Universalbox Universalbox Official support area |
05-28-2008, 09:54 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Blackside Age: 45
Member: 58536 Status: Offline Thanks Meter: 65 | 6300 CS after rpl service... after rpl service the phone is CS i make: -full erase -flash -rpl service (again) -write pm -pm auth but the problem (CS) is same... other solution?? thnx! b. |
05-29-2008, 01:09 | #4 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
First do PM Authentification + write PM then Never the reverse If you don't do Auth prior to write PM , it will not write important values that are on protected fields Write the attached PM 100% ok, if still in Contact Service, run self tests and post results here. BR Max_B | |
6300 restarting after rpl.... | himanshu taldar | A1-Services.org | 4 | 11-06-2008 08:03 |
nokia 6300 contact service after rpls | 4 u man | Nokia Base Band 5 ( BB-5 ) | 0 | 10-11-2007 10:51 |
