08-25-2008, 15:05 | #5 (permalink) |
Junior Member Join Date: Apr 2008
Member: 750650 Status: Offline Sonork: hajisadi Thanks Meter: 8 | i want to unlock 1200 which i bought it from malawi but the problem is when i try to unlock it says failed aborting.its ver.5.23. but check button and flash button its all functioned, but other buttons it said failed aborting MCU ID: 0x2292 FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Powering the phone... Failed! Aborting! |
10-14-2008, 16:05 | #6 (permalink) |
Junior Member Join Date: Apr 2008 Location: dsm
Member: 750735 Status: Offline Sonork: maningo Thanks Meter: 9 | mr this is a cable problem one day i got ten pic to unlock then i face same problem, when i try unlock 1200 it shows failed aborting. i change three cable but same broblem, but i got one cable which you dont believe, it unlock all ten pic without broblem. |
10-14-2008, 17:10 | #7 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
12-05-2008, 20:57 | #10 (permalink) |
Insane Poster Join Date: Aug 2004 Location: MWANZA,TANZANIA Age: 44
Member: 76815 Status: Offline Thanks Meter: 7 | if not the cable,I think its a problem with the new hardware on-board......the flash IC (INTEL) ,PLUS THE CPU.....SEEM EXTREMELY DIFFERENT FORM OLDER VERSIONS AND TO MAKE THINGS WORSE,POWER OVERSTAYS IN THE CIRCUIT AFTER DISCONNECTING CABLE.........THIS FAILS PHONE TO SWITCH AUTOMATICALLY FROM FLASH MODE BACK TO LOCAL/TEST MODE IN APROPRIATE TIME AS STEPS DO REQUIRE TO UNLOCK A PHONE BY PATCHING.. |
again fail to unlock samsung qualcom [ANSWERED] | luinaranjo | PolarBox 3 | 11 | 09-29-2010 06:13 |
1200 RH 100 5.32 failed to unlock. | desbloqueocelgd | Cyclonebox | 5 | 05-25-2009 14:58 |
Failed to unlock 5310x even after Activating BB5SL2 again. | mgtsales | Universalbox | 7 | 05-06-2009 16:46 |
nokia 1200 - now costing credits to unlock??? | koolphones | Universalbox | 5 | 08-29-2008 22:32 |
