GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   SST-Dongle (https://forum.gsmhosting.com/vbb/f310/)
-   -   SST v 7.53 - New "Direct Boot " mode enable connection without test-point. (https://forum.gsmhosting.com/vbb/f310/sst-v-7-53-new-direct-boot-mode-enable-connection-without-test-point-345848/)
SST-GSM 11-04-2006 01:20
SST v 7.53 is already available for download.
New "Direct Boot " mode enable connection without test-point for X65/X75 SGOLD models.
Please remember to select "Direct Boot " after model and speed selection.
PS. Maximum Connection speed with this boot method should not exceed 460k!
glicos 11-04-2006 02:42
Another time saving feature of SST. Luckily have one for test....thanks sst team!!!
andrew14 11-04-2006 02:46
maybe someday there will be no more tp.............
Vansy 11-04-2006 02:56
Lucky my old dongle is working. After upgrade antirivus I cannot run sst program , always say cannot find " kernel32.dll". I Thing dongle spoiled after reinstall driver many times still not work. Now I know it detect by antivirus program. after deactive program run normal. Thank you for new update.
vertz 11-04-2006 03:46
what antivirus do you use? for me i use nod32 and it works fine. no problem whatsoever.
frua 11-04-2006 08:15
s75 and s68 dont work
SST-GSM 11-04-2006 08:53
Yes some of the new models may not support this method.
nzeiga 11-04-2006 11:14
Good Update
Gread Work Thanks SST Team
niketlen 11-04-2006 12:55
SL75 (with software faliure) not working !!! maybe direct boot working with good phone ?
Profiler 11-04-2006 16:16
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
stolen solution from Griffin Team!
regards: Profiler
gsm-decode 11-04-2006 18:53
COPY CAT ****
You talk like Zuleah man :)
SST-GSM 11-04-2006 19:16
Models S75, SL75 S68 and EL71 do not support direct boot method as this boot authority bypassing backdoor is too old and already cleared by Benq-Siemens ! Use java midlet("Boot Password" method) for SL75 and test point method for S68 and EL71 instead of it.
The following models are supported by direct boot method:
  • C65,C6v and etc.
  • CX65,CX70,CXI70
  • M65
  • S65
  • SL65
  • SK65
  • C72
  • C75
  • CX75
  • M75
The adviced maximum connection speed using this method is 460800.
After first connection the phone may be connected using "patched boot" method
Allunlockingsource 11-05-2006 07:19
i need sst new verion
sp-lox 11-06-2006 11:13
http://www.sst-gsm.com/scard/SST7_Setup.exe
[Rod] 11-07-2006 05:16
not working on c72... it gives service mode error.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.11174 seconds with 6 queries
