Universalbox Universalbox Official support area |
08-11-2008, 13:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | Callibrating Box i receive my Ub Tp Adptor until now i dont have made no phone its apears the same error that indicate no ground or bad TP, i have been tested on 5200 5300 6300 N80 E50 E65 6233 6151 and samething. please can u help |
08-11-2008, 13:33 | #3 (permalink) |
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3,97V is in range of: 4,00V ±10,0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05.51 Date: 05-09-07 Type: RM-174 (5200) Additional_1: (c) Nokia. PPM Version: V 05.51 Date: 05-09-07 Type: RM-174 (5200) Pack: (c) Nokia. Product code: 0545710 Original IMEI: ****************** Production serial: DKG926156 HW Version: 2003 DSP Version: 06w14pb_07w32 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 8000000000000000 Simlock config: 2680300000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 26803F Saving PM field... Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05.51 Date: 05-09-07 Type: RM-174 (5200) Additional_1: (c) Nokia. PPM Version: V 05.51 Date: 05-09-07 Type: RM-174 (5200) Pack: (c) Nokia. Product code: 0545710 Original IMEI: ****************** Production serial: DKG926156 HW Version: 2003 DSP Version: 06w14pb_07w32 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 8000000000000000 Simlock config: 2680300000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 26803F Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05.51 Date: 05-09-07 Type: RM-174 (5200) Additional_1: (c) Nokia. PPM Version: V 05.51 Date: 05-09-07 Type: RM-174 (5200) Pack: (c) Nokia. Product code: 0545710 Original IMEI: ****************** Production serial: DKG926156 HW Version: 2003 DSP Version: 06w14pb_07w32 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 8000000000000000 Simlock config: 2680300000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 26803F Connect TP cables! |
08-11-2008, 13:44 | #4 (permalink) |
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3,97V is in range of: 4,00V ±10,0% Auto power-on mode set. Reading Info... MCU Version: V 05wk33v42 Date: 07-05-07 Type: RM-92 (N80) Additional_1: (c) Nokia. PPM Version: V 05wk33v42 Date: 07-05-07 Type: RM-92 (N80) Pack: (c) Nokia. Product code: 0553963 Original IMEI: ****************** Production serial: SEK787534 HW Version: 6007 DSP Version: miro_05wk32v42p1 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 2680100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 26801F Block: 2; Lock: 1; State: Closed; Data: 26801F Backup already saved Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk33v42 Date: 07-05-07 Type: RM-92 (N80) Additional_1: (c) Nokia. PPM Version: V 05wk33v42 Date: 07-05-07 Type: RM-92 (N80) Pack: (c) Nokia. Product code: 0553963 Original IMEI: ****************** Production serial: SEK787534 HW Version: 6007 DSP Version: miro_05wk32v42p1 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 2680100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 26801F Block: 2; Lock: 1; State: Closed; Data: 26801F Connect TP cables! |
08-11-2008, 13:46 | #5 (permalink) |
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | if i have been testing in e65 e 50 or N80 bad tp is possible but in 5200 5300 6300 its so easy and clear tp to make. i think my tp adptor is broken no phones no fun. |
how to bypass pen callibration ? | shahzad_lal | Chinese Models & Cloned Phones | 7 | 05-15-2008 18:36 |
N95i Touch Screen Callibration Suucesfully REPAIRED | .::BHATTI::. | Infinity-Box | 2 | 12-07-2007 13:06 |
CECT K808 format FFS ok but callibration screen?????? | .::BHATTI::. | Infinity-Box | 5 | 10-24-2007 16:00 |
Sensor callibration problem | rafauz | Infinity-Box | 1 | 09-15-2007 18:19 |
callibration window just closes before can calibrate HELP | fonefun | UST Pro II | 1 | 04-21-2007 21:07 |
