Universalbox Universalbox Official support area |
08-01-2008, 11:01 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 330340 Status: Offline Thanks Meter: 2 | Try unlock N95 with tp always failed |
08-01-2008, 11:29 | #3 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: IRELAND
Member: 87357 Status: Offline Thanks Meter: 9,457 | Quote:
Check your box UTP10 RJ45 Connector 1 and 10 pins .try to clean Connector in many cases will help if you band over it, and Maybe Gnd Problem Regards F@iSaL | |
08-01-2008, 18:04 | #4 (permalink) |
Member: 330340 Status: Offline Thanks Meter: 2 | I already did what you said sir, but still the same. Here is the log MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Initializing phone... Output power at Line1 3.92V is in range of: 4.00V ±10.0% Phone powered. Reading Info... MCU Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Additional_1: (c) Nokia PPM Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Pack: (c) Nokia Product code: 0548020 Original IMEI: ****************** Production serial: SGI848434 HW Version: 5900 DSP Version: dsprap_pb06w41v34 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [040A0C060A04] Profile bits: 0000000000000000 Simlock config: 2140700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21407F Block: 2; Lock: 1; State: Closed; Data: 21407F Block: 3; Lock: 1; State: Closed; Data: 21402F Block: 4; Lock: 1; State: Closed; Data: 21402F -------------------------------------------------------------------------------- TBB5ReadInfoThread finished at: 2008/08/01 16:47:59 Done. TBB5TPUnlockThread started at: 2008/08/01 16:48:12 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.92V is in range of: 4.00V ±10.0% Auto power-on mode set. Reading Info... MCU Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Additional_1: (c) Nokia PPM Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Pack: (c) Nokia Product code: 0548020 Original IMEI: ****************** Production serial: SGI848434 HW Version: 5900 DSP Version: dsprap_pb06w41v34 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [040A0C060A04] Profile bits: 0000000000000000 Simlock config: 2140700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21407F Block: 2; Lock: 1; State: Closed; Data: 21407F Block: 3; Lock: 1; State: Closed; Data: 21402F Block: 4; Lock: 1; State: Closed; Data: 21402F Backup already saved Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Initializing phone... Output power at Line1 3.92V is in range of: 4.00V ±10.0% Reading Info... MCU Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Additional_1: (c) Nokia PPM Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Pack: (c) Nokia Product code: 0548020 Original IMEI: ****************** Production serial: SGI848434 HW Version: 5900 DSP Version: dsprap_pb06w41v34 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER [040A0C060A04] Profile bits: 0000000000000000 Simlock config: 2140700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21407F Block: 2; Lock: 1; State: Closed; Data: 21407F Block: 3; Lock: 1; State: Closed; Data: 21402F Block: 4; Lock: 1; State: Closed; Data: 21402F Connect TP cables! Unlock try failed [FF] -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/08/01 16:49:22 Terminated with error: 00010071.00019290.0000040D.00000101.0000020C.00010 091 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBCXO229] TBB5ReadInfoThread started at: 2008/08/01 16:50:20 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Initializing phone... Output power at Line1 3.92V is in range of: 4.00V ±10.0% Reading Info... MCU Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Additional_1: (c) Nokia PPM Version: V 06wk41v31 Date: 05-06-07 Type: RM-159 (Unknown) Pack: (c) Nokia Product code: 0548020 Original IMEI: ****************** Production serial: SGI848434 HW Version: 5900 DSP Version: dsprap_pb06w41v34 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER [040A0C060A04] Profile bits: 0000000000000000 Simlock config: 2140700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21407F Block: 2; Lock: 1; State: Closed; Data: 21407F Block: 3; Lock: 1; State: Closed; Data: 21402F Block: 4; Lock: 1; State: Closed; Data: 21402F I try so many times, but get same result. |
08-01-2008, 19:44 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008 Age: 36
Member: 770769 Status: Offline Sonork: 100.1579718 Thanks Meter: 339 | try this solution as i tried this on mt-pro its 1000 % success open ur fone but dont remove screen frm fone , jus open the screw - power on the fone - after power on conect usb cable - fone ll ask for options - select pc suite option on fone - computer ll ask for drivers give drivers - now read fone on usb with ur universal box - connect gnd cable of ur tp to the fone gnd and go for unlock on usb try and post results |
08-02-2008, 10:58 | #6 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: india Age: 44
Member: 80583 Status: Offline Thanks Meter: 9 | Quote:
As We Select Usb Option In Uni Box So Unlock Via Test Point Option Gets Deactivated | |
08-02-2008, 12:08 | #8 (permalink) |
Member: 330340 Status: Offline Thanks Meter: 2 | Thanks for all. Btw, for gsm era : can't unlock with usb connection, like hiteshhitesh said. For mizmatch : a already replace all the parts, just the mainboard left. Still trying till this time n still failed. |
08-03-2008, 17:39 | #11 (permalink) |
Member: 330340 Status: Offline Thanks Meter: 2 | Know, i got problem with error in unlock with ' BB5TP Adapter is not connect, or not properly connect etc'. I already band the pin in box connector, but still not solve the problem. Can i change box connector (rj-45 or rj 48 ? ) with the new one ? Is it need to re-solder to remove it or just plug out then replace it ? |
i cant unlock n95 with TP | marekkaf | NoooX Box | 1 | 06-06-2009 21:31 |
How to unlock N95 via TP with 1.54 | City_Mobiles22 | MT-BOX | 1 | 11-08-2008 15:29 |
Try unlock 6131 with tp always failed | martindeneco | Universalbox | 6 | 08-27-2008 03:44 |
E1 unlock W/O TP mathod failed. | roberts | Smart-Clip | 1 | 12-23-2006 11:12 |
i have C72 and try to unlock it with Tp but Tp solution not good becuse dont connect | gsm4libya | SIEM Service Tools | 2 | 04-28-2006 12:47 |
