Universalbox Universalbox Official support area |
03-28-2009, 06:32 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 341568 Status: Offline Thanks Meter: 9 | help unlocking k320i! UMTSReadInfoThread 2.7.4.2048 started at: 2009/03/28 12:53:10 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3.95V is in range of: 4.00V ±10.0% Output power at Line2 4.76V is in range of: 5.00V ±25.0% Please turn on the phone! Serial line 1 speed changed to 920kBaud. Trying to send loader... OTP IMEI/CID/PAF: 356706-01-******** / 50 / 1 First FlashID: 897E Phone Color: RED. Phone CID: 50. Leaving test mode... Output power at Line1 3.95V is in range of: 4.00V ±10.0% Output power at Line2 4.74V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Entering explorer mode... Initializing GDFS... Hardware ID: 040 GDFS IMEI/CID/PAF: 356706-01-******** / 50 / 1 Lock Code: 0000 LangPackage: APAC CDA: CDA102727/101 Revision: R2A Leaving test mode... -------------------------------------------------------------------------------- TUMTSReadInfoThread 2.7.4.2048 finished at: 2009/03/28 12:54:39 Done. TUMTSJavaMakeUnlockerPhoneThread 2.7.4.2048 started at: 2009/03/28 12:54:50 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3.95V is in range of: 4.00V ±10.0% Output power at Line2 4.74V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Trying to send loader... OTP IMEI/CID/PAF: 356706-01-******** / 50 / 1 First FlashID: 897E Phone Color: RED. Phone CID: 50. Leaving test mode... Output power at Line1 3.95V is in range of: 4.00V ±10.0% Output power at Line2 4.74V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Entering explorer mode... Initializing GDFS... Leaving test mode... Java application uploaded, please turn on the phone with home network card or motorola test card. Select normal mode and connect it to the computer. When prompted select file mode on the phone. If the phone doesn't attach automatically a drive to the computer, copy the "unlocker.b" file by yourself from phone memory's path "other" to "uni\files\ericsson\loaders\java\rest". Rename the file to ".rest" that is on the clipboard. File name .rest copied to clipboard Waiting for phone... Drive E attached. Drive E detached. Aborting process... -------------------------------------------------------------------------------- TUMTSJavaMakeUnlockerPhoneThread 2.7.4.2048 finished at: 2009/03/28 13:00:56 http://i42.tinypic.com/28so9sp.jpg The problem is i cannot see the "unlocker.b" in the phone memory of my k320i in the folder name "other". And there is no folder name "uni\files\ericsson\loaders\java\rest" in my computer c:\uni. http://i43.tinypic.com/qqycdz.jpg http://i40.tinypic.com/1zqzmsh.jpg kindly guide me to my problem. Last edited by reynaldkatkat; 03-28-2009 at 06:37. |
03-28-2009, 12:11 | #5 (permalink) |
Major Poster Join Date: Mar 2008
Member: 738366 Status: Offline Thanks Meter: 1 | me also i never reached to make the rest file. the support manager think it easy to understand their technical language. i think you have to make a detailled manual for this, because by example personnaly i don't know what is the "clipboard" and when the soft tell "waiting for phone" i don't know if it is by usb or by the box. I am not enough good in english, but UB have to be able to used in all the world. I think UB is now a good box then make good things around it. |
03-28-2009, 12:29 | #6 (permalink) |
Member: 341568 Status: Offline Thanks Meter: 9 | Hello! i just want to know is k320 supported in making rest file? because i follow the procedure carefully and still when i checking the folder of the phone in "others' still no "unlocker.b" file. kindly guide me. |
HELP ME FOR UNLOCK K320i 5 LOUCK | nejm | SETool2 | 1 | 07-22-2009 13:08 |
help for k320i flashing | nadirghazi | Sony Ericsson | 3 | 06-05-2008 14:22 |
Any help Please K320i unlock probleme | Mounir | Cruiser Suite | 4 | 05-30-2008 19:38 |
help me k320i | colombia gsm | DreamBox | 1 | 05-22-2008 15:09 |
help for k320i | khalid2001 | Sony Ericsson | 0 | 12-18-2007 19:59 |
