Universalbox Universalbox Official support area |
11-17-2011, 08:41 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 42
Member: 166885 Status: Offline Thanks Meter: 17 | x3 02 and c5 both dead 6.05 now phone on white blink again i tried to flash RM639_0598209_06.00_011 with same product code still same condition MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007600C192102031104 BB Asic Index is: 00 EM Asic ID is: 00001051 BB Asic Index is: 00 EM Asic ID is: 00001060 BB Asic Index is: 00 Public ID is: 025001189BDA03441666F5194427BB2FB3FC4A15 BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 916F75217F32081248B15C38DFC8E81B BB Asic Index is: 00 ROM ID: E693EF0DAC22615B BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 00EC Device ID: 0030 Extended device ID: 0000 Revision ID: 0431 Loading update server code: 867056 bytes Update server loaded Asic CMT: Start programming 72356 KB... Programming complete Asic CMT: Verifying communication to device... Waiting for phone to reconnect Aborting process... Warning: User called Unsafe Abort! Aborting flashing Warning: Unsafe Abort detected! Aborting flashing now!! Error 0x8401F121 communicating to phone. Unable to verify comm. Warning: Unable to communicate to product after flashing -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.6.2878 finished at: 2011/11/16 23:24:32 c5 same problem for lock code customer had bought now just vibrate MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007600C192102031104 BB Asic Index is: 00 EM Asic ID is: 00000C35 BB Asic Index is: 00 EM Asic ID is: 00000C30 BB Asic Index is: 00 Public ID is: 1C100211E3D00344BD0A34A4AFB4B57B86BE7F17 BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 916F75217F32081248B15C38DFC8E81B BB Asic Index is: 00 ROM ID: E693EF0DAC22615B BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0020 Device ID: 0040 Extended device ID: 0000 Revision ID: 0031 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 0020 Device ID: 0040 Extended device ID: 0000 Revision ID: 0031 Loading update server code: 867056 bytes Update server loaded Asic CMT: Start programming 130678 KB... Programming complete Asic CMT: Verifying communication to device... Waiting for phone to reconnect Error 0x8401F121 communicating to phone. Unable to verify comm. Warning: Unable to communicate to product after flashing -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.6.2878 finished at: 2011/11/16 23:37:03 Terminated with error: Firmware: Firmware updating failed. Error 0x8401F153 - Flash: Unable to communicate with the device after flashing. Check USB connections! [00010123] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBEDFYQM] please don't tell me it is hardware problem both the phones are brand new phones please give me the solution for this thank you |
11-17-2011, 11:23 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mor
Member: 1006514 Status: Offline Thanks Meter: 641 | UB can't flash X3-02 i confirm this ...and phone revived by other tool Quote:
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
