Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 09-12-2009, 08:09   #1 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 99
7610 Phone Startup failed contact the retailer
i have got a 7610 set with phone startup failed contact retailer i got info and press format user area but it showed failed formating user area then i full flashed it and again i press format user area but the same result
Old 09-12-2009, 18:31   #2 (permalink)
Member: 904530
Thanks Meter: 516
make full factory defaults at first
Old 09-12-2009, 19:26   #3 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 763
bro manual formate * + 3 + send key + power buten same time hold and you see on lcd formating.
after formate your set ok
use thanks button
Old 09-12-2009, 20:16   #4 (permalink)
.::Raj::.'s Avatar
Member: 923397
Sonork: 100.1584169
Thanks Meter: 451
you connect your fone and click only '' formate user area'' its last solution in software
Old 09-13-2009, 00:17   #5 (permalink)
Crazy Poster
Member: 954742
Thanks Meter: 20
if all above advice not work...after all software still startup failed,try to rehot RAM..and then format user area after checking boot ok...goodluck
Old 09-13-2009, 08:56   #6 (permalink)
Member: 185776
Thanks Meter: 73
Erase flash with this address and flash with latest files,then full factory setting.START ADDRESS IS 02000000 AND END ADDRESS IS 027FFFFF.PL REFER UFS 3 MANUAL ALSO.
Old 09-13-2009, 10:45   #7 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,095
this is the 100% right solution Misbahullah brother just follow this
Old 09-13-2009, 12:10   #8 (permalink)
ucokmonalisa's Avatar
Member: 527741
Thanks Meter: 355
Flash Ic,zocus ic,.......... Try To Replace
http://i292.photobucket.com/albums/m...M/76100002.jpg
Old 09-13-2009, 12:14   #9 (permalink)
transpirit's Avatar
Member: 950964
Thanks Meter: 160
formate user area' and choose xtra slow speed ur fone is 1000% ok
Old 09-13-2009, 12:21   #10 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
just do 5 times format..........
Br.
Shashank
Old 09-13-2009, 20:21   #11 (permalink)
Member: 115066
Thanks Meter: 48
post mobile info here bro
7610 Phone Startup failed Contact to Retailer Kethey WD2 & APE (Symbian Phones) 28 08-05-2009 08:32
7610 phone startup failed contact the retailer .::ADNAN440::. Nokia Hardware & Hardware Repair 5 08-03-2009 16:35
7650: Phone startup failed. Contact the retailer problem jignesh_1000 Griffin 9 09-25-2005 15:11
7650: Phone startup failed. Contact the retailer. Greatgonzo Griffin 7 06-24-2004 11:39
Page generated in 0.36426 seconds with 8 queries
