Universalbox Universalbox Official support area |
01-15-2010, 05:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2002 Location: davao, philippines Age: 43
Member: 9398 Status: Offline Thanks Meter: 1 | help with my 5300 cs security test fail when i do self test when i checked sd data NO SUPERDONGLE DATA EXISTS How will i repair this and how much credit will be consumed?? thanks in advance br g!zmo |
01-15-2010, 05:31 | #3 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
try write auth and then pm w/o 308 then format. check sd first to avoid waste of log | |
01-15-2010, 07:08 | #6 (permalink) |
Member: 9398 Status: Offline Thanks Meter: 1 | here are the logs.. sorry had lunch thanks for all the replies TBB5SelfTestThread 2.8.4.2510 started at: 2010/01/15 11:51:54 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Phone powered. Reading Info... Soft Version: V 07.20 Date: 23-10-08 Type: RM-146 (5300) Pack: (c) Nokia. Product code: 0540652 Product code: 0530535 Radio: GSM850 / GSM900 / GSM1800 / GSM1900 Original IMEI: 353095-02-******** Production serial: PNA276924 HW Version: 1004 DSP Version: ICPR61_08w10 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 2440700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Open; Data: FFFFFF Block: 2; Lock: 1; State: Open; Data: FFFFFF Block: 3; Lock: 1; State: Open; Data: FFFFFF Block: 4; Lock: 1; State: Open; Data: FFFFFF Block: 5; Lock: 1; State: Open; Data: FFFFFF Block: 6; Lock: 1; State: Open; Data: FFFFFF Block: 7; Lock: 1; State: Open; Data: FFFFFF All locks are open. Security code: 12345 Executing self tests... Passed [0C] ST_EAR_DATA_LOOP_TEST Passed [0D] ST_SIM_CLK_LOOP_TEST Passed [0F] ST_SIM_IO_CTRL_LOOP_TEST Passed [2E] ST_SLEEP_X_LOOP_TEST Passed [07] ST_UEM_CBUS_IF_TEST Passed [16] ST_KEYBOARD_STUCK_TEST Passed [14] ST_CAMERA_IF_TEST Passed [15] ST_BACKUP_BATT_TEST Passed [2C] ST_LPRF_IF_TEST Passed [02] ST_LPRF_AUDIO_LINES_TEST Passed [2A] ST_CURRENT_CONS_TEST Passed [45] ST_RADIO_TEST Passed [21] ST_BACKLIGHT_TEST Passed [5D] ST_SIM_LOCK_TEST Fail [47] ST_SECURITY_TEST Passed [63] ST_BT_WAKEUP_TEST Passed [60] ST_IRDA_LED_STRESS_TEST Passed [58] ST_HOOKINT_TEST Passed [38] ST_TAHVOINT_TEST Passed [65] ST_SLEEPCLK_FREQ_TEST Passed [6B] ST_BTEMP_TEST Passed [0E] ST_BT_SLEEP_CLK_TEST Passed [6C] ST_MICB1_TEST Passed [56] ST_EXT_DEVICE_TEST Not executed [53] ST_CDSP_RF_BB_IF_TEST Not executed [55] ST_CDSP_RF_SUPPLY_TEST Not executed [4A] ST_CDSP_TX_IQ_TEST Not executed [4F] ST_CDSP_TXC_DATA_TEST Not executed [50] ST_CDSP_RX_PLL_PHASE_LOCK_TEST Not executed [51] ST_CDSP_TX_PLL_PHASE_LOCK_TEST Not executed [4D] ST_CDSP_RX_IQ_LOOP_BACK_TEST Not executed [00] ST_CDSP_GSM_TX_POWER_TEST -------------------------------------------------------------------------------- TBB5SelfTestThread 2.8.4.2510 finished at: 2010/01/15 11:52:48 Done. TBB5CheckSDThread 2.8.4.2510 started at: 2010/01/15 12:01:49 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Phone powered. Reading Info... Soft Version: V 07.20 Date: 23-10-08 Type: RM-146 (5300) Pack: (c) Nokia. Product code: 0540652 Product code: 0530535 Radio: GSM850 / GSM900 / GSM1800 / GSM1900 Original IMEI: 353095-02-******** Production serial: PNA276924 HW Version: 1004 DSP Version: ICPR61_08w10 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 2440700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Open; Data: FFFFFF Block: 2; Lock: 1; State: Open; Data: FFFFFF Block: 3; Lock: 1; State: Open; Data: FFFFFF Block: 4; Lock: 1; State: Open; Data: FFFFFF Block: 5; Lock: 1; State: Open; Data: FFFFFF Block: 6; Lock: 1; State: Open; Data: FFFFFF Block: 7; Lock: 1; State: Open; Data: FFFFFF All locks are open. Security code: 12345 Reading PM... No Superdongle data exists, you need to generate Superdongle data -------------------------------------------------------------------------------- TBB5CheckSDThread 2.8.4.2510 finished at: 2010/01/15 12:02:56 Done. |
Please help with my unlock with my 3G | kenny8881 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-03-2009 15:20 |
need help with a 5300 repair | marcus0000 | Nokia Hardware & Hardware Repair | 3 | 09-28-2007 19:08 |
some help with a 5300 | service_sad | MT-BOX | 1 | 09-03-2007 13:08 |
