Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 04-26-2008, 16:27   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
What is the problem with 1100 . . . . . Check this one.
Hello ,
I have dead 1100 phone. & i try to flash the phone with UB. this error show.
Take a look @ screen shot.
In same cable i flash the many 1600 & 1110 phone.
But this model show this error.
What is the problem . . .
Thankx in advance.
Old 04-26-2008, 20:47   #2 (permalink)
mickle1's Avatar
Member: 228253
Thanks Meter: 22
i had the same problem with a 2310 as it initialises the phone hold the power switch down should work best of luck. let me know what happens
Old 04-27-2008, 11:04   #3 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Where r u Mobile Doctor & Universalbox . . . . ?
Check u r customer queries.
Waiting . . . . . . . . . . . . . . . .
Old 04-27-2008, 22:03   #4 (permalink)
universalbox's Avatar
Member: 68982
Thanks Meter: 17,853
bad cable, or phone has problems.
Br:universalbox.
Old 04-28-2008, 16:54   #5 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
For cable problem also i change the cable from working one.
After that same problem.
Old 04-28-2008, 19:06   #6 (permalink)
Member: 744454
Sonork: shakil
Thanks Meter: 26
Try to flash by sellecting easy flash cable, even then same problem then try to hit the power button when after clicking the flash button the flashing starts and as it shows the volt input in the screen. in most cases this works. Mostly this is not cable problem.
Old 04-28-2008, 20:03   #7 (permalink)
Member: 87357
Thanks Meter: 9,457
bro ,its look like a hardware problem ,Please Check Hardware Section.
Regards
Faisal
Old 09-05-2008, 14:56   #8 (permalink)
Member: 199996
Thanks Meter: 41
I have Nokia 1100 phone. it has no ohm.
what is the problem?
pls help me
Old 09-05-2008, 15:01   #9 (permalink)
Member: 199814
Thanks Meter: 1,960
Bad cable or Bad phone. if there is hardware issue inside the phone you will get always this error.
Old 09-05-2008, 15:37   #10 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 329
The problem is the connection sure that the cable pins make good contact with the telephone, often for doing so must be disarmed phone, if the problem persists it is highly probable that the telephone has damaged the hard
Old 09-06-2008, 10:22   #11 (permalink)
mickle1's Avatar
Member: 228253
Thanks Meter: 22
Hello ,
Thankx in advance.
press the and hold power button on the phone immediatly after pressing yes on the error message
What is the problem with this team .::Naseer Al-islam::. A1-Services.org 4 03-26-2009 04:50
WHAT IS THE PROBLEM WITH THIS?? INFINITY pls help... xannix_7575 Infinity-Box 8 03-06-2009 01:40
what is the problem with this please help zerocoolfrost Universalbox 2 10-01-2008 17:16
what is the problem with get flash from vsh BLIDA Samsung Flashers, Software, Firmware. 0 12-16-2002 18:12
Page generated in 0.18764 seconds with 9 queries
