1600 Process Failed, plz help me 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.0.8.0] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84E366AA1E791AEF5C83E1D08F Decoded MSID: 3E4EBAE9-001ACEC6-AA000000 Encoded FAID: 82BB991F-F0B30268-BE938035 IMAGE: rh64_05.530 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:26 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:11 IMAGE: rh640_nai5.53ia Area1: 0x01380000-0x013BFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:00 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.0.8.0] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84E366AA1E791AEF5C83E1D08F Decoded MSID: 3E4EBAE9-001ACEC6-AA000000 Encoded FAID: 82BB991F-F0B30268-BE938035 IMAGE: rh64_05.530 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:26 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:11 IMAGE: rh640_nai5.53ia Area1: 0x01380000-0x013BFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:00 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: :mad: |
make erase then try again or use higher version like 7.02 |
Reheat Flash IC then Flash with other version. |
br write cnt file in the ppm field. after you finish writing mcu and ppm select the cnt file in the ppm field and write it only and you see it work ok. good luck. |
