Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 01-08-2013, 15:27   #1 (permalink)
Member: 1127127
Sonork: etmos
Thanks Meter: 2
Hwk-nokia 100, rh130 unlocking not supported
Help me unlock nokia 100- rh130, simlock invalid
Old 01-08-2013, 15:54   #2 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
This phone does not support any one box --for direct unlock
for bruteforce only 15 Digit NCK
20 Digit NCK not support
Old 01-08-2013, 16:31   #3 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,670
Check imei if damage,write pm backup
The Following User Says Thank You to jawedakht For This Useful Post:
Old 01-21-2013, 19:01   #4 (permalink)
XFM
Member: 1871879
Thanks Meter: 2
Can anyone unlock this?
MODEL: NOKIA 100
TYPE: RH-130
CODE: 059N4C2
IMEI: 351941/05/669039/9
Locked to Tesco Ireland
TIA
Old 01-21-2013, 19:07   #5 (permalink)
Registered User
Member: 211475
Thanks Meter: 11
Yes!!!
Just be patient...
The Following User Says Thank You to alo-alo For This Useful Post:
Old 01-21-2013, 19:17   #6 (permalink)
XFM
Member: 1871879
Thanks Meter: 2
Originally Posted by alo-alo View Post
Yes!!!
Just be patient...
Excellent! Thank you!
I can't get the phone to ask for a code. I've tried inserting another SIM. The phone just tells me to "Insert SIM"
Old 01-21-2013, 19:57   #7 (permalink)
Member: 1591394
Thanks Meter: 552
insert hammer! it will solve your problem !
The Following User Says Thank You to kikas112 For This Useful Post:
Old 01-21-2013, 20:19   #8 (permalink)
Member: 1591394
Thanks Meter: 552
just wait for Odia the ultimate he will give you right Code fo free or PM him
B.R
Old 01-22-2013, 10:16   #9 (permalink)
Member: 24115
Thanks Meter: 46
Originally Posted by XFM View Post
...the phone just tells me to "Insert SIM"
This is hardware problem
The Following User Says Thank You to milenjs For This Useful Post:
Old 01-22-2013, 14:29   #10 (permalink)
XFM
Member: 1871879
Thanks Meter: 2
I think I'm just doing it wrong. I put a data SIM card into another unlocked phone. It said the same thing - "Insert SIM".
Putting another provider's card into a locked phone brings up a prompt for the unlock code, right?
Do some phones need a code while the right card is in, like *#91#* or something?
Thanks!
Old 01-22-2013, 17:12   #11 (permalink)
satch1234's Avatar
Member: 1005489
Thanks Meter: 105
Thanks!
"Insert sim" in your case means that sim card is damaged because it is not working in another phone also,so just replace it.
When you insert good working sim card you should see "phone restricted" or in some other phones "insert correct sim card".
The Following User Says Thank You to satch1234 For This Useful Post:
Old 01-22-2013, 19:08   #12 (permalink)
XFM
Member: 1871879
Thanks Meter: 2
That's not quite what happened, but I did a bad job explaining.
Your solution was spot-on, though. With another card it says, "SIM not valid" and a place to put an unlock code.
Thanks for the assist!
Old 01-23-2013, 14:18   #13 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
You can wait 10357319 secounds and it'll unlock itself
The Following User Says Thank You to piracik For This Useful Post:
Old 01-23-2013, 15:31   #14 (permalink)
XFM
Member: 1871879
Thanks Meter: 2
Has it not been that long already?
Old 01-24-2013, 14:03   #15 (permalink)
XFM
Member: 1871879
Thanks Meter: 2
B.R
Isn't It sort of a bad idea to PM the Board's Owner/Administrator for something like this?
Page generated in 0.24989 seconds with 8 queries
