Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-22-2008, 08:57   #1 (permalink)
jacob magembe's Avatar
Member: 184973
Thanks Meter: 27
Exclamation again 1200 ver:05.23 fail to unlock
Nokia 1200 ver.5.23 fails to unloc by hwk,the product is from india
Old 08-22-2008, 09:30   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Nokia 1200 v5.23 can be unlocked. Check your cable and try again.
Old 08-22-2008, 09:46   #3 (permalink)
Member: 757799
Thanks Meter: 782
some new 1200 and 1208 is hard to unlock..
hwk team. why?
Old 08-22-2008, 10:43   #4 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
dear,
wait for update from HWK team.
Old 08-25-2008, 15:05   #5 (permalink)
Member: 750650
Sonork: hajisadi
Thanks Meter: 8
i want to unlock 1200 which i bought it from malawi
but the problem is when i try to unlock it says failed aborting.its ver.5.23.
but check button and flash button its all functioned, but other buttons it said failed aborting
MCU ID: 0x2292
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
Powering the phone...
Failed! Aborting!
Old 10-14-2008, 16:05   #6 (permalink)
Member: 750735
Sonork: maningo
Thanks Meter: 9
mr this is a cable problem one day i got ten pic to unlock then i face same problem, when i try unlock 1200 it shows failed aborting. i change three cable but same broblem, but i got one cable which you dont believe, it unlock all ten pic without broblem.
Old 10-14-2008, 17:10   #7 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
MCU ID: 0x2292
Algo is ready...
Done!
Phone Restarted...
Failed! Aborting!
this is jaf log not hwk
Old 10-14-2008, 17:11   #8 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
unlocked without problem some thing is wrong in your cable
Old 12-05-2008, 20:39   #9 (permalink)
Member: 76815
Thanks Meter: 7
where is the difference in these cables..........................I request to get cable schematics in case there is a difference....pliz....
Old 12-05-2008, 20:57   #10 (permalink)
Member: 76815
Thanks Meter: 7
if not the cable,I think its a problem with the new hardware on-board......the flash IC (INTEL) ,PLUS THE CPU.....SEEM EXTREMELY DIFFERENT FORM OLDER VERSIONS AND TO MAKE THINGS WORSE,POWER OVERSTAYS IN THE CIRCUIT AFTER DISCONNECTING CABLE.........THIS FAILS PHONE TO SWITCH AUTOMATICALLY FROM FLASH MODE BACK TO LOCAL/TEST MODE IN APROPRIATE TIME AS STEPS DO REQUIRE TO UNLOCK A PHONE BY PATCHING..
again fail to unlock samsung qualcom [ANSWERED] luinaranjo PolarBox 3 11 09-29-2010 06:13
1200 RH 100 5.32 failed to unlock. desbloqueocelgd Cyclonebox 5 05-25-2009 14:58
Failed to unlock 5310x even after Activating BB5SL2 again. mgtsales Universalbox 7 05-06-2009 16:46
nokia 1200 - now costing credits to unlock??? koolphones Universalbox 5 08-29-2008 22:32
Page generated in 0.34254 seconds with 9 queries
