04-03-2010, 18:05 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 72 | U600B flash problem i try with diferent FW but same problem Code: Region: 1, 0x20000000-0x20000007, Length: 8 bytes Region: 2, 0x20010000-0x20014A3F, Length: 19008 bytes Region: 3, 0x20020000-0x2002DD93, Length: 56724 bytes Region: 4, 0x20040000-0x200404E3, Length: 1252 bytes Region: 5, 0x20042000-0x20196DF3, Length: 1396212 bytes Region: 6, 0x201B0000-0x21A0D117, Length: 25547032 bytes Region: 7, 0x21BB0000-0x21EEC343, Length: 3392324 bytes Region: 8, 0x21F10000-0x21F15F2C, Length: 24365 bytes Region: 9, 0x28000000-0x2987EFFB, Length: 25686012 bytes 1st Boot Ok, McuId: 000200A3, Rom: 000200A3, 6-1.1 (Trident HPE) 2nd Boot Ok, McuId: 000200A3, Rom: 000200A3, 4-1.1 Fll Boot Ok, Vers: 5.13, fl_sceptrehp_sgh_hw1_v24_s07_m01.sre Flash1: Fl_Id: 00EC0000_22FD0000 - Samsung KBJ17KC00M-B Flash2: Fl_Id: 00EC0000_00340000 - Samsung KBH1xPE00M-N 1G Baud Rate Set: 460800 bps Flashing NOR part... Flashing NAND part... ErOpen: [ERROR] EraseSectorNAND : nRet=0x80110000#8msg.rplyOPEN-err Write Failed at: 0x28000000 |
04-04-2010, 17:55 | #4 (permalink) |
Member: 78657 Status: Offline Thanks Meter: 72 | same problem with low speed Code: Region: 1, 0x20000000-0x20000007, Length: 8 bytes Region: 2, 0x20010000-0x20014A3F, Length: 19008 bytes Region: 3, 0x20020000-0x2002DD93, Length: 56724 bytes Region: 4, 0x20040000-0x200404E3, Length: 1252 bytes Region: 5, 0x20042000-0x20196DF3, Length: 1396212 bytes Region: 6, 0x201B0000-0x21A0D117, Length: 25547032 bytes Region: 7, 0x21BB0000-0x21EEC343, Length: 3392324 bytes Region: 8, 0x21F10000-0x21F15F2C, Length: 24365 bytes Region: 9, 0x28000000-0x2987EFFB, Length: 25686012 bytes 1st Boot Ok, McuId: 000200A3, Rom: 000200A3, 6-1.1 (Trident HPE) 2nd Boot Ok, McuId: 000200A3, Rom: 000200A3, 4-1.1 Fll Boot Ok, Vers: 5.13, fl_sceptrehp_sgh_hw1_v24_s07_m01_1.sre Flash1: Fl_Id: 00EC0000_22FD0000 - Samsung KBJ17KC00M-B Flash2: Fl_Id: 00EC0000_00340000 - Samsung KBH1xPE00M-N 1G Baud Rate Set: 230400 bps Flashing NOR part... Flashing NAND part... ErTxdt: 0 - rplyTXDT+!eom. Write Failed at: 0x28734000 |
04-04-2010, 18:21 | #7 (permalink) | |
Freak Poster Join Date: May 2004 Location: Kabul - Afghanistan Age: 52
Member: 65945 Status: Offline Sonork: 100.1606747 Thanks Meter: 15 | Quote:
was ur mobile on before flashing or it was in dead position or hang problem on restart......for what purpose r u flashing ur mobile ? | |
04-04-2010, 20:16 | #8 (permalink) |
Member: 78657 Status: Offline Thanks Meter: 72 | problem solved thanks for all. problem solved when use 115200 bps speed Code: Region: 1, 0x20000000-0x20000007, Length: 8 bytes Region: 2, 0x20010000-0x20014A3F, Length: 19008 bytes Region: 3, 0x20020000-0x2002DD93, Length: 56724 bytes Region: 4, 0x20040000-0x200404E3, Length: 1252 bytes Region: 5, 0x20042000-0x20196DF3, Length: 1396212 bytes Region: 6, 0x201B0000-0x21A0D117, Length: 25547032 bytes Region: 7, 0x21BB0000-0x21EEC343, Length: 3392324 bytes Region: 8, 0x21F10000-0x21F15F2C, Length: 24365 bytes Region: 9, 0x28000000-0x2987EFFB, Length: 25686012 bytes 1st Boot Ok, McuId: 000200A3, Rom: 000200A3, 6-1.1 (Trident HPE) 2nd Boot Ok, McuId: 000200A3, Rom: 000200A3, 4-1.1 Fll Boot Ok, Vers: 5.13, fl_sceptrehp_sgh_hw1_v24_s07_m01_1.sre Flash1: Fl_Id: 00EC0000_22FD0000 - Samsung KBJ17KC00M-B Flash2: Fl_Id: 00EC0000_00340000 - Samsung KBH1xPE00M-N 1G Baud Rate Set: 115200 bps Flashing NOR part... Flashing NAND part... Write Done, 56123017 byte(s), Time: 32:38 FS Formated (TFS) FS Mounted (TFS) Files Count: 11 Writing File: /a/Def/Paul Simon-The Russian Futurists.mp3, 5561493 byte(s) Writing File: /a/Def/SamsungFunClub.3gp, 1080092 byte(s) Writing File: /a/Def/MMSTemplate_01.mms, 76710 byte(s) Writing File: /a/Def/MMSTemplate_02.mms, 70923 byte(s) Writing File: /a/Def/MMSTemplate_03.mms, 71243 byte(s) Writing File: /a/Def/MMSTemplate_04.mms, 70767 byte(s) Writing File: /a/Def/MMSTemplate_05.mms, 54842 byte(s) Writing File: /a/Java/0000.jad, 322 byte(s) Writing File: /a/Java/0000.jar, 153002 byte(s) Writing File: /a/Java/0001.jad, 293 byte(s) Writing File: /a/Java/0001.jar, 271782 byte(s) FS Unmounted FS Write Done, 7414441 byte(s), Time: 11:13 |
The Following User Says Thank You to bilm25 For This Useful Post: |
u600b lcd problem | timberland2 | Samsung Hardware Repair | 8 | 03-31-2010 09:08 |
U600B lcd problem | daffy duck | Samsung Hardware Repair | 1 | 08-06-2009 10:23 |
Ust pro ii-- samsung u600b unlock problem | MANfaith | UST Pro II | 3 | 05-11-2009 08:00 |
u600 ? u600b ? flashin problem | Kiano | UST Pro II | 25 | 12-10-2008 10:25 |
U600b big problem | Moursi | NSPRO | 1 | 11-25-2008 08:58 |
