Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 03-16-2009, 16:37   #1 (permalink)
Member: 112674
Thanks Meter: 5
6500 Classic - Tryed to unlock and now Contact Service - Please Help...
Tried to unlock 6500 Classic and Not Unlocked and now Contact service.
Have done a PM Auth and written the backed up PM but still not working.
Please help.
TBB5PatchUnlockThread 2.7.4.2048 started at: 2009/03/16 15:09:56
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.42, and up to date.
MCU BB5SL2 Version: 1.022, and up to date.
SMCU BB5SL2 Version: 1.12, and up to date.
Initializing phone...
Output power at Line1 3.93V is in range of: 4.00V ±10.0%
Phone powered.
Reading Info...
Soft Version: V 03.21 Date: 31-08-07 Type: RM-265 (6500C CLASSIC) Pack: (c) Nokia
Product code: 0555828
Original IMEI: 358667-01-********
Production serial: MUJ687279
HW Version: 1003
DSP Version: 07w15pb_07w33
LCD Version: SEIKO
APE ADSP Version:
SIMLock service: SIMLOCK SERVER [01000407031E]
Profile bits: 8000000000000000
Simlock config: 2343300000000000
Invalid codes entered: 3 / 0
Block: 1; Lock: 1; State: Closed; Data: 23433F
Block: 2; Lock: 1; State: Closed; Data: 23486F
Reading PM...
Input power: 4.68V OK.
Asic ID: 000000010000022600010006010C192101003000
EM Asic ID: 00000295
EM Asic ID: 00000B22
Public ID: 08900015FDFA01545666E056365D1562EE874D1D
Asic Mode ID: 00
Hash: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: PatchUnlock 0 kB
Speed: [3000k, 3250k, 3250k, 98k] Baud.
Supported Hardwares: [010C192101003000]
Boot Loader: RAP3Gv3_2nd.fg 15 kB
Version: 1.30.0
Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
Asic Mode ID: 00
Total time: 8,2 sec.
Phone powered.
Reading Info...
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
Writing PM...
Reading Info...
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
Simlock info invalid
Phone powered.
Reading Info...
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
Trying to authenticate PM...
Connecting to server: BB5 PM Auth
Elapsed time: 2,9 sec.
Old 03-16-2009, 17:50   #2 (permalink)
Member: 211725
Thanks Meter: 9
try unlocking again, should fix the contact service problem.
The Following User Says Thank You to gsmteknikk For This Useful Post:
Old 03-16-2009, 18:01   #3 (permalink)
rana_'s Avatar
Member: 597570
Sonork: 100.1590733
Thanks Meter: 159
flash phone with update virsion than unlock phone post rejult
The Following User Says Thank You to rana_ For This Useful Post:
Old 03-16-2009, 18:26   #4 (permalink)
honyjee's Avatar
Member: 506989
Sonork: 100.1585406
Thanks Meter: 81
today i solved same fault by using( simlock repair ) 100% tested
The Following User Says Thank You to honyjee For This Useful Post:
Old 03-16-2009, 18:29   #5 (permalink)
Member: 112674
Thanks Meter: 5
Just downloading latest flash files and will try again. Simlock Repair, Then Flash, Then Try and unlock.
I Will let you lot of great people know how I get on.
Many thanks for your help.
Old 03-16-2009, 21:38   #6 (permalink)
Member: 87357
Thanks Meter: 9,457
Please look it here
http://forum.gsmhosting.com/vbb/showthread.php?t=699867
Old 03-16-2009, 21:38   #7 (permalink)
Member: 87357
Thanks Meter: 9,457
Please look it here
Old 03-16-2009, 21:40   #8 (permalink)
Member: 581508
Thanks Meter: 5
using simrepair lock and unlock again work 100%
Old 03-17-2009, 09:48   #9 (permalink)
Member: 112674
Thanks Meter: 5
Have done above, and phone Unlocked and accepting all sims, but now appears to have corrupted the IMEI so unable to make a call.
Tried to Send ASK and it fails on Non Valid IMEI.
Please help:
Done.
TBB5PMAuthThread 2.7.4.2048 started at: 2009/03/17 08:31:02
Reading Info...
Original IMEI: 123456-10-********
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
Simlock config: 0010100000000000
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Open; Data: 00101F
All locks are open.
Elapsed time: 2,2 sec.
TBB5PMAuthThread 2.7.4.2048 finished at: 2009/03/17 08:31:13
Done.
TBB5SimlockRepairThread 2.7.4.2048 started at: 2009/03/17 08:34:26
Reading Info...
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
Input power: 4.72V OK.
Asic Mode ID: 00
Power off mode set.
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: RPL 0 kB
Input power: 4.70V OK.
Version: 1.30.0
Max Flash Devices: 2
Flash ID 1: 00EC220C - 0000 Rev: 8921 Manufacturer: Samsung MSB: 00 SectorSize: 0x020000
Flash ID 2: FFFF0000 - 0000 Rev: 0000 Manufacturer: Unknown MSB: 00 SectorSize: 0x010000
Signature: 00000000000000000000000000000000
Flash Loader: RAP3Gv3_algo.fg 166 kB
Version: 1.31.0
Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
Using RX2 flash.
Asic Mode ID: 00
SecHash: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88
Writing flash...
After MCU Flash Delay: 5000 msec.
Total time: 23,6 sec.
Switching from Local to Normal mode...
Normal mode set.
Power off mode set.
Flashing file:
Version: 1.30.0
Version: 1.31.0
Using RX2 flash.
Asic Mode ID: 00
Writing flash...
Total time: 23,2 sec.
TBB5PatchUnlockThread 2.7.4.2048 started at: 2009/03/17 08:35:53
MCU BB5NoTP Version: 1.042, and up to date.
SMCU BB5NoTP Version: 1.16, and up to date.
Reading Info...
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
Reading PM...
Asic Mode ID: 00
Flashing file:
Version: 1.30.0
Asic Mode ID: 00
Total time: 8,5 sec.
PM Section not changed
TBB5PatchUnlockThread 2.7.4.2048 finished at: 2009/03/17 08:36:32
TBB5SimlockRepairThread 2.7.4.2048 finished at: 2009/03/17 08:36:32
Done.
TNokiaWritePMThread 2.7.4.2048 started at: 2009/03/17 08:36:51
Phone powered.
Writing PM values...
TNokiaWritePMThread 2.7.4.2048 finished at: 2009/03/17 08:38:47
Done.
TBB5ReadInfoThread 2.7.4.2048 started at: 2009/03/17 08:38:51
Reading Info...
HW Version: 1003
LCD Version: SEIKO
APE ADSP Version:
TBB5ReadInfoThread 2.7.4.2048 finished at: 2009/03/17 08:38:54
Done.
TBB5GetRPLThread 2.7.4.2048 started at: 2009/03/17 08:39:04
Asic Mode ID: 00
Connecting to server: US2
TBB5GetRPLThread 2.7.4.2048 finished at: 2009/03/17 08:39:14
Terminated with error: Response from server: Your BB5 ASK is not in queue. Please send BB5 ASK first. [00000880].00029110
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->Universal Box [UBD2M2IZ]
TBB5SendASKThread 2.7.4.2048 started at: 2009/03/17 08:39:29
Input power: 4.66V OK.
Asic Mode ID: 00
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: ReadKeys 0 kB
Version: 1.30.0
Version: 1.31.0
Asic Mode ID: 00
Total time: 49,0 sec.
TBB5SendASKThread 2.7.4.2048 finished at: 2009/03/17 08:40:21
Terminated with error: No valid IMEI in the phone [00010111]
Old 03-17-2009, 10:04   #10 (permalink)
tersace's Avatar
Member: 44483
Thanks Meter: 4
Simlock repair is for SL phones ONLY (6300, 7373 etc), there is a sticky about contact service repair, mobile doctor has posted the link
WBR
Old 03-17-2009, 10:24   #11 (permalink)
Member: 12864
Thanks Meter: 17
i think you have flashed it with a wrong file.
Reflashed with the right file and the imei will be OK.
Old 03-17-2009, 11:35   #12 (permalink)
Member: 112674
Thanks Meter: 5
Just reflashed with V8.3 and still the same.
How do I change IMEI back to original?
Old 03-17-2009, 12:06   #13 (permalink)
Member: 112674
Thanks Meter: 5
Have just unlocked 2 other 6500 Classics with no problem.
Just this one I am having problem with corrupt IMEI. Please help.
Old 03-17-2009, 15:37   #14 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
solution for 6500s
hi bro u most check this
i holp it can help u
http://forum.gsmhosting.com/vbb/show...=683608&page=2
Old 03-18-2009, 00:26   #15 (permalink)
moni108's Avatar
Member: 26440
Thanks Meter: 6
if u have the original .rpl file this can be fixed, done 1 today. lmk
Nokia 3300 after flash shows insert sim card and then contact service please help prakashmanwar Nokia Digital Core Technology 4 ( DCT-4 ) 5 11-10-2009 17:11
Nokia 3300 after flash shows insert sim card and then contact service please help prakashmanwar Nokia Digital Core Technology 4 ( DCT-4 ) 2 03-08-2009 14:57
hi help trying to unlock wiza200 could some one please help smart phones HTC & PDA WM( With Touchscreen) 1 02-15-2007 22:27
[HELP] 6310i no signal and now CONTACT SERVICE André_F Nokia Hardware & Hardware Repair 3 09-05-2006 20:03
Page generated in 0.32336 seconds with 10 queries
