Member Join Date: Feb 2007 Location: Searching..GPS lost connection
Member: 447531 Status: Offline Thanks Meter: 0 | K610 bluetooth cannot turn on. |
03-12-2007, 15:55 | #6 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Philippines http://www.pogi.ph
Member: 68075 Status: Offline Thanks Meter: 51 | Hello! Ma8! You try Full Flash use USB cable. 1. Full Charge Battery. 2. Click Flash. 3. You see Please turn on the phone while pressing the C key! 4. Put Battery 5. Push hold "C" Then Connect USB Cable. 6. If not run. You try Push Hold "2" + "5". B.R. EIGY. |
03-13-2007, 08:50 | #7 (permalink) |
Member: 447531 Status: Offline Thanks Meter: 0 | Thanks for ur support anyway. if u don mind, can u tell me how to full flash? as far as i know and tried is only generic and software flash, is it incl custom as your attachment highlighted with red circle, and skip imei patch? Thousand thanks EIGY, u r bravo ! |
03-13-2007, 14:33 | #8 (permalink) |
Member: 447531 Status: Offline Thanks Meter: 0 | brother, i did try to flash using DCU-60 cable as ur attachement but the fon does'nt respond, when i use the ori UB cable it can run but after software binary been flash then pop up say " UA file not found " , still continuing to flash the generic and custom till end for 3 credit, answer still the same can't on bluetooth. How ah? Blur blur n lost credit. |
03-13-2007, 16:47 | #10 (permalink) | |
Member: 447531 Status: Offline Thanks Meter: 0 | Quote:
so, did u managed to change the ic? if yes pls share ur xperience which hardware need to b change. plz.......! Oh ! hope EIGY can help for this also......! | |
03-13-2007, 22:22 | #11 (permalink) | |
Member: 68075 Status: Offline Thanks Meter: 51 | Quote:
You need USB Flash driver. C:\Uni\Files\Ericsson\Drivers\Gordons Gate B.R. EIGY. | |
03-14-2007, 05:10 | #12 (permalink) |
Member: 447531 Status: Offline Thanks Meter: 0 | unluckily all driver also install, DCU-60 not working but UB cable running. yet still the same answer, after software "UA file not found for this phone", then cont Generic and credit- . |
03-14-2007, 17:18 | #13 (permalink) | ||
1. Log on internet. 2. You try other Flash file. B.R. EIGY. | ||
2100 Can Flash But Cannot turn on | NuengEve | Nokia Hardware & Hardware Repair | 1 | 08-22-2005 12:09 |
T610 Can Flash but Cannot turn on | NuengEve | Sony Ericsson | 2 | 08-22-2005 11:04 |
6100 Flash Ok but cannot turn on | NuengEve | Nokia Hardware & Hardware Repair | 7 | 08-17-2005 07:42 |
E365 Can Flash But Cannot turn on | NuengEve | Motorola ODM | 3 | 06-27-2005 01:49 |
8250 can flash but cannot turn on | webberlink | Nokia Hardware & Hardware Repair | 7 | 10-11-2003 19:12 |
