7210s restart when caling i rapeir 7210s with ub set was contect service mode after rapeir set is ok bu when i make a call during call set is restart up team pls tell me what is problm sory my bad english |
7210c solution take 120feild pm of same provider and write and post reply |
..::Brother full flash higher version and not solved so to write PM without 308 chk and post::.. Br RIZWANJAT |
make backup with jaf give balnk rpl give good pm than restore bakup ur mobile 100% okay pm here http://www.2shared.com/file/9352221/1cb8c9db blank rpl here http://www.2shared.com/file/9276551/68485e0b |
restart i flashed latest version 7.23 i make backup with jaf write blanck rpl write good pm write backup same problm during call set restrt pls tell me what is problm |
no brother just change earpiece 10000000% tested solution DONT FORGET TO SAY THANKS |
h.f but same problm with hands free |
Does it only Restart when you Receiving/Outgoing Call? without Calling Does it work or not? |
out call only when i macke a call otherwise set is 100% ok |
2 after macking a call with in 2 mint set restart |
u need buy Original rpl from nokia server to fix super dongle key.. Please read trough this F.A.Q Q: Can i repair PM Auth "Step1 problem"? (SuperDongle Key missing) A: No you can't. wbr yousef |
..::Brother first erase and flash higher version and do write PM without 308 and do unlock not solved so to try it NOKIA HARDWARE section Ok::.. Br RIZWANJAT |
h.w ok i check the hardware but hardware is 100% ok |
..::Brother hardware ok so to try erase erase file(BB5 ERASE FILE DOWNLOAD)and then flash higher version and do unlock and write PM without 308 I hope problem solved::.. Br RIZWANJAT |
