Member: 481337
Thanks Meter: 6 | GDFS Read Quote:
McuId: 80400301FFFFFF, CID: 36, 98 (Brown)
Mcert: A1_DB2010_36_BROWN
Baud Rate: 921600
Trying: CXC1326738_000000_0002_R2AB{0102030401}.bin
PayLoader Certificate Rejected :00 46 32 09 7A
Trying: CXC1326738_041214_0816_R2U{0101030402}.bin
PayLoader Certificate Accepted
Prolgue Ok
PayLoader: 041214 0816 LLECXC1326738_COMPACTFLASHLOADER R2U, Ok
IMEI : xxxxxx-xx-xxxxxx-x, CID: 36, CDT: 1 0 1 (Red)
FlId0: 890D, Intel RD38F4050L0YT
Bad Resp Length 253 0689330601, 00000037FC45FFFF, Retrying
Bad Resp Length 261 0689330601, 000000E8FC45FFFF, Retrying
Found 0 Active Record(s) in Block 0x0000 [0x0000-0xFFFF]
Bad Resp Length 258 0689330601, 00000053F245FFFF, Retrying
Bad Resp Length 261 0689330601, 000000ECF245FFFF, Retrying
Bad Resp Length 262 0689330601, 00000000F345FFFF, Retrying
Found 0 Active Record(s) in Block 0x0001 [0x0000-0xFFFF]
Bad Resp Length 257 0689330601, 00000018F045FFFF, Retrying
Bad Resp Length 258 0689330601, 0000001FF045FFFF, Retrying
Bad Resp Length 258 0689330601, 00000035F045FFFF, Retrying
Bad Resp Length 257 0689330601, 000000C3F045FFFF, Retrying
Bad Resp Length 257 0689330601, 00000021F145FFFF, Retrying
Bad Resp Length 254 0689330601, 000000A4F145FFFF, Retrying
Bad Resp Length 260 0689330601, 000000B9F145FFFF, Retrying
Found 0 Active Record(s) in Block 0x0002 [0x0000-0xFFFF]
Bad Resp Length 257 0689330601, 00000006FE45FFFF, Retrying
Found 0 Active Record(s) in Block 0x0003 [0x0000-0xFFFF]
Bad Resp Length 257 0689330601, 000000B4F845FFFF, Retrying
Bad Resp Length 261 0689330601, 000000B9F845FFFF, Retrying
Bad Resp Length 261 0689330601, 00000024F945FFFF, Retrying
Bad Resp Length 253 0689330601, 00000084F945FFFF, Retrying
Bad Resp Length 262 0689330601, 000000C2F945FFFF, Retrying
Found 0 Active Record(s) in Block 0x0004 [0x0000-0xFFFF]
Bad Resp Length 255 0689330601, 00000045FA45FFFF, Retrying
Bad Resp Length 260 0689330601, 00000086FA45FFFF, Retrying
Bad Resp Length 262 0689330601, 0000009EFA45FFFF, Retrying
Bad Resp Length 256 0689330601, 000000A5FA45FFFF, Retrying
Bad Resp Length 258 0689330601, 00000010FB45FFFF, Retrying
Bad Resp Length 253 0689330601, 00000024FB45FFFF, Retrying
Bad Resp Length 260 0689330601, 0000002BFB45FFFF, Retrying
Bad Resp Length 261 0689330601, 00000085FB45FFFF, Retrying
Found 0 Active Record(s) in Block 0x0005 [0x0000-0xFFFF]
Bad Resp Length 259 0689330601, 000000EEF645FFFF, Retrying
Bad Resp Length 262 0689330601, 000000ADF745FFFF, Retrying
Found 0 Active Record(s) in Block 0x0006 [0x0000-0xFFFF]
Found 0 Active Record(s) in Block 0x0007 [0x0000-0xFFFF]
GDFS Read Done, Time: 02:15
| GDFS Write Quote:
Trying: CXC1326739_R2K{0101030301}.bin
041101 1458 NPACXC1326739_COMPACTCERTLOADER R2K
PayLoader Ok
OTP_F: 22426D6FF142D81B - Locked
OTP_U: 1480CA7005800AC1 - Locked
050503 2001 NPACXC1327364_COMPACT_SEMC_CS_LOADER__R3E
Customization Info Err_08.5: Bad Resp Hdr 06,
GDFS Write Failed, Time: 00:22
| MCU & Cu/FS Flash Quote:
Baud Rate: 921600
Prolgue Ok
PayLoader Ok
FlashImage: X_K750_CXC125953_EMEA4_R1N035.bin (36_RED)
PARS: 0x45400000, 0x00020000, 0, 00010000, 45400000, 10000
PARS: 0x45410000, 0x00020000, 1, 00010000, 45400000, 10000
PARS: 0x45420000, 0x00020000, 0, 00010000, 45420000, 10000
PARS: 0x45430000, 0x00020000, 1, 00010000, 45420000, 10000
PARS: 0x45440000, 0x00020000, 0, 00010000, 45440000, 10000
PARS: 0x45450000, 0x00020000, 1, 00010000, 45440000, 10000
PARS: 0x45460000, 0x00020000, 0, 00010000, 45460000, 10000
PARS: 0x45470000, 0x00020000, 1, 00010000, 45460000, 10000
PARS: 0x45480000, 0x00020000, 0, 00010000, 45480000, 10000
PARS: 0x45490000, 0x00020000, 1, 00010000, 45480000, 10000
PARS: 0x454A0000, 0x00020000, 0, 00010000, 454A0000, 10000
PARS: 0x454B0000, 0x00020000, 1, 00010000, 454A0000, 10000
PARS: 0x454C0000, 0x00020000, 0, 00010000, 454C0000, 10000
PARS: 0x454D0000, 0x00020000, 1, 00010000, 454C0000, 10000
PARS: 0x454E0000, 0x00020000, 0, 00010000, 454E0000, 10000
PARS: 0x454F0000, 0x00020000, 1, 00010000, 454E0000, 10000
PARS: 0x45500000, 0x00020000, 0, 00010000, 45500000, 10000
PARS: 0x45510000, 0x00020000, 1, 00010000, 45500000, 10000
PARS: 0x45520000, 0x00020000, 0, 00010000, 45520000, 10000
PARS: 0x45530000, 0x00020000, 1, 00010000, 45520000, 10000
PARS: 0x45540000, 0x00020000, 0, 00010000, 45540000, 10000
PARS: 0x45550000, 0x00020000, 1, 00010000, 45540000, 10000
PARS: 0x45560000, 0x00020000, 0, 00010000, 45560000, 10000
PARS: 0x45570000, 0x00020000, 1, 00010000, 45560000, 10000
PARS: 0x45580000, 0x00020000, 0, 00010000, 45580000, 10000
PARS: 0x45590000, 0x00020000, 1, 00010000, 45580000, 10000
PARS: 0x455A0000, 0x00020000, 0, 00010000, 455A0000, 10000
PARS: 0x455B0000, 0x00020000, 1, 00010000, 455A0000, 10000
PARS: 0x455C0000, 0x00020000, 0, 00010000, 455C0000, 10000
PARS: 0x455D0000, 0x00020000, 1, 00010000, 455C0000, 10000
PARS: 0x455E0000, 0x00020000, 0, 00010000, 455E0000, 10000
PARS: 0x455F0000, 0x00020000, 1, 00010000, 455E0000, 10000
PARS: 0x45600000, 0x00020000, 0, 00010000, 45600000, 10000
PARS: 0x45610000, 0x00020000, 1, 00010000, 45600000, 10000
PARS: 0x45620000, 0x00020000, 0, 00010000, 45620000, 10000
PARS: 0x45630000, 0x00020000, 1, 00010000, 45620000, 10000
PARS: 0x45640000, 0x00020000, 0, 00010000, 45640000, 10000
PARS: 0x45650000, 0x00020000, 1, 00010000, 45640000, 10000
PARS: 0x45660000, 0x00020000, 0, 00010000, 45660000, 10000
PARS: 0x45670000, 0x00020000, 1, 00010000, 45660000, 10000
PARS: 0x45680000, 0x00020000, 0, 00010000, 45680000, 10000
PARS: 0x45690000, 0x00020000, 1, 00010000, 45680000, 10000
PARS: 0x456A0000, 0x00020000, 0, 00010000, 456A0000, 10000
PARS: 0x456B0000, 0x00020000, 1, 00010000, 456A0000, 10000
PARS: 0x456C0000, 0x00020000, 0, 00010000, 456C0000, 10000
PARS: 0x456D0000, 0x00020000, 1, 00010000, 456C0000, 10000
PARS: 0x456E0000, 0x00020000, 0, 00010000, 456E0000, 10000
PARS: 0x456F0000, 0x00020000, 1, 00010000, 456E0000, 10000
PARS: 0x45700000, 0x00020000, 0, 00010000, 45700000, 10000
PARS: 0x45710000, 0x00020000, 1, 00010000, 45700000, 10000
PARS: 0x45720000, 0x00020000, 0, 00010000, 45720000, 10000
PARS: 0x45730000, 0x00020000, 1, 00010000, 45720000, 10000
PARS: 0x45740000, 0x00020000, 0, 00010000, 45740000, 10000
PARS: 0x45750000, 0x00020000, 1, 00010000, 45740000, 10000
PARS: 0x45760000, 0x00020000, 0, 00010000, 45760000, 10000
PARS: 0x45770000, 0x00020000, 1, 00010000, 45760000, 10000
PARS: 0x45780000, 0x00020000, 0, 00010000, 45780000, 10000
PARS: 0x45790000, 0x00020000, 1, 00010000, 45780000, 10000
PARS: 0x457A0000, 0x00020000, 0, 00010000, 457A0000, 10000
PARS: 0x457B0000, 0x00020000, 1, 00010000, 457A0000, 10000
PARS: 0x457C0000, 0x00020000, 0, 00010000, 457C0000, 10000
PARS: 0x457D0000, 0x00020000, 1, 00010000, 457C0000, 10000
PARS: 0x457E0000, 0x00020000, 0, 00010000, 457E0000, 10000
PARS: 0x457F0000, 0x00020000, 1, 00010000, 457E0000, 10000
PARS: 0x45800000, 0x00020000, 0, 00010000, 45800000, 10000
PARS: 0x45810000, 0x00020000, 1, 00010000, 45800000, 10000
PARS: 0x45820000, 0x00020000, 0, 00010000, 45820000, 10000
PARS: 0x45830000, 0x00020000, 1, 00010000, 45820000, 10000
PARS: 0x45840000, 0x00020000, 0, 00010000, 45840000, 10000
PARS: 0x45850000, 0x00020000, 1, 00010000, 45840000, 10000
PARS: 0x45860000, 0x00020000, 0, 00010000, 45860000, 10000
PARS: 0x45870000, 0x00020000, 1, 00010000, 45860000, 10000
PARS: 0x45880000, 0x00020000, 0, 00010000, 45880000, 10000
PARS: 0x45890000, 0x00020000, 1, 00010000, 45880000, 10000
PARS: 0x458A0000, 0x00020000, 0, 00010000, 458A0000, 10000
PARS: 0x458B0000, 0x00020000, 1, 00010000, 458A0000, 10000
PARS: 0x458C0000, 0x00020000, 0, 00010000, 458C0000, 10000
PARS: 0x458D0000, 0x00020000, 1, 00010000, 458C0000, 10000
PARS: 0x458E0000, 0x00020000, 0, 00010000, 458E0000, 10000
PARS: 0x458F0000, 0x00020000, 1, 00010000, 458E0000, 10000
PARS: 0x45900000, 0x00020000, 0, 00010000, 45900000, 10000
PARS: 0x45910000, 0x00020000, 1, 00010000, 45900000, 10000
PARS: 0x45920000, 0x00020000, 0, 00010000, 45920000, 10000
PARS: 0x45930000, 0x00020000, 1, 00010000, 45920000, 10000
PARS: 0x45940000, 0x00020000, 0, 00010000, 45940000, 10000
PARS: 0x45950000, 0x00020000, 1, 00010000, 45940000, 10000
PARS: 0x45960000, 0x00020000, 0, 00010000, 45960000, 10000
PARS: 0x45970000, 0x00020000, 1, 00010000, 45960000, 10000
PARS: 0x45980000, 0x00020000, 0, 00010000, 45980000, 10000
PARS: 0x45990000, 0x00020000, 1, 00010000, 45980000, 10000
PARS: 0x459A0000, 0x00020000, 0, 00010000, 459A0000, 10000
PARS: 0x459B0000, 0x00020000, 1, 00010000, 459A0000, 10000
PARS: 0x459C0000, 0x00020000, 0, 00010000, 459C0000, 10000
PARS: 0x459D0000, 0x00020000, 1, 00010000, 459C0000, 10000
PARS: 0x459E0000, 0x00020000, 0, 00010000, 459E0000, 10000
PARS: 0x459F0000, 0x00020000, 1, 00010000, 459E0000, 10000
PARS: 0x45A00000, 0x00020000, 0, 00010000, 45A00000, 10000
PARS: 0x45A10000, 0x00020000, 1, 00010000, 45A00000, 10000
PARS: 0x45A20000, 0x00020000, 0, 00010000, 45A20000, 10000
PARS: 0x45A30000, 0x00020000, 1, 00010000, 45A20000, 10000
PARS: 0x45A40000, 0x00020000, 0, 00010000, 45A40000, 10000
PARS: 0x45A50000, 0x00020000, 1, 00010000, 45A40000, 10000
PARS: 0x45A60000, 0x00020000, 0, 00010000, 45A60000, 10000
PARS: 0x45A70000, 0x00020000, 1, 00010000, 45A60000, 10000
PARS: 0x45A80000, 0x00020000, 0, 00010000, 45A80000, 10000
PARS: 0x45A90000, 0x00020000, 1, 00010000, 45A80000, 10000
PARS: 0x45AA0000, 0x00020000, 0, 00010000, 45AA0000, 10000
PARS: 0x45AB0000, 0x00020000, 1, 00010000, 45AA0000, 10000
PARS: 0x45AC0000, 0x00020000, 0, 00010000, 45AC0000, 10000
PARS: 0x45AD0000, 0x00020000, 1, 00010000, 45AC0000, 10000
PARS: 0x45AE0000, 0x00020000, 0, 00010000, 45AE0000, 10000
PARS: 0x45AF0000, 0x00020000, 1, 00010000, 45AE0000, 10000
PARS: 0x45B00000, 0x00020000, 0, 00010000, 45B00000, 10000
PARS: 0x45B10000, 0x00020000, 1, 00010000, 45B00000, 10000
PARS: 0x45B20000, 0x00020000, 0, 00010000, 45B20000, 10000
PARS: 0x45B30000, 0x00020000, 1, 00010000, 45B20000, 10000
PARS: 0x45B40000, 0x00020000, 0, 00010000, 45B40000, 10000
PARS: 0x45B50000, 0x00020000, 1, 00010000, 45B40000, 10000
PARS: 0x45B60000, 0x00020000, 0, 00010000, 45B60000, 10000
PARS: 0x45B70000, 0x00020000, 1, 00010000, 45B60000, 10000
PARS: 0x45B80000, 0x00020000, 0, 00010000, 45B80000, 10000
PARS: 0x45B90000, 0x00020000, 1, 00010000, 45B80000, 10000
PARS: 0x45BA0000, 0x00020000, 0, 00010000, 45BA0000, 10000
PARS: 0x45BB0000, 0x00020000, 1, 00010000, 45BA0000, 10000
PARS: 0x45BC0000, 0x00020000, 0, 00010000, 45BC0000, 10000
PARS: 0x45BD0000, 0x00020000, 1, 00010000, 45BC0000, 10000
PARS: 0x45BE0000, 0x00020000, 0, 00010000, 45BE0000, 10000
PARS: 0x45BF0000, 0x00020000, 1, 00010000, 45BE0000, 10000
PARS: 0x45C00000, 0x00020000, 0, 00010000, 45C00000, 10000
PARS: 0x45C10000, 0x00020000, 1, 00010000, 45C00000, 10000
PARS: 0x45C20000, 0x00020000, 0, 00010000, 45C20000, 10000
PARS: 0x45C30000, 0x00020000, 1, 00010000, 45C20000, 10000
PARS: 0x45C40000, 0x00020000, 0, 00010000, 45C40000, 10000
PARS: 0x45C50000, 0x00020000, 1, 00010000, 45C40000, 10000
PARS: 0x45C60000, 0x00020000, 0, 00010000, 45C60000, 10000
PARS: 0x45C70000, 0x00020000, 1, 00010000, 45C60000, 10000
PARS: 0x45C80000, 0x00020000, 0, 00010000, 45C80000, 10000
PARS: 0x45C90000, 0x00020000, 1, 00010000, 45C80000, 10000
PARS: 0x45CA0000, 0x00020000, 0, 00010000, 45CA0000, 10000
PARS: 0x45CB0000, 0x00020000, 1, 00010000, 45CA0000, 10000
PARS: 0x45CC0000, 0x00020000, 0, 00010000, 45CC0000, 10000
PARS: 0x45CD0000, 0x00020000, 1, 00010000, 45CC0000, 10000
PARS: 0x45CE0000, 0x00020000, 0, 00010000, 45CE0000, 10000
PARS: 0x45CF0000, 0x00020000, 1, 00010000, 45CE0000, 10000
PARS: 0x45D00000, 0x00020000, 0, 00010000, 45D00000, 10000
PARS: 0x45D10000, 0x00020000, 1, 00010000, 45D00000, 10000
PARS: 0x45D20000, 0x00020000, 0, 00010000, 45D20000, 10000
PARS: 0x45D30000, 0x00020000, 1, 00010000, 45D20000, 10000
PARS: 0x45D40000, 0x00020000, 0, 00010000, 45D40000, 10000
PARS: 0x45D50000, 0x00020000, 1, 00010000, 45D40000, 10000
PARS: 0x45D60000, 0x00020000, 0, 00010000, 45D60000, 10000
PARS: 0x45D70000, 0x00020000, 1, 00010000, 45D60000, 10000
PARS: 0x45D80000, 0x00020000, 0, 00010000, 45D80000, 10000
PARS: 0x45D90000, 0x00020000, 1, 00010000, 45D80000, 10000
PARS: 0x45DA0000, 0x00020000, 0, 00010000, 45DA0000, 10000
PARS: 0x45DB0000, 0x00020000, 1, 00010000, 45DA0000, 10000
PARS: 0x45DC0000, 0x00020000, 0, 00000404, 45DC0000, 0404
MCU Part_1 Flashing Done, Time: 04:03
Baud Rate: 921600
Prolgue Ok
PayLoader Ok
