Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 12-01-2009, 16:20   #1 (permalink)
Member: 839770
Thanks Meter: 24
Question Nokia 6680, FLASHING OK BUT DISPLAYS NOKIA ONLY
Hi all help me with nokia 6680 pls, i already flashed nokia 6680 successfully but still can't power on, it displays Nokia only here is the log.br thank's in advance
1ST BOOT : C0,0C [Rm-36] [2.0.9.0]
OMAP ID : 17100701
OMAP MODE : 00
OMAP PBID : 20CDAD323BAE58C1BDC1D59512929CEA24036B1A
OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
OMAP ROID : AB5E4ADB27A06946
RAPx ID : 000000010000022600010006000C192101002100
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx PBID : 11D0000548C94F574F5284EB05F5AA076D143B15
RAPx MODE : 00
RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
RAPx ROID : F28A211FAC901AEE
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
CMT FLID0 : 00010002-00000111, Amd 29NS064J
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0
APE FLID0 : 00EC0035-00A500BD, Sam KEE00D00CM
APE FLCNT : 01010000020000000600000000000000000000
APE 2ND Boot OK
APE ALG0 : h3_sam_nand_gbbm.fg, Ver: 1.33.0
APE VPP : Internal
APE KSIG1 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
DUAL LINE : True
APE ALG Boot OK
Rebooting Mobile
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : RM36_5.050440_B5.C0R
CMT NOR Erase Area: 0x00000000-00509309
CMT NOR Erase Area: 0x006A0000-006BFFFF
CMT NOR Erase Area: 0x006DF000-006EFFFF
CMT NOR Erase Area: 0x00700000-007EFFFF
CMT FLASH ERASE OK, Time: 00:46
Written: 7 Certificate(s)
CMT FLASH WRITE OK, Time: 00:27
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Boot OK
APE VPP : Internal
DUAL LINE : True
APE ALG Boot OK
APE NAND Erase Area: 0x00000000-0000FFFF
APE NAND Erase Area: 0x00010000-0001FFFF
APE NAND Erase Area: 0x00020000-000203FF
APE NAND Erase Area: 0x00050000-01F5BFFF
APE FLASH ERASE OK, Time: 00:03
Written: 8 Certificate(s)
APE FLASH WRITE OK, Time: 01:30
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Boot OK
APE VPP : Internal
DUAL LINE : True
APE ALG Boot OK
IMAGE : RM36_5.050440_B5.v25
APE NAND Erase Area: 0x01060000-01F5BFFF
PPM FLASH ERASE OK, Time: 00:01
PPM FLASH WRITE OK, Time: 00:33
Flashing Completed, Rebooting Mobile
UI Defaults Ok, Time: 00:10
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults Ok, Time: 00:01
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
Old 12-01-2009, 17:28   #2 (permalink)
Member: 1094377
Thanks Meter: 27
format phone with jaf if not solve write PM and flash
Old 12-01-2009, 22:21   #3 (permalink)
chimed09's Avatar
Member: 479816
Thanks Meter: 851
BACKUP RPL and full eraes and write flash...
Old 12-01-2009, 23:41   #4 (permalink)
Member: 839770
Thanks Meter: 24
Here is the log, i try to write pm but the problem still goes on
PM File: 6680 ok.pm
Group Id: [1] Rec: 0 Len: 114 .... Ok 2
Group Id: [1] Rec: 1 Len: 4 ...... Ok 1
Group Id: [1] Rec: 2 Len: 86 ..... Ok 1
Group Id: [1] Rec: 4 Len: 110 .... Ok 2
Group Id: [1] Rec: 5 Len: 4 ...... Ok 1
Group Id: [1] Rec: 6 Len: 86 ..... Ok 1
Group Id: [1] Rec: 8 Len: 110 .... Ok 2
Group Id: [1] Rec: 13 Len: 86 ..... Ok 1
Group Id: [1] Rec: 15 Len: 4 ...... Ok 1
Group Id: [1] Rec: 16 Len: 86 ..... Ok 1
Group Id: [1] Rec: 18 Len: 86 ..... Ok 1
Group Id: [1] Rec: 20 Len: 86 ..... Ok 1
Group Id: [1] Rec: 24 Len: 84 ..... Ok 1
Group Id: [1] Rec: 25 Len: 16 ..... Ok 1
Group Id: [2] Rec: 0 Len: 340 .... Ok 3
Group Id: [4] Rec: 0 Len: 1 ...... Ok 1
Group Id: [4] Rec: 1 Len: 16 ..... Ok 1
Group Id: [4] Rec: 2 Len: 44 ..... Ok 1
Group Id: [4] Rec: 3 Len: 10 ..... Ok 1
Group Id: [4] Rec: 4 Len: 8 ...... Ok 1
Group Id: [4] Rec: 5 Len: 8 ...... Ok 1
Group Id: [4] Rec: 9 Len: 5 ...... Ok 1
Group Id: [8] Rec: 0 Len: 12 ..... Ok 1
Group Id: [8] Rec: 1 Len: 12 ..... Ok 1
Group Id: [8] Rec: 4 Len: 8 ...... Ok 1
Group Id: [8] Rec: 6 Len: 4 ...... Ok 1
Group Id: [8] Rec: 7 Len: 8 ...... Ok 1
Group Id: [11] Rec: 0 Len: 4 ...... Ok 1
Group Id: [11] Rec: 1 Len: 4 ...... Ok 1
Group Id: [11] Rec: 2 Len: 4 ...... Ok 1
Group Id: [11] Rec: 3 Len: 4 ...... Ok 1
Group Id: [11] Rec: 4 Len: 1 ...... Ok 1
Group Id: [11] Rec: 5 Len: 6 ...... Ok 1
Group Id: [11] Rec: 6 Len: 1 ...... Ok 1
Group Id: [11] Rec: 7 Len: 2 ...... Ok 1
Group Id: [11] Rec: 8 Len: 2 ...... Ok 1
Group Id: [11] Rec: 9 Len: 2 ...... Ok 1
Group Id: [11] Rec: 10 Len: 2 ...... Ok 1
Group Id: [11] Rec: 11 Len: 2 ...... Ok 1
Group Id: [11] Rec: 12 Len: 1 ...... Ok 1
Group Id: [11] Rec: 13 Len: 1 ...... Ok 1
Group Id: [11] Rec: 14 Len: 1 ...... Ok 1
Group Id: [11] Rec: 15 Len: 1 ...... Ok 1
Group Id: [11] Rec: 16 Len: 1 ...... Ok 1
Group Id: [11] Rec: 17 Len: 1 ...... Ok 1
Group Id: [11] Rec: 18 Len: 1 ...... Ok 1
Group Id: [11] Rec: 19 Len: 2 ...... Ok 1
Group Id: [11] Rec: 20 Len: 2 ...... Ok 1
Group Id: [11] Rec: 21 Len: 1 ...... Ok 1
Group Id: [11] Rec: 22 Len: 1 ...... Ok 1
Group Id: [11] Rec: 23 Len: 4 ...... Ok 1
Group Id: [11] Rec: 24 Len: 4 ...... Ok 1
Group Id: [11] Rec: 25 Len: 2 ...... Ok 1
Group Id: [11] Rec: 26 Len: 2 ...... Ok 1
Group Id: [11] Rec: 27 Len: 2 ...... Ok 1
Group Id: [11] Rec: 28 Len: 2 ...... Ok 1
Group Id: [11] Rec: 29 Len: 1 ...... Ok 1
Group Id: [11] Rec: 30 Len: 1 ...... Ok 1
Group Id: [11] Rec: 31 Len: 1 ...... Ok 1
Group Id: [11] Rec: 32 Len: 1 ...... Ok 1
Group Id: [11] Rec: 33 Len: 1 ...... Ok 1
Group Id: [11] Rec: 34 Len: 1 ...... Ok 1
Group Id: [11] Rec: 35 Len: 1 ...... Ok 1
Group Id: [11] Rec: 36 Len: 1 ...... Ok 1
Group Id: [11] Rec: 37 Len: 1 ...... Ok 1
Group Id: [11] Rec: 38 Len: 2 ...... Ok 1
Group Id: [11] Rec: 39 Len: 2 ...... Ok 1
Group Id: [11] Rec: 40 Len: 2 ...... Ok 1
Group Id: [11] Rec: 41 Len: 2 ...... Ok 1
Group Id: [11] Rec: 42 Len: 2 ...... Ok 1
Group Id: [11] Rec: 43 Len: 4 ...... Ok 1
Group Id: [11] Rec: 44 Len: 4 ...... Ok 1
Group Id: [11] Rec: 45 Len: 4 ...... Ok 1
Group Id: [11] Rec: 46 Len: 1 ...... Ok 1
Group Id: [11] Rec: 47 Len: 16 ..... Ok 1
Group Id: [11] Rec: 48 Len: 2 ...... Ok 1
Group Id: [11] Rec: 49 Len: 2 ...... Ok 1
Group Id: [11] Rec: 50 Len: 20 ..... Ok 1
Group Id: [11] Rec: 51 Len: 10 ..... Ok 1
Group Id: [11] Rec: 52 Len: 2 ...... Ok 1
Group Id: [11] Rec: 53 Len: 20 ..... Ok 1
Group Id: [11] Rec: 54 Len: 10 ..... Ok 1
Group Id: [11] Rec: 55 Len: 1 ...... Ok 1
Group Id: [11] Rec: 56 Len: 1 ...... Ok 1
Group Id: [11] Rec: 57 Len: 1 ...... Ok 1
Group Id: [11] Rec: 58 Len: 1 ...... Ok 1
Group Id: [11] Rec: 59 Len: 1 ...... Ok 1
Group Id: [11] Rec: 60 Len: 1 ...... Ok 1
Group Id: [11] Rec: 61 Len: 1 ...... Ok 1
Group Id: [11] Rec: 62 Len: 1 ...... Ok 1
Group Id: [11] Rec: 63 Len: 1 ...... Ok 1
Group Id: [11] Rec: 64 Len: 1 ...... Ok 1
Group Id: [11] Rec: 65 Len: 1 ...... Ok 1
Group Id: [11] Rec: 66 Len: 2 ...... Ok 1
Group Id: [11] Rec: 67 Len: 2 ...... Ok 1
Group Id: [11] Rec: 68 Len: 2 ...... Ok 1
Group Id: [11] Rec: 69 Len: 2 ...... Ok 1
Group Id: [11] Rec: 70 Len: 2 ...... Ok 1
Group Id: [11] Rec: 71 Len: 2 ...... Ok 1
Group Id: [11] Rec: 72 Len: 2 ...... Ok 1
Group Id: [11] Rec: 73 Len: 2 ...... Ok 1
Group Id: [11] Rec: 74 Len: 2 ...... Ok 1
Group Id: [11] Rec: 75 Len: 2 ...... Ok 1
Group Id: [11] Rec: 76 Len: 2 ...... Ok 1
Group Id: [11] Rec: 77 Len: 2 ...... Ok 1
Group Id: [11] Rec: 78 Len: 2 ...... Ok 1
Group Id: [11] Rec: 79 Len: 2 ...... Ok 1
Group Id: [11] Rec: 80 Len: 2 ...... Ok 1
Group Id: [11] Rec: 81 Len: 2 ...... Ok 1
Group Id: [11] Rec: 82 Len: 2 ...... Ok 1
Group Id: [11] Rec: 83 Len: 2 ...... Ok 1
Group Id: [11] Rec: 84 Len: 2 ...... Ok 1
Group Id: [11] Rec: 85 Len: 2 ...... Ok 1
Group Id: [11] Rec: 86 Len: 2 ...... Ok 1
Group Id: [11] Rec: 87 Len: 2 ...... Ok 1
Group Id: [11] Rec: 88 Len: 2 ...... Ok 1
Group Id: [11] Rec: 89 Len: 2 ...... Ok 1
Group Id: [11] Rec: 90 Len: 2 ...... Ok 1
Group Id: [11] Rec: 91 Len: 2 ...... Ok 1
Group Id: [11] Rec: 92 Len: 2 ...... Ok 1
Group Id: [11] Rec: 93 Len: 2 ...... Ok 1
Group Id: [11] Rec: 94 Len: 2 ...... Ok 1
Group Id: [11] Rec: 95 Len: 2 ...... Ok 1
Group Id: [11] Rec: 96 Len: 2 ...... Ok 1
Group Id: [11] Rec: 97 Len: 2 ...... Ok 1
Group Id: [11] Rec: 98 Len: 2 ...... Ok 1
Group Id: [11] Rec: 99 Len: 2 ...... Ok 1
Group Id: [11] Rec: 100 Len: 2 ...... Ok 1
Group Id: [11] Rec: 101 Len: 2 ...... Ok 1
Group Id: [11] Rec: 102 Len: 2 ...... Ok 1
Group Id: [11] Rec: 103 Len: 2 ...... Ok 1
Group Id: [11] Rec: 104 Len: 2 ...... Ok 1
Group Id: [11] Rec: 105 Len: 2 ...... Ok 1
Group Id: [11] Rec: 106 Len: 2 ...... Ok 1
Group Id: [11] Rec: 107 Len: 2 ...... Ok 1
Group Id: [11] Rec: 108 Len: 4 ...... Ok 1
Group Id: [11] Rec: 109 Len: 4 ...... Ok 1
Group Id: [11] Rec: 110 Len: 1 ...... Ok 1
Group Id: [11] Rec: 111 Len: 4 ...... Ok 1
Group Id: [11] Rec: 112 Len: 4 ...... Ok 1
Group Id: [11] Rec: 113 Len: 4 ...... Ok 1
Group Id: [11] Rec: 114 Len: 4 ...... Ok 1
Group Id: [11] Rec: 115 Len: 16 ..... Ok 1
Group Id: [11] Rec: 116 Len: 4 ...... Ok 1
Group Id: [11] Rec: 117 Len: 2 ...... Ok 1
Group Id: [11] Rec: 118 Len: 2 ...... Ok 1
Group Id: [11] Rec: 119 Len: 857 .... Ok 8
Group Id: [17] Rec: 0 Len: 4 ...... Ok 1
Group Id: [25] Rec: 0 Len: 64 ..... Ok 1
Group Id: [26] Rec: 0 Len: 16 ..... Ok 1
Group Id: [26] Rec: 1 Len: 32 ..... Ok 1
Group Id: [26] Rec: 2 Len: 68 ..... Ok 1
Group Id: [26] Rec: 3 Len: 6 ...... Ok 1
Group Id: [27] Rec: 0 Len: 15 ..... Ok 1
Group Id: [29] Rec: 0 Len: 6 ...... Ok 1
Group Id: [35] Rec: 0 Len: 10 ..... Ok 1
Group Id: [43] Rec: 5 Len: 4 ...... Ok 1
Group Id: [44] Rec: 0 Len: 1 ...... Ok 1
Group Id: [50] Rec: 0 Len: 2 ...... Ok 1
Group Id: [54] Rec: 0 Len: 2 ...... Ok 1
Group Id: [54] Rec: 2 Len: 24 ..... Ok 1
Group Id: [88] Rec: 0 Len: 36 ..... Ok 1
Group Id: [92] Rec: 0 Len: 16 ..... Ok 1
Group Id: [94] Rec: 0 Len: 40 ..... Ok 1
Group Id: [95] Rec: 0 Len: 1 ...... Ok 1
Group Id: [95] Rec: 1 Len: 1 ...... Ok 1
Group Id: [96] Rec: 0 Len: 24 ..... Ok 1
Group Id:[117] Rec: 0 Len: 4 ...... Ok 1
Group Id:[117] Rec: 1 Len: 3 ...... Ok 1
Group Id:[117] Rec: 2 Len: 6 ...... Ok 1
Group Id:[117] Rec: 3 Len: 1 ...... Ok 1
Group Id:[117] Rec: 4 Len: 9 ...... Ok 1
Group Id:[117] Rec: 5 Len: 10 ..... Ok 1
Group Id:[117] Rec: 6 Len: 8 ...... Ok 1
Group Id:[117] Rec: 8 Len: 42 ..... Ok 1
Group Id:[117] Rec: 13 Len: 3 ...... Ok 1
Group Id:[117] Rec: 14 Len: 3 ...... Ok 1
Group Id:[118] Rec: 0 Len: 1 ...... Ok 1
Group Id:[193] Rec: 2 Len: 8 ...... Ok 1
Group Id:[193] Rec: 3 Len: 32 ..... Ok 1
Group Id:[193] Rec: 4 Len: 32 ..... Ok 1
Group Id:[193] Rec: 7 Len: 1 ...... Ok 1
Group Id:[212] Rec: 0 Len: 2 ...... Ok 1
Group Id:[217] Rec: 0 Len: 32 ..... Ok 1
Group Id:[239] Rec: 0 Len: 2 ...... Ok 1
Group Id:[246] Rec: 0 Len: 130 .... Ok 2
Group Id:[246] Rec: 2 Len: 114 .... Ok 2
Group Id:[246] Rec: 3 Len: 234 .... Ok 3
Group Id:[246] Rec: 4 Len: 162 .... Ok 2
Group Id:[247] Rec: 0 Len: 70 ..... Ok 1
Group Id:[248] Rec: 0 Len: 120 .... Ok 2
Group Id:[249] Rec: 0 Len: 4 ...... Ok 1
Group Id:[249] Rec: 1 Len: 4 ...... Ok 1
Group Id:[249] Rec: 4 Len: 42 ..... Ok 1
Group Id:[307] Rec: 0 Len: 1 ...... Ok 1
Group Id:[308] Rec: 0 Len: 1 ...... Ok 1
Group Id:[308] Rec: 3 Len: 1 ...... Ok 1
Group Id:[308] Rec: 4 Len: 1 ...... Ok 1
Group Id:[309] Rec: 0 Len: 4 ...... Ok 1
Group Id:[309] Rec: 1 Len: 2 ...... Ok 1
Group Id:[309] Rec: 2 Len: 12 ..... Ok 1
Group Id:[309] Rec: 4 Len: 12 ..... Ok 1
Group Id:[309] Rec: 5 Len: 12 ..... Ok 1
Group Id:[309] Rec: 7 Len: 12 ..... Ok 1
Group Id:[309] Rec: 8 Len: 12 ..... Ok 1
Group Id:[309] Rec: 17 Len: 12 ..... Ok 1
Write PM Done, Time: 00:17
Old 12-02-2009, 03:52   #5 (permalink)
Member: 422015
Thanks Meter: 64
hi,
Flash with a newest firmware and do write crt backup
br
Old 12-02-2009, 03:55   #6 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
dont erase
just flash it with (israelian language)
The Following User Says Thank You to ahmad yousif For This Useful Post:
Old 12-02-2009, 04:00   #7 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
dont erase
your write .............
Old 12-02-2009, 05:37   #8 (permalink)
Member: 839770
Thanks Meter: 24
Originally Posted by dhiet View Post
hi,
br
What i have done is using the latest firmware, RM36_5.050440_B5.C0R, are there any newest one?
Old 12-02-2009, 06:51   #9 (permalink)
Member: 839770
Thanks Meter: 24
Originally Posted by ahmad yousif View Post
dont erase
Thank's bro, it works with Hebrew language. After flashing and ui setting successfully do not forget to write good pm, CASE CLOSED. Br.dino
The Following User Says Thank You to dinoadropy For This Useful Post:
Old 12-02-2009, 07:00   #10 (permalink)
Member: 437090
Thanks Meter: 131
try to flash it with higher version... hope it helps with your problem
br.
Old 12-02-2009, 07:12   #11 (permalink)
nmbaiju's Avatar
Member: 246200
Thanks Meter: 104
try to manuval formating'''''''''
baiju
Old 12-02-2009, 08:08   #12 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 846
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Boot OK
APE VPP : Internal
DUAL LINE : True
APE ALG Boot OK
Rebooting Mobile
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Boot OK
APE VPP : Internal
DUAL LINE : True
APE ALG Boot OK
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000341
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Boot OK
APE VPP : Internal
DUAL LINE : True
APE ALG Boot OK
i think it's hardware problem plz try it
Old 12-02-2009, 08:31   #13 (permalink)
.::intel32::.'s Avatar
Member: 350719
Sonork: 100.1623850
Thanks Meter: 157
hi my bro.
please try to downgrade with this version.5.050407.
solve your problem 100%.
Old 12-03-2009, 09:15   #14 (permalink)
Member: 137670
Thanks Meter: 12
problem already solved!
The Following User Says Thank You to may_power For This Useful Post:
Old 06-24-2010, 10:13   #15 (permalink)
Member: 4123
Thanks Meter: 27
I have same problem
How can I solve this problem,.I flash my phone with 5_050440....
N 6630 Flashing Ok But Not Boot Only White Screen umesh garg MT-BOX 5 10-12-2011 07:21
nokia 6680 charging ok but no power on tuban_gsm Nokia Hardware & Hardware Repair 3 02-02-2010 06:18
6680 Flash Ok But Not Power On /ARIF/ Nokia Base Band 5 ( BB-5 ) 8 12-19-2007 15:49
6680 flashing ok but not bowering on m_slahe Nokia Hardware & Hardware Repair 5 08-22-2007 19:29
Page generated in 0.31053 seconds with 10 queries
