Universalbox Universalbox Official support area |
10-15-2008, 20:22 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 585791 Status: Offline Thanks Meter: 2 | help unlock 1208b rh-106 ver4.11 My problem is as follows: unlock several nokia 1208b rh-106 4.11, and constantly restart when send messages. update the phone to version 5.06, but still doing the same thing plz help me! I'm using universalbox gracias from argentina- PEHUAJO |
10-15-2008, 21:52 | #2 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: ...Argentina
Member: 225513 Status: Offline Thanks Meter: 23 | Quote:
10-15-2008, 22:39 | #3 (permalink) |
Insane Poster Join Date: Jun 2008 Location: Argentina
Member: 800178 Status: Offline Thanks Meter: 1 | Just as the friend says: flash it MCU PPM only, and find the SAME product code or mark "set product code" "set default" and "unlock".... Better with the mochila cable my friend. regards from Patagonia. |
10-16-2008, 12:08 | #4 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Philippines http://www.pogi.ph
Member: 68075 Status: Offline Thanks Meter: 51 | Quote:
Hello Ma8! You try Unlock. C:\Uni\Files\Nokia\DCT-4\Patch\RH-106_5.06.imp 1. buck-up PM(FULL). 2. Flash v5.06. 3. Read info. 4. Unlock. 5. Post here Full log. B.R. EIGY. | |
10-17-2008, 14:57 | #5 (permalink) | |
Member: 585791 Status: Offline Thanks Meter: 2 | try, all of the above for you, I'm still the same flash procuct code 0552830 (argentina) 1208B (RH-106) VER.5.06, as usual, I'm using cable rj-45. I think that the problem is in the test selft they step into the part that says FAIL BECAUSE IF YOU CHECK WITH OTHER THAN EVER WAS PASSED UNBLOCK DA, ESOS ITEM WHERE CAN I DOWNLOAD OF A GENERIC PM that works.? THANKS Nokia MCU Version: 1124, and up to date. SMCU Nokia Version: 1.42, and up to date. Initializing phone ... Output power at Line1 3.93 V is in range of: 4.00 V ± 10.0% Phone powered. Executing self tests ... Passed [0F] ST_UEM_CBUS_IF_TEST Passed [03] ST_SLEEP_X_LOOP_TEST Passed [0C] ST_EAR_DATA_LOOP_TEST Passed [0D] ST_SIM_CLK_LOOP_TEST Passed [27] ST_SIM_IO_CTRL_LOOP_TEST Passed [21] ST_WARRANTY_TEST Passed [0A] ST_SIM_LOCK_TEST Passed [2B] ST_PPM_VALIDITY_TEST Passed [29] ST_LCD_TEST Fail [1E] ST_FLASH_CHECKSUM_TEST Fail [34] ST_RF_CHIP_ID_TEST Passed [00] ST_KASUMI_TEST --------- EN CASTELLANO intente, todo de lo expuesto por uds, siguen igual lo estoy flasheando con procuct code 0552830 (argentina) 1208B(RH-106) VER.5.06, sigue igual, estoy usando cable rj-45. yo creo que el problema esta en el selft test que les paso en la parte que dice FAIL, PORQUE SI LO CHEQUEO CON OTRO QUE NUNCA FUE DESBLOQUEADO DA PASSED, ESOS ITEM DE DONDE PUEDO BAJAR UN PM GENERICO QUE FUNCIONE.? GRACIAS MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Initializing phone... Output power at Line1 3,93V is in range of: 4,00V ±10,0% Phone powered. Executing self tests... Passed [0F] ST_UEM_CBUS_IF_TEST Passed [03] ST_SLEEP_X_LOOP_TEST Passed [0C] ST_EAR_DATA_LOOP_TEST Passed [0D] ST_SIM_CLK_LOOP_TEST Passed [27] ST_SIM_IO_CTRL_LOOP_TEST Passed [21] ST_WARRANTY_TEST Passed [0A] ST_SIM_LOCK_TEST Passed [2B] ST_PPM_VALIDITY_TEST Passed [29] ST_LCD_TEST Fail [1E] ST_FLASH_CHECKSUM_TEST Fail [34] ST_RF_CHIP_ID_TEST Passed [00] ST_KASUMI_TEST -------------- Quote:
Convert 1208b RH-106 to 1208 RH-105 Success!!! | jerick_m | Nokia Digital Core Technology 4 ( DCT-4 ) | 14 | 03-12-2011 15:08 |
Please help with unlocking 1208b RH-106 | katalyst | Cyclonebox | 17 | 09-20-2009 19:17 |
Help need 1208b RH-106 PM file | Panthereitor | J.A.F. By Jafsupport.com | 3 | 11-19-2008 01:16 |
