06-07-2006, 13:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | SST V7.40 and A70 after laste update i see sst lose flash fonction i Flash (4 pcs) a70 Still dead ( 2pcs) C75 olso (1pcs)C72 but when i use V6.86 after Flash mobile work fine i hope you fix this bug soon as possibel br hitibiti |
06-09-2006, 09:42 | #3 (permalink) |
No Life Poster Join Date: Sep 2003
Member: 38795 Status: Offline Thanks Meter: 106 | After Last update there is one change in flashing function: "flash firmware area only" which is set at default. So when the customers flash the phone for example for downgrade/upgrade or FFS reset it will protect the phone EEPROM memory. But if you want to flash a dead phone please remove the checkbox selection and it will work just like the privious version of SST As we see that some of our users do not understand the new feature we shall create a special sticky topic describing it. |
06-09-2006, 10:40 | #4 (permalink) | |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Quote:
like for Flash A60 C55 C60 A56 no need to do press repair Boutton but for new model like A70 or C75 C72 ( dead phone , you tel "flash firmware area only" i do that same thing mobile still dead !! so pleas try to find dead seimesne and try you will see like i say before tou SST-GSM i recive more than 20 or 30 Seimense /week so it's easy to learn if i am new | |
06-09-2006, 22:57 | #7 (permalink) | |
Member: 38795 Status: Offline Thanks Meter: 106 | Quote:
1. "flash firmware only - not set 2. "Calculate EEPROM area" set | |
New SST v7.58 update !!! Windows Vista support and Vista driver installation! | SST-GSM | SST-Dongle | 18 | 01-02-2008 12:07 |
SST v7.10 now speaks your languge! | SST-GSM | SST-Dongle | 5 | 06-14-2007 09:41 |
SST v7.40 now with S68,AF51,AL21 and AP75 support | SST-GSM | SST-Dongle | 13 | 08-29-2006 11:48 |
Important Anouncemnt about SST v7.xx Beta version | SST-GSM | SST-Dongle | 17 | 02-04-2006 16:30 |
sst 6.50 and a70 first test | HackGSM team | SST-Dongle | 26 | 08-14-2005 14:03 |
