09-26-2008, 19:55 | #16 (permalink) |
Freak Poster Join Date: Sep 2006 Location: topcom.comunicaciones Age: 47
Member: 353737 Status: Offline Sonork: 100.1580139 Thanks Meter: 43 | please help me i cant upgrade my hwk then many try: Upgrade log: ---------- HWK Update Client v 2.0.8.0 ---------- ---------- HWK upgrade started:26/09/2008 13:44:52 ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 75xxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-85EDB44D01xxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs |
09-27-2008, 07:21 | #19 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | |
The Following 5 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
09-27-2008, 12:16 | #23 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | @shawgsm First reinstall main setup by Modify option and then simply replace files with Flash-Fix, no need to replace rapido11. |
09-27-2008, 12:37 | #25 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Uninstall main set up, restart pc, manually delete folder X:\Program Files\Nokia\Phoenix\Flash, Reinstall main set up and then to replace Flash_Fix. Post result. Cannot read your PM as it's not working since morning, if you want can meet me at yahoo messenger. |
09-27-2008, 13:58 | #27 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Just place this file- Good to know that your problem is solved. |
The Following 3 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
09-30-2008, 00:28 | #30 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 62
Member: 63042 Status: Offline Thanks Meter: 117 | I m confused now with all the correction needed for our 2.0.8, Yesterday i changed and tried flashing N81 by replacing the rapidov11_2nd first posted STICKY Thread HERE by odia and so far 2nd CMT boot error was solved but flashing was "Slow and not flawless " Now after returning the sticky thread the RAPIDOv11_2nd attachment was removed and now i read from this thread that we should use the whole "FLASH_FIX" posted by Passionate Boys and disregard the first RAPIDOv11_2nd? "you MUST use the entire flash_fix.zip." posted by Odia #28 Is my understanding right ? |
UPDATED ! ERR: CMT 2ND Boot CMT 2ND CERT Mismatch" with v2.0.8 Official Temp Solutio | hisham ny | HWK | 1 | 01-18-2009 04:11 |
I found problem again with v2.0.8.0 | andre128 | HWK | 4 | 12-02-2008 11:06 |
UPDATED ! ERR: CMT 2ND Boot CMT 2ND CERT Mismatch" with v2.0.8 Official Temp Solution | Odia The Ultimate | HWK | 0 | 09-25-2008 14:22 |
