12-27-2009, 00:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Cairo/Egypt Age: 36
Member: 914426 Status: Offline Sonork: 01017474627 Thanks Meter: 235 | 3110c flashing problem plz helpe while flashing plz solution mates |
12-27-2009, 02:13 | #10 (permalink) |
Freak Poster Join Date: Oct 2002 Location: Bulgaria Age: 49
Member: 16994 Status: Offline Thanks Meter: 157 | Try with "Dual Line" unchecked. If not success - flash phone with cracked phoenix (http://phoenixslayer.********.com/) on usb. |
12-27-2009, 02:57 | #11 (permalink) | |
Member: 914426 Status: Offline Sonork: 01017474627 Thanks Meter: 235 | Quote:
12-27-2009, 05:35 | #13 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 421331 Status: Offline Thanks Meter: 30 | Use another cable tested 100% I was trying with three cables with 1 pin missing but the error always appear like in the picture but I tryed with one cable with all pins complete and flashing succesfully...the phone is working fine |
12-27-2009, 06:43 | #14 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1170910 Status: Offline Thanks Meter: 76 | i was also facing same problem and i tried using GPG TMA Adapter only thing you have to do when the Data Blk Error comes means phone trying to come in Normal Mode and device doesn't detect the phone so when the Data Blk Error comes keep pressing Power switch and than press ok to continue. hope ths will help you |
12-27-2009, 06:52 | #15 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | This is cable problem. Use 7 pincable our "check" the "Dual line" check box. If you have 7 pin cable then uncheck the "Dual line" check box |
3110c flash problem plz help me | sanjay rana | Nokia Hardware & Hardware Repair | 8 | 03-17-2010 04:49 |
3110c flashing problem plz helpe | mogrem.soft | Nokia Base Band 5 ( BB-5 ) | 14 | 12-27-2009 10:21 |
3110c flashing problem...plz help me | manishber | Nokia Base Band 5 ( BB-5 ) | 9 | 07-17-2009 00:15 |
3110c format ok but flashing problem plz help | shivashakthi | Nokia Hardware & Hardware Repair | 0 | 02-06-2009 14:14 |
