3110c data blk error-perfect soln mostly on 3110c dead during flashing in hwk...data blk error....i tried n getting good result....in cable 7pin.....just connect 9v via zener diode to 2nd no pin from top(b/c side) n 6th no pin ground...click on extvpp..(attach 9v battery)..n flash.....just do technically perfect by understanding |
can post here log file.. |
Flashing 7 pins, Dual Line should be Check Mate. Its best to use Other Tool using USB cable. |
brother just connect 9v via zener diode...to 2nd pin which is disconnected in 7pin jaf cable n 6th no pin ground....just bring these two wires out from upside of cable n connect 9v battery...click on extvppp...thats all |
is it correct? http://i631.photobucket.com/albums/u.../BB5_cable.jpg br, |
plz post any one has tested this solution |
3110c - RX2 flashing error Flash with - ver 7.21, cable - 8 pin & USB cable Rehot - CPU, Power IC , Thavo , Memory Ic , many time present time set complete dead BUT booting 100% ok . Set also could not convert in to Normal , Local , or Test mode . Flashing Result - by different box Jaf - abort at last i select downgrade also. Mx KEY - RX2 not responding check BSI , cable & pin Micro - Data BLK error UB - Through USB - Detecting USB flash device. Sir any other cable or box solve this solution Pls help me . Please digramatically see your language i could not follow it |
Use JAF with UFS interface I got good results. |
see SL1 3110c and guide me please detail about cable 5 Attachment(s) Detail pinout about 3110c |
1 Attachment(s) 3110c Data BLK error or RX2 error This modified cable figure is write or wrong |
Why can i interface between Micro & JAF clear it please. |
I have 5ps 3110c with the same probleme, any one have perfect solution. |
