10-17-2014, 23:30 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: PL
Member: 384541 Status: Offline Thanks Meter: 101 | Question about SST Android Suite Question about SST Android Suite Is possible to remove limitation of direct reading? "Checking Connection with Device... Checking Root Access... Detected Root Access Reading Data Image Directly to PC Started Data Partition Size 11 GB Data Partition Size Exceeds 2GB Size Limit for Direct Reading Reading Data Image Directly to PC Finished The Operation was Unsuccessfull !!!" BR |
10-20-2014, 14:41 | #2 (permalink) |
No Life Poster Join Date: Sep 2003
Member: 38795 Status: Offline Thanks Meter: 106 | New SST Android Suite 2.1.0 is coming soon Hi, First sorry for answering so late. 2GB Size Limit for Direct Reading is set for 2 reasons:
The upcoming version of SST Android Suite will have Disk Copy option to directly clone entire data partition to external SD card. For your case you will need at least 16 GB micro SD card. Also for devices that could be mounted as USB Mass Storage Device reading data partition is not needed for files recovery. |
The Following User Says Thank You to SST-GSM For This Useful Post: |
