06-15-2010, 16:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Germany , Bavaria Age: 45
Member: 37125 Status: Offline Thanks Meter: 19 | Samsung S5230 dead i got a Samsung S5230, which was flashed with the Files from an other Samsung phone. The Phone doesn't start anymore. With SAM Software i can't connect the Phone. Also Bootloader Repair doesn't work on SAM Software. It shows only the folow: Connect Phone to RJ-45 Without Battery ! ExBL Failed: Invalid NAND Boot SET_BAUD Failed: 0 The cable is brand new. Does anyone this problem ? |
06-15-2010, 17:18 | #3 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | Is it not possible to repair with HWK ? I mean, HWK SAM Software has BOOT REPAIR Button but this dont work . Connect Phone to RJ-45 Without Battery ! ExBL Failed: Invalid NAND Boot SET_BAUD Failed: 0 |
06-15-2010, 22:14 | #4 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | After a long time and many test, i repaired the boot section. I dont know why it worked 1 time after 50 trys. But yet i can set the phone in download mode. The new Problem is i cant flash. SAM Software shows allways USB Time-Out, the samsung drivers are installed but for mobile phone modem isnt installed, there is no driver in HWK folder for that. Please tell me how to flash this phone. Moreover which options must i set in SAM Software and which flashfile parts are needed ? Thanks |
06-16-2010, 10:23 | #5 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
06-16-2010, 13:16 | #6 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | @ODIA, which cable do you mean ? Is it possible that you post a picture ? I have RJ45 cable for Twister to Phone and original S5230 usb data cable. I repaired Bootloader via RJ45, but flashing didnt work via RJ45 and also not via original Samsung data cable. Thanks |
06-16-2010, 14:23 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 458 | tested 100/1000000000 ok SAMSUNG S5230-S3650 Dead phone Repair FREE Here Sw From SAmsung all totaly free without any box... 1. Select com Port 2. Press Start 3. Press Power On Phone 4. Err.Bootloader. 5. Disconnect. 6. DL Bootloader. 7 Press Power on Phone 8 After Job Done Write full flash with boot B.R GT-S3650_UART_Downloader.rar (259.8 KB, 34 views) GT-S5230_UART_Downloader.rar (253.1 KB, 34 views) For more Information see below SAMSUNG S5230-S3650 Dead phone Repair FREE!!!!! - GSM-Forum |
06-16-2010, 15:18 | #9 (permalink) | |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote: Odia. | |
06-17-2010, 08:18 | #10 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | Yet I found that problem, it is because SAMs Software just load BCMBOOT and BOOT2 if you do Bootloader repair. And on Flashing Mode, you can just give 1 file into BOOT section. With Multiloader (Samsung Original Programm) you can select the complete Bootloader Folder. In there are BCMBOOT, BOOT2, PATCH_DSP, SYSPARM_DEP, SYSPARM_IND. After flashing the Bootloader Folder with Multiloader, the phone worked again. So its just a Problem that SAMS cant select the whole folder. Thanks for Help |
06-18-2010, 11:04 | #12 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | I will test it, but I dont have actually such a phone here. But I have a other question ODIA, is it possible to reduce the Window Size from the HWK Software ? I mean, on a Netbook with 1024x600 pixel, you dont see the process bar, or buttons Buttons. Also not in Fullscreen mode. Thanks |
07-31-2010, 14:23 | #13 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Poland Age: 39
Member: 157756 Status: Offline Thanks Meter: 14 | Workin fine whit c450 cable My phone was dead after soft upgrade. Connect Phone to RJ-45 Without Battery ! ExBL Failed: Invalid NAND Boot UART_BOOT Done File: \Pulpit\BOOTFILES\bcmboot.img S5230-img, START: 00000000 SIZE: 0000D720 NAND Write Complete NAND_ID: Samsung K522H1HACA [BA] COMM_BR: 921600 Baud File: \Pulpit\BOOTFILES\boot2.img S5230-img, START: 00020000 SIZE: 00029AB8 NAND Write Complete |
08-21-2010, 11:10 | #14 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Inside Your Mind Age: 38
Member: 97899 Status: Offline Thanks Meter: 46 | Quote:
Can you please give little more info, because when I pass the step: Connect Phone to RJ-45 Without Battery ! ExBL Failed: Invalid NAND Boot it gives me set baud error Connect Phone to RJ-45 Without Battery ! ExBL Failed: Invalid NAND Boot SET_BAUD Failed: 0 Same like "MisterX GSMFREE" I tried with and without battery......tried to reconnect phone in the moment when program asks to chose the bott file.....and always set baud error 0 !!! Tell me where`s my mistake?!? BR TheBrain | |
08-22-2010, 02:45 | #15 (permalink) | ||
Freak Poster Join Date: Jan 2004
Member: 48396 Status: Offline Thanks Meter: 82 | To repair dead S5230 I used E210 rj45 cable: Step by step: 1. Select S5230 from models list. 2. Select boot file bcmboot.img from firmware boot folder. 3. Tick "Boot change" in "Write options". 4. Press "Boot repair" button. When see "Connect Phone to RJ-45 Without Battery !" connect phone without battery to the box with rj45 cable (you will be asked to select boot2.img file): Quote:
5. Tick "Full download" ("Boot change" must be enabled too). 6. Select firmware files. 7. Press "Write Flash". Quote:
The Following 9 Users Say Thank You to UnReality For This Useful Post: |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
