12-29-2009, 04:21 | #1 (permalink) |
Registered User Join Date: Nov 2007 Location: Marianas Trench
Member: 632643 Status: Offline Thanks Meter: 74 | kp110 restart problem but phone still restart.... any suggestions? logs If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 01 21 00 [SPANSION] 0E BaudRate Set to: 921600 IMEI: 352008-02-138069-3 Read [01000000-017FFFFF] Done, 01:58 Code Image Saved as KP110_CODE_all data.bif Read [18000000-187FFFFF] Done, 01:58 Alchemy Image Saved as KP110_ALCH_.bif Aux Data, not Defined Region File: KP110AT-00-V10a-410-XX-JAN-13-2009 CodeData.bif Write [01000000-017CFDEB] Done, 04:23 File: KP110AT-00-V10a-410-XX-JAN-13-2009 AlchemyData.mot MOT Format File, Converting to BIF Region: 1, 0x18000000-0x185A8C1F, Length: 5934112 bytes Processed: 370882 record(s) Saved as KP110AT-00-V10a-410-XX-JAN-13-2009 AlchemyData.bif Write [18000000-185A8C1F] Done, 03:04 Read [01000000-01007FFF] Done, 00:00 Cal. Data Saved as KP110_CAL_352008-02-138069-3_12292009_111905.bif Unlock Done, 00:01 ShutDown Done, Wait for Product Start-Up ! Communications error, check cable, switch-on product ! |
E2130 restart problem.... | aikonmani | SWIFT Platform | 11 | 10-24-2012 07:49 |
>>> LG KP110 Restart Solved <<< | zeel_zeel | Infinity-Box | 20 | 06-20-2010 14:44 |
LG Kp110 restart solution with hwk | .:::Dr. Cell:::. | LG | 5 | 04-17-2010 09:13 |
LG KP110 Hang Problem Solved | zeerik | Infinity-Box | 1 | 05-26-2009 16:33 |
6270 startup restarting problem help big problem | vinay_sharma | Nokia Hardware & Hardware Repair | 5 | 07-07-2007 22:06 |
