Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 04-19-2008, 18:59   #1 (permalink)
GSM PAVIA's Avatar
Member: 235881
Thanks Meter: 221
pls help prob unlock 6120 !!!!!!
hi
i have nokia 6120
i need to unlock with online unlock
but always this prob.
Old 04-19-2008, 19:36   #2 (permalink)
Member: 87357
Thanks Meter: 9,456
If you become "this phone cannot be unlocked" message, you can't unlock it for now, but in next comming updates we will add this version too
Regards
Faisal
Old 04-19-2008, 19:45   #3 (permalink)
GSM PAVIA's Avatar
Member: 235881
Thanks Meter: 221
ok tnks bro 4 ur
reply.
for moment not possiblle to unlock this phone.
Old 04-19-2008, 23:58   #4 (permalink)
Member: 745071
Thanks Meter: 37
which cable did you use?
Old 04-20-2008, 06:33   #5 (permalink)
Member: 618006
Thanks Meter: 62
Regards
Faisal
do you mean that the problem is in version...
means if we change the Firmware version ,,is it possible to unlock now...
Old 04-20-2008, 18:26   #6 (permalink)
albarka network's Avatar
Member: 82693
Thanks Meter: 12
@MOBILEDOCTOR'S
IF DOWNGRADED THE PHONE TO UB BOX SUPPORTED VERSION,ARE WE GOING TO HAVE AN UNLOCKED PHONE??????
PLS URGENT REPLY IS NEEDED........
REGARDS.
Old 04-20-2008, 22:50   #7 (permalink)
Member: 132496
Thanks Meter: 34
I dont hink that this is depending on fw.
I think its depends in simlock server or imei or any other....
Old 04-21-2008, 09:02   #8 (permalink)
Member: 1155
Thanks Meter: 11
Red face The same problem here
Hello all,
i have the same problem with some 6120, did someone try to change software version to see what is happend?
Where could be the problem? Software version, hardware version or an alien influence :-) ???
regards,
DanV
Old 05-26-2008, 19:55   #9 (permalink)
Crazy Poster
Member: 377901
Thanks Meter: 10
6120c unlock
i unlock 6120c after not working mobile give solution
Old 05-26-2008, 20:08   #10 (permalink)
Member: 87357
Thanks Meter: 9,456
1: Erase
2: Full Flash
3: Write Backup ,if Not Have ,
4: Then Use ask to RPl Service
5: Make SX4
6: Write Pm without 308 Field
Regards
Faisal
pls help prob unlock PDA ( S.E P1) GSM FREE Seking Server 2 07-31-2009 18:42
pls help prob t 230 4 locs closed bulid Sony Ericsson 7 12-29-2003 19:59
pls help to unlock MW 3026 cale Infineon C16X M51 & ARM7 M52 BASED 0 09-14-2002 20:56
Can someone pls help me unlock MY-3020 bluelights Phone Unlocking Codes & Maps 17 09-02-2002 10:51
Page generated in 0.16992 seconds with 10 queries
