Nokia 6300; ERR: CMT 2ND Boot CERT Mismatch 1ST BOOT : C0,07 [Rm-217] [2.2.0.3] CMT ASICID: 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 CMT PUBID : 06200201C7798C5649E6E045AFA499F91DBB258A CMT MODE : 00 CMT HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROMID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 00000000: 02 00 00 00 00 F1 72 ......r ERR: CMT 2ND Boot CERT Mismatch Rebooting Mobile when i click "Check" how to solved this? phone condition is Show fight mode then off:o |
chance cable flash again................. |
check may b 1 pinout break |
reboll flash chip i hope ur proublum solve |
Reheat Flash I.C then Flash 100% TESTED Post Result |
select model first and add firmware in right selections...(MCU,PPM,CNT) accordance with the product code of the phone or use ini setting, then press check again... |
Then Post Result ..! |
HWK CMT BOOT ERROR 100% SOLUTION http://i39.tinypic.com/fe3x1x.jpg http://i42.tinypic.com/11u95xx.jpg |
1ST BOOT : C0,07 [Rm-495] [2.2.0.3] CMT ASICID: 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 08600018AFBA8E565844E85B70A39F4B5C302F1A CMT MODE : 00 CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROMID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2400-00008A31, Sam K8x1259ETF CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 0C917F11196FDB7378C18EF7260698CA4489DCA0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK Chip SECTOR_SIZE: 128k Warning, Must be Used 128Kb Sector_Size CNT File CONVERSION: Already 128K Paged Source IMAGE : rm495__07.97_v2.image_mi_red CMT NOR Erase Area: 0x01DC0000-0215FFFF CMT NOR Erase Area: 0x02160000-03FBFFFF CNT FLASH ERASE OK, Time: 00:19 DATA_BLK_ERROR at: 0x022E0000, 00 ERR: CNT FLASH WRITE D_BLK 000000000000000410000000B172, LN: 0x004000, Time: 00:09 Process Failed, Repowering Mobile |
hardwer problem........ |
NO, in this case my problem is F-Bus cable thanks ........... |
1. Maybe IC Flash Bad 2. check the voltage source to flash IC. Vpp (1,8v),Vdram (1,8v) and Vio (1,8) in |
