09-19-2013, 07:23 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: 03218554185 Age: 43
Member: 243881 Status: Offline Thanks Meter: 68 | E2120 blinking solution 100% E2120CBIH1.cla E2120CBIH1.tfs Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flsloader Ok FLASH Id: SEC, K5N5629ATA [NOR 256Mb] Bad Resp: 1FF1 at: 0x10070000 MCU Read Failed, at: 0x00070000 Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flsloader Ok FLASH Id: SEC, K5N5629ATA [NOR 256Mb] Bad Resp: 1FF7 at: 0x1058C000 MCU Read Failed, at: 0x0058C000 MCU File: E2120CBIH1.cla CRC32: 459986EE Regions : Poland Language: cs,de,en,fr,hu,it,pl,sl(ru) Release : 2009 August Rev: 1 TFS File: E2120CBIH1.tfs CRC32: 0F16B5EE CFG File: E2120CBIH1.cfg 15457 byte(s) MCU File: E2120CBIH1.cla CRC32: 459986EE TFS File: E2120CBIH1.tfs CRC32: 0F16B5EE CFG File: E2120CBIH1.cfg 15457 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flsloader Ok FLASH Id: SEC, K5N5629ATA [NOR 256Mb] Erase Done, 120 sector(s), Time: 00:41 MCU MSL Patched Ok, Time: 00:08 File CRC: 0x79BA3134 MCU Write Done, 15625408 byte(s), Time: 05:55 File CRC: 0x0F16B5EE TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 78 Max_Files : 176 Files_Count: 176/176 Files Closed TFS Unmounted TFS Write Done, 3428750 byte(s), Time: 01:16 than Rebuild imei Connect Cable to Switched Off Mobile (with battery) MSL Deactivated Old IMEI: 351664-04-344958-6 New IMEI: 351664-04-344958-6 IMEI Rebuild Done E2120 blinking solution 100% |
The Following User Says Thank You to imdad-ia For This Useful Post: |
