7610 Phone Startup failed contact the retailer i have got a 7610 set with phone startup failed contact retailer i got info and press format user area but it showed failed formating user area then i full flashed it and again i press format user area but the same result |
make full factory defaults at first |
bro manual formate * + 3 + send key + power buten same time hold and you see on lcd formating. after formate your set ok use thanks button |
you connect your fone and click only '' formate user area'' its last solution in software |
if all above advice not work...after all software still startup failed,try to rehot RAM..and then format user area after checking boot ok...goodluck:) |
Erase flash with this address and flash with latest files,then full factory setting.START ADDRESS IS 02000000 AND END ADDRESS IS 027FFFFF.PL REFER UFS 3 MANUAL ALSO. |
Flash Ic,zocus ic,.......... Try To Replace http://i292.photobucket.com/albums/m...M/76100002.jpg :) |
formate user area' and choose xtra slow speed ur fone is 1000% ok |
just do 5 times format.......... Br. Shashank |
