lg boot problem how to boot or flash lg mobiles give proper mothed with details i try many time but cannot boot change cable and change mobile but same please help here is log If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! this error show in all mobile |
1. Insert Charged batery 2. Use good cable according to phone... 3. Now Press Boot in software 4. If not booting press Power button shortly again and again... thats it.... |
@syed tuqeer which models you try ? and which cables ? |
thanks for reply i also change cable many time and mobile but same |
Mate when you select KG110 you can see in front of tab 18 pin cable or 24 pin cable. make sure you have both working cable for kG110 you have to use 18 pin cable which is simply LG 8110 Cable. 1. select model 2. connect with power of phone 3 press boot & Shortly press power on Button 4. press Unlock 5. GOOD LUCK:) |
i think it is 100 % cable problum |
schematics can find on support |
Cheqthis method b.r use this method 1. Insert Charged batery 2. Use good cable according to phone... 3. Now Press Boot in software 4. If not booting press Power button shortly again and again... here is proof unlocking KG130 http://forum.gsmhosting.com/vbb/show...94#post4231194 CHEQ IT THIS LINKS I HOPE U R CABLE IS PROBLEM 100% CHANGE CABLE OR MODIFY CABLE AND TRY AGAIN U R PROBLEM SOLVED SAQIB-:eek::eek::eek: |
@syed tuqeer Framing errors can be Because, need look here: UFS_High_Bauds_Problem_Solution.zip on Support Area.!! Munna. |
