EGOLD models White LCD please sst team, help us to post the solution of white screen/lcd of siemens phones after flash with SST as i encounter this problem here and most times after write eeprom from sipport site, phone die completely and i buy new one for custumer all the time! |
for me , only tuning----->phone contrast adjustment. then read ,adjust for approximate 100 ,write the value back to phone. all is ok! happy and collect customer's money |
for all EGOLD models you can use the display files from our support area (*.dst files). Usually phones have 2 types of LCD settings. You can see type1 and type2 display settings files |
still no solution for this cf62 and ax75, everything has been done still the same, white lcd |
Can you tell us which dst file you have used? |
>SST-GSM i have tried using the two .dst available from support for CF62 CF62_V07.DST CF62_V84_1.DST i have tried to flash with differet software versions. if i write eeprom from support site, phone will die, untill i revive with Joker! |
thanks to all, i solved the cf62 by joker contrast adjustment after write lcd file! |
