Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 06-05-2011, 18:43   #1 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
1616 flash ok but not powered on
All is ok but not charging or powered on .
I THINK IT'S LCD FAULT. but is it hardware or software
mcu sw : V 03.60 15-01-10 rh-125 (c) nokia
ppm sw : V 03.60 15-01-10 rh-125 (c) nokia ic
platform: Infineon
prd.code: 0588618
bpr.code: 059c7b8
prod.sn : 48312ddai
hw vers : 1010
uem : 1328
upp : 8850 [2292]
lcd type: Unkwn: Ids: 00:00:00
imei : 354xxxxxxxxx
sl conf : 001-01-00000000000
sl prof : 000000000003000-2
sl var : 00003548710424273200
sl aux : 000b0000
hw sig : C75bdb9111fd0de1
box id : Ffffffffffffffff
blk1= l1: Open l2: Open l3: Open l4: Open l5: Open
blk2= l1: Open l2: Open l3: Open l4: Open l5: Open
blk3= l1: Open l2: Open l3: Open l4: Open l5: Open
blk4= l1: Open l2: Open l3: Open l4: Open l5: Open
blk5= l1: Open l2: Open l3: Open l4: Open l5: Open
blk6= l1: Open l2: Open l3: Open l4: Open l5: Open
blk7= l1: Open l2: Open l3: Open l4: Open l5: Open
provider: Gsm test equipment
Old 06-05-2011, 18:51   #2 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
check harware ,, your fone must gating volts on power suply this time ..
check lcd
Old 06-05-2011, 18:58   #3 (permalink)
Member: 904530
Thanks Meter: 517
posible too old firmware, last is v6.20
The Following User Says Thank You to Major-T For This Useful Post:
Old 06-05-2011, 18:59   #4 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
LCD Fault Check LCD Also LCD Tracks
The Following User Says Thank You to shoaibrao For This Useful Post:
Old 06-05-2011, 19:26   #5 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
change lcd..................
The Following User Says Thank You to f164 For This Useful Post:
Old 08-05-2011, 12:07   #6 (permalink)
Crazy Poster
Member: 1230999
Thanks Meter: 6
1616 flash ok lcd ok lcd treck ok but
lcd type: Unkwn: Ids: 00:00:00 plzzzzzzzzzzzzzzz help
Old 08-05-2011, 12:14   #7 (permalink)
cdma_sollution's Avatar
Member: 1271517
Sonork: 100.1606968
Thanks Meter: 54
use it bro.....[IMG]http://2.bp.********.com/-dygGcY3VCjk/TV0R3XpVPiI/AAAAAAAADEk/dh4e7Ju4Xlc/s320/nokia1800%252C1616display.png[/IMG]
The Following User Says Thank You to cdma_sollution For This Useful Post:
Old 08-05-2011, 12:26   #8 (permalink)
Crazy Poster
Member: 1230999
Thanks Meter: 6
sir its all treck ok
Old 08-05-2011, 12:31   #9 (permalink)
Member: 1271517
Sonork: 100.1606968
Thanks Meter: 54
then change lcd bro also post info
Old 08-05-2011, 12:35   #10 (permalink)
Crazy Poster
Member: 1230999
Thanks Meter: 6
Old 08-05-2011, 13:11   #11 (permalink)
Crazy Poster
Member: 1230999
Thanks Meter: 6
Old 08-05-2011, 13:22   #12 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Try to flash with latest firmware available.
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 08-05-2011, 14:29   #13 (permalink)
mridulnandy's Avatar
Member: 1134419
Sonork: 100.1621725
Thanks Meter: 452
Try to flsh with this file. Download all .
http://nds2.fds-fire.nokia.com/fdp/i..._signature.bin
http://nds2.fds-fire.nokia.com/fdp/i..._06.51_001.vpl
http://nds2.fds-fire.nokia.com/fdp/i...bel_layout.xml
http://nds2.fds-fire.nokia.com/fdp/i...fier_vDCT4.sim
http://nds2.fds-fire.nokia.com/fdp/i...E_P8027401.pcx
http://nds2.fds-fire.nokia.com/fdp/i..._06.51_001.dcp
http://nds2.fds-fire.nokia.com/fdp/i...250_nai06.51ic
http://nds2.fds-fire.nokia.com/fdp/i...rh125_006.51ic
http://nds2.fds-fire.nokia.com/fdp/i..._rh125_006.510
After full flash do "Info" , If set gives info then set will switch on, if not switch on please change LCD. This is 100% suceed solution .
The Following User Says Thank You to mridulnandy For This Useful Post:
Old 08-10-2011, 16:20   #14 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
chel your lcd track missing
watch witch mirer and u see track is damegd
i all so face this problem but after rapeir track 100% working
Old 08-10-2011, 17:03   #15 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,266
100% lcd problem change lcd
The Following User Says Thank You to rizwankhan8670 For This Useful Post:
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.26629 seconds with 10 queries
