Help Me To Unlock SE Z520a Hi I have Sony Ericsson Z520a when i try to unlock it i choose in Model Z520 and K750 is same thing this is the log: Please Help me McuId: 80400301FFFFFF, CID: 36, 4 (Red) Mcert: A1_DB2010_36_RED Baud Rate: 921600 Trying: CXC1326738_000000_0002_R2AB{0102030401}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB, Ok Trying: CXC1326739_R2K{0101030301}.bin PayLoader Certificate Accepted 041101 1458 NPACXC1326739_COMPACTCERTLOADER R2K PayLoader Ok IMEI : 357198-00-429476-0, CID: 36, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT App2: 06 Loader Fail: App2 Security Initialization Failed, Time: 00:06 All Done, Total Time: 00:22 |
no,you can;t unlock this new software because along time no new update on new Z520,,,try on USB-SMART,,,use read all codes good luck |
use sonic cracked software with 5in 1cruiser cable 100% tested |
I able to unlock a Z520a with HWK as an experiment and it was successful, as follows: 1. Connect phone then 'go' to boot, u can see if it RED or BROWN. (since your phone is RED, you can try what I did because mine was RED, also Im working on another one which is BROWN but post result later if success) 2. Click 'flash Mcu' to flash MCU only (with Z520 flash files from www.ufsxhwk.com) 3. Click 'Init Sb' to unlock. (check at this stage, insert sim and test otherwise continue to 4.) 4. Click 'Restore' (when completed, insert and try). If failed, redo all from 1. to 4. If failed, say a prayer. Note: Experts may know better, but my little experiment or playing I did able to unlock my Z520a phones (RED). Im working on BROWNs and see what gonna happen. cheers. |
sir, i got no access at ufshwk.... can you pls upload the flash file??? badly needed sir..... thanks.... |
@Jhay-r PM me your email address, so that I can send file to. cheers. |
