Nokia 3100 not charging hello, i have got a nokia 3100 that displays "not charging" whenever i try to chargre it...can anybody pls help me with a solution...thnx! |
First try to use diferent chargers... that message means : phone recognize charger but dont allow charging... After that if 100% sure that no problem in charger, try flash it... |
Thanx, i will try that soln and come back to you.... |
open phone and clean point of contact under connector. Else you must solder resistants near connector. |
try charger without batt, check voltage in conbatt, if low voltage (- 3 volt ) change UEM and rebuilt IMEI |
Try to flash mcu+ucp+pm and it will ok otherwithe replace uem |
reflow smt components Try use hot air and reflow all smt components from uem below. |
uper side battery conactor in center 2 PF or Rajistance change this is parmanant solution |
nokia 3100 nokia 3100 not charging diagrame |
try this it will solve |
