Nokia E5-00 vibrate only after flash see the flash log Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 60,07 [Rm-632] [2.2.0.0] CMT ASICID: 000000030000022600010007600C192102031104 EM 1 ID : 00000C35 EM 2 ID : 00000C30 CMT PUBID : 21D000121BD60344F129B817CCAD37BD92413363 CMT MODE : 00 CMT HASH : 916F75217F32081248B15C38DFC8E81B CMT ROMID : E693EF0DAC22615B CMT 2ND Bt: RAPUv11_2nd.fg, Ver: 11.16.0 CMT 2ND Bt: SILO OK CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00200050-00000031, St OneNAND-4G CMT FLID1 : 00200050-00000031, St OneNAND-4G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : RAPUv11_XSR17_alg.fg, Ver: 11.16.0 CMT KSIG0 : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C CMT ALG Boot OK IMAGE : rm632_081.004_prd.core.fpsx CMT NAND Erase Area: 0x00020000-0003FFFF CMT NAND Erase Area: 0x00060000-004DFFFF CMT NAND Erase Area: 0x008E0000-0E77FFFF CMT NAND Partition Format CMT FLASH ERASE OK, Time: 00:02 Written: 10 Certificate(s) CMT FLASH WRITE OK, Time: 00:00 IMAGE : rm632_081.004_U005.000_prd.uda.fpsx CMT NAND Erase Area: 0x0E780000-1F13FFFF CNT FLASH ERASE OK, Time: 00:02 CNT FLASH WRITE OK, Time: 00:06 IMAGE : rm632_081.004_34.01_APAC_QW2_prd.rofs2.fpsx CMT NAND Erase Area: 0x08980000-0D0FFFFF PPM FLASH ERASE OK, Time: 00:00 Written: 1 Certificate(s) PPM FLASH WRITE OK, Time: 00:09 IMAGE : rm632_081.004_C00.01_DEFAULT_prd.rofs3.fpsx CMT NAND Erase Area: 0x0D100000-0E77FFFF CUS FLASH ERASE OK, Time: 00:00 Written: 1 Certificate(s) CUS FLASH WRITE OK, Time: 00:01 Flashing Completed, Rebooting Mobile after flash phone only vibrates..... |
ERR: CMT 2ND Boot File not Found can anyone help to understand what this error is??? ERR: CMT 2ND Boot File not Found it apears every time i try to read or unlock a BB5 with the tornado box! what file is this??? |
ERR: CMT 2ND Boot File not Found please help 1 Attachment(s) when i try to read gives me this !! when i try to unlock is ERR: CMT 2ND Boot File not Found |
Try flash with same product code if not flash with latest version. |
use a good eno file then post here result |
E5-00 flashing Hello flash via USB cable |
please help me sir.i have same problem.after full flash phone will be vibrate only......................... |
Try Flash Phone by F-BUS Cable With Last Version |
i tried both cable and usb but flashed fully, then vibrates. any solution? |
flash with 91.1 may ur problem solved |
flah with latest fileeeeeeeeeeeeee |
first erase full flash then wright latest flash files |
whr is flash file $ nokia E5 RM-632 code - 059H9K4 |
But friends there are sometimes, "vibration only" comes from hardware. However it is wiser to upgrade the firmware first of all. If flashing goes fine & software program detects the phone after flashing in TEST MODE, but it is still only vibrates, you can check the LCD operating voltages (VAUX1 & VIO) on LCD socket. If u can not find any of these voltages at the LCD socket, it is time to check L2420(VAUX1 comes through this) & R2423 (VIO comes through this) http://i632.photobucket.com/albums/u...ps723a3f06.jpg Good Luck!! |
nokia E5 boot error how to solve. 1ST BOOT : C0,07 [Rm-632] [2.3.0.3] CMT ASICID: 000000030000022600010007600C192102031104 EM 1 ID : 00000C35 EM 2 ID : 00000C30 CMT PUBID : 15900101F0DE0344AE298DE3D22559E47BAD47E8 CMT MODE : 00 CMT HASH : 916F75217F32081248B15C38DFC8E81B CMT ROMID : E693EF0DAC22615B CMT 1ST Boot OK Cannot Find KEYS CERT BAD BOOT ERR: CMT 2ND Boot File not Found Rebooting Mobile |
