E1410 after flashing imei 00000 Dear hwk team E1410 was hanging so i flashed it with E1410DDIA3. flash was ok but imei has changed to 00000000 kindly give solution thanks |
http://forum.gsmhosting.com/vbb/f286...0000-a-998343/ so how you flashed ? |
after flash write e2p and rebuilt imei |
wrote e2p, but still imei write fails 1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A) 2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre Flash1: Fl_Id: 00890000_89010000 - Intel SIBLEY 256 Baud Rate Set: 460800 bps Image File: E1410_RW6S277997_E2P.s3t Flashing NOR part... Write Done, 131088 byte(s), Time: 00:08 Phone Must be with Battery and Powered On ! MSL : Active 1st: 008800241601000000033A000030 MSL : FAILED 10 IMEI: Error IMEI Write Error |
repair MSL at first !!! |
to repair MSL its asking for serial no and serial no is not visible. what should i do??????? thanks |
Hi. Try to Write e2p readed from working fone, no need to rebuiled ImEI. |
Flash with Z3X after that imei was 0000 then just.. change TAT mode Flash mode then rebuild imei number and press coustem your problem will solve 100% if any issue post me reply ..:: X.Ram ::.. |
just rebuild imei and write the imei as u wish bro |
