Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 10-24-2009, 08:39   #1 (permalink)
gagan_o5's Avatar
Member: 602830
Thanks Meter: 283
Arrow 5130 c-2 contact service help me ???
5130 c-2 contact service here is log :
MCU SW : V 06.93 20-05-09 RM-495 (c) Nokia
PPM SW : V 06.93 20-05-09 RM-495 (c) Nokia MH
Prd.Code: 0577793
Bpr.Code: 0567772
Prod.Sn : IIO549485
HW Vers : 2000
EM VILMA: 16
EM BETTY: 22
RFIC Ver: 06540601
DSP Vers: ICPR72_09w04
LCD Type: SEIKO
IMEI : 359329-02-xxxxxx
SL Serv : SIMLOCK SERVER
SL Conf : 000-00-00000000000
SL Prof : 0141191F00000000
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
Old 10-24-2009, 08:50   #2 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
Prd.Code: 0577793
Bpr.Code: 0567772
Prod.Sn : IIO549485
HW Vers : 2000
EM VILMA: 16
EM BETTY: 22
RFIC Ver: 06540601
LCD Type: SEIKO
SL Count: 00 00
SL Data Corrupted
Provider: Not Found
just RPL solved this
dont try any other solution Because you lost your time.
lahdache
The Following User Says Thank You to lahdache For This Useful Post:
Old 10-25-2009, 18:28   #3 (permalink)
NokiaMobileCare's Avatar
Member: 652870
Thanks Meter: 136
only rpl is solution . otherwise try Universal box for repair sl data . after tht ur imei still 123456
thn also u hav 2 write rpl.
Old 10-26-2009, 07:42   #4 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
You Need ask2rpl to solve ur problem
Old 10-26-2009, 07:45   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
this issue is solve only write rpl your problem solve 100%
Old 10-28-2009, 16:28   #6 (permalink)
Member: 670719
Thanks Meter: 3
thanksssssssssssssssssssssssssssssssssssssssssssss s
Old 01-30-2010, 10:11   #7 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
hone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 35417903158495-0
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Old 01-30-2010, 10:12   #8 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
howcan solve this brathers tell me i think hi is sim data repair only
Old 01-30-2010, 10:13   #9 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
genie universal clip solve his
Old 01-30-2010, 10:20   #10 (permalink)
agadir5241's Avatar
Member: 771019
Thanks Meter: 27
there is no solution at moment with hwk. u can try other tool
Old 01-30-2010, 11:22   #11 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
Language Pack:
- not available.
SIMLOCK invalid!
1:Don't Forget this is HWK section . your logfile is created with another device
2: Get RPL and write with your device is only solution
3: For more don't make more post just use search button U will find too much about your Problum
Old 01-30-2010, 12:54   #12 (permalink)
Member: 1116719
Thanks Meter: 542
see hare http://forum.gsmhosting.com/vbb/showthread.php?t=906384
The Following User Says Thank You to >>.123.<< For This Useful Post:
Old 01-30-2010, 13:54   #13 (permalink)
Member: 1116719
Thanks Meter: 542
http://forum.gsmhosting.com/vbb/show...15#post5341515
nokia 5130 sl3 contact service 100% ok in mx key
Old 01-30-2010, 14:13   #14 (permalink)
Member: 36715
Thanks Meter: 22
incase if you havent noticed he has super dongle invalid, the only solution is with credits or rpl
The Following User Says Thank You to jacob For This Useful Post:
nokia 5130 contact service help me shafi816 Nokia Base Band 5 ( BB-5 ) 11 03-25-2010 09:41
5130c-2 contact service,,help me bluetut MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-03-2010 11:07
5130 contact service help me mdmosheur MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-13-2010 14:33
5130 contact service help me thethi MT-BOX 17 12-26-2009 19:31
Page generated in 0.21042 seconds with 9 queries
