Samsung B3410 screen show "BD0204EE" how to solve? Samsung B3410 screen show "BD0204EE" Can i solve this problem by HWK? |
Br. Vijendra Saini. |
its posibble erase then write flash |
Nope write only e2p,your problem were solved. Used search button. Br. Vijendra Saini. |
for me same problem i tied many ways still error . i write E2P writing 51% then stops. what is the problem please help. regards |
1 Attachment(s) hi, i tried many ways no luck please check image and help solution. BR |
First Erase Nor, next write good E2p and then full flash. Don't worry if E2P writing stops in between. Br. |
thanks for kind replays, i did same way still error . can u please know me which version has to flash ? BR |
Try different flasher like z3x and do eprom repair tool all ok many time tested |
I tried Z3X tool also with 3 deferent version flashed and repair EEprom no luck. Can u tell me exact which version files has to use. BR |
if this B3410c ? how to know exact model ? |
MCU File: B3410UTJA1_H6.cla CRC32: BD5155AF TFS File: B3410UTJA1_H6.tfs CRC32: 32B3713D CFG File: B3410UTJA1_H6.cfg 196550 byte(s) CSC File: B3410ZTAJA1_H6.csc CRC32: 1EC73BA7 CCF File: B3410ZTAJA1_H6.ccf 28935 byte(s) MCU Id: 5B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:09 File CRC: 0xBD5155AF MCU Write Done, 30739148 byte(s), Time: 07:55 File CRC: 0x32B3713D TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 219 Max_Files : 2351 Files_Count: 2351/2351 TFS Unmounted TFS Write Done, 38915410 byte(s), Time: 13:03 CSC Format Done, Time: 00:00 File CRC: 0x1EC73BA7 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 53 Max_Files : 317 Files_Count: 317/317 CSC Unmounted CSC Write Done, 3583407 byte(s), Time: 01:20 Erase Canceled E2P File: B3410 eeprom.sw_eep CPU: GenuineIntel Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Version : Ufs2xx.dll 3.1.19, Ufs2xx.sys 2.6.0 C:\Program Files\Common Files C:\Program Files\SarasSoft\UFS\UFS_SAMs V 2.2.0.3 ------ SWIFT-AEROFONE E1080T-SEA,E1175T-MEA,E1190-CHN,E1195,E1195-CHN,E1230 added (PUNL,PIM,FL) E1055G info/unlock bug fixed. xx-DX models renamed to xx-SEA (note: DD is IND not SEA) E2222 (UNL,SECT,IM) SWIFT-3G (CUNL,SECT) fixed for C3630C,C3730C,S3930C E3213K,i6320C,i6330C,S3710,S3770,S3778,S3830U,S561 0, S5610K,S5630C added (CUNL,SECT,FL) INFINEON IMEI2 Rebuild added for DUOS models. Minor bugs in AT protocol fixed: (not read Codes and IMEI Rebuild fails on some models) Notes: Some S3550 units stucks on DFFS (CSC) Flashing, Solution: Untick [Use EBL from FLS Pack] CheckBox. COMMON Fixed BSOD bug on W7 x64 when Connect Box. V 2.2.0.2 ------ TRIDENT VISION <CODE CORRUPTED> for non 8 Digits PCK Fixed. SWIFT-AEROFONE E1050-CHN,E1050V,E1086i,E1150-CHN,E1155L,E1180,E1190,E1220i added (PUNL,PIM,FL) E1182L added (DUNL,PUNL,PIM,FL) E1225T,E1182 TFS Flashing bug Fixed. C3322 Unlock, IMEI, Sections bug Fixed. B7722,B7732 Slave Part Flashing/Read/E2P added. QUALCOMM T669 Added. INFINEON C3011,C3560,C3750,C3752 added (CUNL,PUNL,PIM,FL,UFL) E2232 Flashing bug Fixed. <CODE CORRUPTED> for non 8 Digits PCK Fixed. V 2.2.0.1 ------ SWIFT Some DUOS models Slave Boot bug Fixed. SWIFT-AEROFONE E1050,E1055T,E1080W,E1170i E2P Size Fixed. Max Section Size Increased. E1182 added (DUNL,PUNL,PIM,FL) C3303i,C3322,C3500 added (CUNL,DUNL,IM,SECT,E2P) Note: C3322,C3500 TFS and CSC Flashing not Supported yet, use Original Flasher. SWIFT-3G C5010B added (CUNL,SECT,FL) QUALCOMM A885,A886,F406,S3370B,S3370L added. INFINEON E2652,E2652W USB Flahing bug Fixed. E2152i added (CUNL,PUNL,PIM,FL,UFL) XGOLD213 BIF file Write bug fixed. XGOLD213 Patch bug fixed. BROADCOM B5310R,C6712,S3853,S5250W added (UFL) COMMON Used Abbrevations List can be seen at the Bottom of this page. V 2.2.0.0 ------ TRIDENT A127,i626,T719,X475 added (DUNL,IM,FL) OM(SYSOL) T209,T319 added (DUNL,IM,FL,SECT) SWIFT A436,A437,A516,A517,T229,T249,T339,T349-LTA-USA,T369, T409,T619,T739 added (DUNL,IM,SECT,FL) Added Multi Drive support for TFS Read. Fixed SLAVE Boot Bug on some models (D980,D980F,D988) TFS Extractor and TFS Builder added, Allows to Edit TFS files. SWIFT-AEROFONE Added [Patch MSL] Function to Patch without MCU Part Flashing. C3300i,T109,T119 added (DUNL,IM,FL) E1050,E1055G,E1055T,E1080F-IND-MEA-SEA,E1080W, E1081T-EU-IND-MEA-SEA,E1083C,E1085F,E1085F-MEA,E1087T,E1105F, E1150i,E1160i,E1170i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F, E1225T,E1225T-IND,E2121L added (PUNL,PIM,FL) Notes: 1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets. 2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA. 3.For Cross Flashing Select Model Name Extension by File type. 4.Before Unlock, Info to see Codes or Rebuild IMEI use [Patch MSL] Button or Flash with [Patch MSL] Option Enabled. C3222,C3222W added (DUNL,CUNL) Note: C3222 Flashing not Supported yet, use Original Flasher. TFS Extractor and TFS Builder added, Allows to Edit TFS files. SWIFT-3G C5010E,E3210 added (CUNL,SECT,FL) QUALCOMM A597,A847,A927,B2710D,C5180,S5520,S5580,S6700T,S68 88,T359,T479, T746,T749 added. More Versions Support of Hidden Sysinfo models CUNL and UNFR: A597,A706,A707,A717,A727,A847,A887,A897,A927,B2710 ,B2710D,S3370, S5530,T359,T469,T479,T559,T659,T746,T749 QUALCOMM+LSI S8500B,S8530 added (FL) BROADCOM S5230N added (FL,CUNL,UNFR,BRP) S3850,S5260,S5263,S5330L,S5560i,S5750E,S5753E,S723 0B,S7230E, S7230W,S7233E added (FL) S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP) [QCDI Info] Renamed to [BCMBL Info] for BroadCom Models. INFINEON B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2230,E223 0M,E2232, E2330,E2330B,E2330C,E2530,E2652,E2652W,S3310i,S335 0,S3353, S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL,UFL) Note: for USB Flashing select 'USB0' in [BaudRate] box. E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000) DOCUMENTS SAMSUNG_UNIVERSAL_uUSB_RJ45_CABLE_REV2.1.xps Samsung Swift-Aerofone MSL3 Models How to Rev.2.txt V 2.1.0.7 ------ SWIFT-AEROFONE E2152 FULL, _RD, E2P Write Bug Fixed. Note: E2152 DX Firmwares cannot be Properly Flashed. QUALCOMM B2710,S3370E added. QUALCOMM+LSI S8000L added (FL) BROADCOM S5620B,S5628i added (FL) COMMON Used Abbrevations List can be seen at the Bottom of this page. V 2.1.0.6 ------ TRIDENT X427 added (DUNL,IM,FL) TRIDENT VISION M2520 added (UNL,CUNL,IM,FL) Display of USER LOCK Key for All Models. SWIFT E2550,E2550D,E2558 added (UNL,SECT,IM) Notes: 1.Chinese Versions E2550Zxxx select as E2558 for UNL,SECT,IM. 2.E255x PRAM Flashing not Supported yet, use Original Flasher. B3410C,E2510C,S5050C added (UNL,IM,FL) Note: Chinese Versions B3410Zxxx select as B3410C. SWIFT-AEROFONE C3300D,C3300K,C3303,C3303K added (UNL,SECT,IM,FL) use 530Kom Cable. E1107-DX,E1107L,E1117-MEA-IND,E1130,E1130B,E1150-MEA-SEA,E1153, E1160-DX,E1220,E2120i,E2120L,E2121,E1252,E2121B,E2210T,E 2152, E2370 added (CUNL,PUNL,PIM,FL) Note: Mixing of DX MEA SEA Models causes Blinking or Dead Sets. [Restart] Button now Exit TAT mode with Battery. Auto Exit from TAT Mode when Flashing, not need Cable or Battery Reconnect after UI functions (Info,IM,..) SWIFT-3G J808,S5550,S5550U added (CUNL,SECT,FL) B7722,B7732 DUOS added (CUNL,SECT,FL) Flashing only Master Part. C3630C,C3730C,S3930C TD-SCDMA added (FL) use 530Kom Cable. QUALCOMM A657,A887,A897,M7600L,S5530,T559 added. BROADCOM A697,B3410W added (FL,CUNL,UNFR,BRP) S5250,S5253,S5330,S5333 added (FL) Boot Repair Enabled for All Broadcom models, use 530Kom Cable. Some Models have encrypted Boot2.img and don't have uart_boot, for these models use our released Boot_Repair packs. Note: S562x with OneNand Flash Chip, Cannot be Repaired. Added Unlock support(CUNL) for Hidden Sysinfo models (S5560,..) if have no succes in SysInfo search, need ReFlash, to have untrashed FS COMMON Reduced/Full Log of TFS file list progress for OM/Swift. Improved FileOpen dialog, to Override suggested path to last used on same model. Used Abbrevations List can be seen at the Bottom of this page. DOCUMENTS SAMSUNG_UNIVERSAL_uUSB_RJ45_CABLE.pdf Samsung B7722 How to Rev.1 Samsung C3300_C3303 How to Rev.1 Samsung S523x Warning Rev.1 Samsung S7070 How to Rev.1 Samsung Swift-Aerofone MSL3 Models How to Rev.1 V 2.1.0.5 ------ TRIDENT VISION M2513 added (UNL,CUNL,IM,FL) SWIFT Added MCU_Id and Type Display. Increased Preloader boot speed. QUALCOMM More Versions Support of Hidden Sysinfo models CUNL (S3370,..) A877,M7600H,M8800H,S5603T,S7120H,S8300T added. QUALCOMM+LSI M8910,M8910B,M8910H,M8910U,S8000,S8000B,S8000C,S80 00H,S8000U, S8003,S8500,S8500C added (FL) BROADCOM C3510T,M3710,S5560H added (FL) S3650H,S5230C added (FL,CUNL,UNFR,BRP) INFINEON Infineon Platform Introduced, See on [Sky/INF] Tab. E1151 added (CUNL,FL) DHLT Engine will ask about additional DHLT tables generation. COMMON [Refresh] will Auto Select Ports, be sure that Right Model and Mode is Selected (Untick [QualComm mode] when Flashing !) V 2.1.0.4 ------ TRIDENT VISION B3210M added. Bug in E2P Filename Display fixed. OM(SYSOL) On the Fly E2P Patch added to keep Original IMEI number. SWIFT C3212i added(UNL,IM,FL) On the Fly E2P Patch added to keep Original IMEI number. SWIFT-AEROFONE E1080i,E1086,E1086L,E1170,T139 added (CUNL,PUNL,PIM,FL) On the Fly E2P Patch added to keep Original IMEI number. On the Fly MCU Patch added to bypass MSL security for MSL3 (MSLC16) products (E1080,E1080i,E1086,E1150,E1160, ...) after is possible Direct Unlock, Rebuild IMEI in normal way. QUALCOMM S3370,S5350M added (FL,CUNL,UNFR) S5350 added (CUNL,UNFR) Increased Speed in Communications (NVM Read/Write, RAM Read) BROADCOM B5310U added (FL) i6230,S3653M added (CUNL,FL,BRP) Combo Cable (USB+RJ45) Support added, not need Manipulations with Cable when use [QCDI Info] Corrected CSC,APP,PFS flashing for BCM2153 platform (B5310,..) [Boot Change] Product will Restart after success Boot Change, if Failed, will stay in Download Mode to Allow Retry. [Full Download] will Write All without Restart after Boot Change. COMMON [Refresh] will Show Avalaible Ports List with Full Names. 2.1.0.3 ------ TRIDENT M628N added (DUNL,IM,FL) SWIFT A256,J218,S3600i,S3601C added (UNL,IM,FL) SWIFT-3G B2703 added (CUNL,FL,SECT,BT) QUALCOMM A747,C5510,C5510U,T929 UNLOCK and UNFREEZE added. Improved Decryption algo, more models UNLOCK and UNFREEZE supported by Default. BROADCOM S5230K,S5230R added (CUNL,FL,BRP) B5310,S5620,S5628,S7070C added (FL) Use Samsung Kies drivers for these models (B5310,S562x) Fixed 'Cannot Find NandInfo !' on some models. COMMON Log to file fixed for Trident models. Introduced New Extremely Fast Key Calculation Algorithm (DHLT) Need few hours for Tables generation at First Software startup. But after, Key calculation for Qualcomm, Broadcom and Trident platforms will take few seconds. DHLT (c)SarasSoft. V 2.1.0.2 ------ SWIFT-AEROFONE T239 added (CUNL,FL) BROADCOM Fixed UNFREEZE Key Display. V 2.1.0.0 ------ TRIDENT C158,C158B,C188L,C240L,C258,C260B,C260L,C260M,C300 B,E576,E758, X138,X180,X468P,X478,X568 added (DUNL,IM,FL) USB flashing introduced for HPE models (U600,.. Approx. 2x faster) TRIDENT VISION B3210,B3310,B3313,C3010S,C3050C,C3053,C3060,C3110H ,M620N, S3030C,S3500C,S3500H,S3500i,S3501C,S5150,S5150C added (CUNL,IM,FL) MSL3 bypass introduced (B3210,B3310,B3313,C3060,C3060R,...) USB UI functions introduced, allows to unlock USB only phones. USB flashing introduced (Approx. 5x faster) (Cannot use USB flashing of dead phones which have UL erased or damaged. RJ45 flashing can be used to recover from erased UL situation) SWIFT A177,A226,A227,A237,A257,B3410,B5702,B5712C,B5722, B5722C,C3212, C3510,C3518,C6112,C6112C,D980F,E200E,E208B,E250L,E 848i,F118, F278,J150B,M2710,M2710C,M2710L,M3510C,S3100,S3110, S3110C, S3600C,S3600H,S5200C,T219,T329,T729 added(UNL,IM,FL) Added ENG flashing for DUOS FOTA models (D988,B5712C,..) Auth. Boot and Firmware Sign. for Secure models (B5722,C3510,C6112,S3100) B5702,D988,F265L,S5050 (SECT) bug fixed. CSC Area format added. SWIFT-AEROFONE A137,CC01i,E1070C,E1100C,E1101C,E1107,E1113C,E1120 C,E1210, E1310C,E1310E,E1360,E1360C,E1360S,E2100C,E2210C,E2 210H added (DUNL,IM,FL) E1080,E1080C,E1080T,E1085,E1085L,E1085T,E1088C,E11 00H,E1150, E1150C,E1160,E2120,E2120B,E2120C,E2130 added (CUNL,FL) SWIFT-3G C5110,C5130,C5130S,C5130U,J800R added (CUNL,FL,SECT,BT) P270 (CUNL,SECT) bug fixed. E2P Write is supported only for C5130,C5130S and C5130U. QUALCOMM A551,A561,A637,A746,A747,A766,A767,A811,A821,A827, A836,A837, A867,C5220,C5510H,C5510U,G508,G508E,M7600B,M7600H, S5350, S5600B,S5600L,S5608U,S5510,S7120U,S7350C,S7350E,S7 350F, S7350H,S7350i,S7520U,S8300H,T469,T659,T749,T919,T9 29,U808 added. Fixed flashing of non page size aligned files (rc1,rc2,ffs) Added flashing support for QSC62xx models. UNLOCK and UNFREEZE added for these models: A551,A637,A767,A827,A837,C5220,F400,S5510,S7350,S7 350C, S7350F,S7350i,T639,Z170,Z240E,Z360,Z720,ZV40 BROADCOM QC Legacy BroadCom models introduced: i6220,S3650,S3650C,S3650M,S3650W,S3653,S3653W,S523 0,S5230G, S5230H,S5230M,S5230W,S5233A,S5233S,S5233T,S5233W,S 5560,S5560C, S7070 (CUNL,FL) To read codes use: [Mobile Info] button using USB Cable (Phone Switched-ON) and after [QCDI Info] button, using RJ45 Cable (Phone-OFF) QC Legacy BroadCom models Full Flashing (with BOOT Change) [BOOT Repair] for QC Legacy BroadCom models added. Boot Repair and Codes Read is possible only for phones with NM_20 pin USB/RJ45 connector ! COMMON Log to file added. CLONE error message fixed. V 2.0.9.0 ------ TRIDENT T539 added (DUNL,IM,FL) TRIDENT VISION Fixed MSL algorithm for some models (C3050,...) SWIFT D606,D900E,E260,M2310,P220,S366,S5050,S5200 added(DUNL,IM,FL,SECT) SWIFT-AEROFONE B270i,C276,C276L,E1070M,E1070T,E1075,E1075L,E1105T ,E2100B, E2210B added (DUNL,IM,FL) QUALCOMM Manual Port Selection Added (Use Refresh, After Each Phone Reboot or Reconnect) (Untic QualComm Mode, Before Flashing) F480R,i6210,U900W added. UNLOCK and UNFREEZE added for these models: A736,A737,F490,G800,G800L,M7600,S5600,U900W,Z400,Z 540 V 2.0.8.5 ------ TRIDENT B100K,C140i added (DUNL,IM,FL) TRIDENT VISION C3010,C3050,C3060R,C3110,C3110C,S3500 added (CUNL,IM,FL) M120,M128,E1040,S3030 added (DUNL,IM,FL) B520 Vodafone support added. (use B520B-V model, not mix with B520, filenames are similar) (Use [Reset MMI] if phone ask for password without SIM) New MSL bypass algo introduced (B220,..,C3050,E1410,S3500...) allows direct codes reading, unlock and IMEI repair. MSL Repair introduced, allows to repair or use alien E2P (Repair of "User Fault on Illegal Trial !!" and restore IMEI) OM(SYSOL) C160G added (DUNL,IM,FL,SECT) SWIFT B2100,C5212,E250i,F265L,F270,J700i,M158,P250,U800E ,X576 added (DUNL,IM,FL,SECT) SWIFT-AEROFONE B100i,B210 added (DUNL,IM,FL,SECT) C270,E1100,E1120,E1125W,E1125-SEA,E1210M,E1210S,E1310B, E1310M,E1310S,E1360B,E1360M,E2100,E2210 added (DUNL,IM,FL) (Do not mix B-C-M-L-S-T-EUR-SEA models! More info on support) B130S,B130T flashing fixed (blinking or frozen phone) (Must select target firmware as model, e.g. model is B130 and want to flash B130S, select B130S as the model.) SWIFT-3G P270 added (DUNL,FL,SECT,BT) QUALCOMM A777,M7600,M7603,M8800C,M8800L,S5600,S5603,S8300N added. [Write E2P] (NVM) added. UNLOCK and UNFREEZE added for these models: A411,A777,S7220, S7330,S8300,S8300C,Z230 (Use [QCDI Info] button to read keys) Old models UNLOCK and UNFREEZE: Z300,Z500,..,ZM60,.. (these are not in models list, select any model. Use [Mobile Info] button to read keys & [Unlock] to direct unlock) V 2.0.8.4 ------ TRIDENT B100M added (DUNL,IM,FL) TRIDENT VISION B310R added (CUNL,FL) SWIFT-AEROFONE E1070,E1100T,E1125 added (DUNL,IM,FL) QUALCOMM Increased Comms speed on RJ45 interface. UNLOCK and UNFREEZE added for these models: L810,L811 (Use [QCDI Info] button to readout keys) V 2.0.8.3 ------ TRIDENT C275L,C500L,C506,C510L,C516,E570L,U106 added (DUNL,IM,FL) TRIDENT VISION B520B,M310L added (CUNL,FL) OM(SYSOL) C145,C161,C168B,M140L added (DUNL,IM,FL,SECT) SWIFT C3610C,E200B,E230L,E251L,F270L,F275L,F480L,J700L,P 906,U900L added (DUNL,IM,FL,SECT) SWIFT-AEROFONE B130L,E1110(Euro and Asia),E1110C,E1117,E1117L added (DUNL,IM,FL,SECT) Increased flashing speed. QUALCOMM G400L,M8800B,V820L added. UNLOCK and UNFREEZE added for these models: G400,G400F,G400L,Z150 (Use [QCDI Info] button to readout keys) V 2.0.8.2 ------ TRIDENT B270 added (DUNL,IM,FL) TRIDENT VISION J610 MSL corrected (DUNL,IM) E215L,M320L added (CUNL,FL) (Use [Reset MMI] if phone ask for password) OM(SYSOL) M140 added (DUNL,IM,FL,SECT) SWIFT J706,L708E added (DUNL,IM,FL,SECT) SWIFT-AEROFONE B130,B130S,B130T fixed flashing for HW 0.600 QUALCOMM ENUMERATION NOT EXIST: 20 bug fixed (up to COM256 supported) Fixed flashing for OEMSBL V5.32 and higher (M7500,M8800) UNLOCK and UNFREEZE added for these models: F480F,M7500(******),M8800(Pixon),U700,U700B,U708,U 800,U800F (Use [QCDI Info] button to readout keys) S7220,S7350 added. V 2.0.8.1 ------ TRIDENT CC01,P258,U600G added (DUNL,IM,FL) TRIDENT VISION B220,B310,B320,B518,B520,B528,J600G,J610,J618,M318 ,M620,M628 added (CUNL,FL) L320 added (DUNL,IM,FL) (Use [Reset MMI] if phone ask for password) OM(SYSOL) B110 added (DUNL,IM,FL,SECT) SWIFT D618,D980,E2510,F250L,F268,F278,G600G,G618,J770,J8 08E,L258,M150, M200,M3200,M3510,S3600,T429,U708E,U808E added(DUNL,IM,FL,SECT) D780,D788,D880,D888,D980 SLAVE support added (DUNL,IM,SECT) J150 fixed (DUNL,IM,SECT) IM Rebuild added and RAW TFS Read fixed for these models: D618,D780,D788,D880,D888,D900i,D908i,D980,E200,E20 8,E250, E250D,E250V,E256,E258,E258D,E251,E251C,E480,E488,E 590,E598, E740,E747,E830,E838,E2510,F110,F250,F250L,F258,F26 8,F278,G600, G608,G808E,G618,J150,J210,J700,J708,J770,J808E,L25 8,L310,L600, L608,M150,M200,M610,M618,M3200,M3510,P180,P260,S36 00,T429,U708E, U808E,U908E (Need power up phone with battery after IM done !) SWIFT-AEROFONE B130,B130S,B130T added (DUNL,IM,FL,SECT) SWIFT-3G B2700,J800,L700,L708 introduced (DUNL,FL,SECT,BT) SKYWORKS C100 - 'Not Released Yet' bug fixed. QUALCOMM F480G,F480H,M7500,M8800,S7330,U900F,U900G,U900K added(FL,INF,REUL) Added QualComm mode support: (*#QUAUSB# to enter QualComm mode, QC Debug Interface on USB) (*#SAMUSB# to enter Samsung mode, QC Debug Interface on RJ45) QCDI Info, NVM Read, RAM Read added. UNLOCK and UNFREEZE introduced for these models: F480x,L760x,U900x,Z240 (Use [QCDI Info] button to readout keys) COMMON Stop button added. User interface localisation. V 2.0.8.0 ------ TRIDENT S730i (DUNL,IM,FL)added. B200,B300 DUNL and IM fixed. Reserved Regions values revised and fixed. MSL Repair enhanced, and added for following products: C17x,C26x,C520,E84x,E90x,E95x,F21x,M300,M60x,P520, U10x,U30x,X82x "Erase NOR" activated. Enhanced 4CC protocol handler (fixed error on PC busy) TRIDENT VISION E21x,J60x fixed (INF,DUNL,IM) M310 added (FL,CUNL) Enhanced 4CC protocol handler (fixed error on PC busy) OM(SYSOL) A117,C288,M130L added (DUNL,IM,FL,SECT) E746 bug fixed. SWIFT D780,D788(Duos2),D828E,E251,E251C,E258D,F110,G808E ,J210,L310, P180,P200,P260,P850,P858,T309,T509,U908E,X700N (DUNL,FL,SECT) F488E,J150 (FL,CUNL) Use 'Unlock E2P' to see Codes. E35x,E37x,T809 DUNL, SECT and IM fixed. E480,E488 bug in DUNL,SECT fixed. D880-Duos flashing bug in 2.0.7.2 fixed. X700 SECT fixed. SWIFT-AEROFONE B130 introduced(FL,CUNL) Use 'Unlock E2P' to see Codes. QUALCOMM A411,A412,A701,A706,A707,A711,A717,A727,A736,A737, A801,A817, F330,F338,F400,F408,F480,F488,F490,F510,F550,F700, G400,G800, G800B,G800L,G808,J200,J200L,J208,J630,J638,L170,L7 60,L760G, L768,L810,L811,P910,P920,P940,P950,P960,T639,T819, U700,U700B, U708,U800,U800F,U900,U900U,U908,V705,V706,V707,V70 8,Z150,Z170, Z230,Z238,Z240,Z240E,Z248,Z310,Z360,Z368,Z400,Z540 ,Z548,Z560, Z570,Z720,Z728,Z740,ZV40,ZV50,ZV60 introduced (FL,INF,REUL) COMMON Product Langpacks description added (Info and MCU-Open) Note, real menu languages can differ from listed here, for different models, firmware versions. Languages in brackets is not mandatory for current Region. V 2.0.7.2 ------ TRIDENT B100,B108,B200,B300,S710i added (DUNL,IM,FL) B100,U600,U600B MSL Repair introduced. OM(SYSOL) C420,C420L,C421,C425,C426,X560,X560L,X566 added (DUNL,IM,FL,SECT) SWIFT E747.F250,F258,J700 added (DUNL,FL,SECT) Chinese FOTA products E838, J708 flashing. COMMON INFO Product filter added. V 2.0.7.0 ------ TRIDENT C170,C178,C188,E210,E218,E840B,E848,E870,E878,E888 ,E958, F210,F218,P520(******),M608,T519,T629,U600B,U608B added. OM(SYSOL) C160,C160B,C160L,C160M,C166,C168,C180,C450,C458,CC 03, M110,X540,X550 added. E2P unlock fixed for E420,E428... Implemented MSL calculation, allows direct unlock without E2P corruption and shows correct codes. Rebuild of corrupted Master Key during wrong unlock. IMEI rebuild for new models (Sysol3) SWIFT D880,D888(Duos),E746,G608,L600,L608,M610,M618 added. Implemented MSL calculation, allows direct unlock, and show correct codes, without any data lose or setting to default values of MSL, BTID, IMEI or Radio settings. E2P Sections Read/Write introduced (compatible with TAT) IMEI and BTID rebuild.(Imei option for Swift_1 only now) Fixed bug of 0 length TFS files flashing (affected: java appletts in D880, E200, E250, G600, M610 products) COMMON INFO E2P(hee)sections R/W allows to transfer calibration data, radio setttings, etc. from product to product, without damage to other vital data, unlike E2P or FULL clone. Or allows to Read-Edit-Write well known values. Warning, Access to some sections can be denied by firmware, or can have different values dependand on firmware version. In case of protected or none existing section will have result length of 0 or lose of TAT mode. V 2.0.6.0 ------ COMMON Remaked user interface. "Support" button, to access support site. TRIDENT E950,F200,J600,J600E,J608,U300,U308,X830N added. Read Codes for J600,J600E,J608 SWIFT E598,E768,G600 added. Unlock Codes on Info for D820,D900,E250,E740,G600. V 2.0.5.7 ------ TRIDENT C520,M300,M600,X526 added. V 2.0.5.5 ------ TRIDENT E840,F300,F308,U100,U108 added. Full Reset(*2767*3855#)is mandatory after flashing ! If make Asia<>EU change, use *2767*3855# before flashing. SWIFT D900i,D908i,E200,E208,E390,E398,E590,E740,E830,E83 8 added. V 2.0.5.4 ------ TRIDENT U600,U608 added. "Test Mode" enter improved. Warning about Battery usage, during UI operations. Corrected Reserved Regions for some models(D83x,D84x,E90x,P31x,X82x) Added MSL calculation, allows direct unlock and show correct codes for new models(D83x,E570,E90x,P31x,U60x,X5xx,X63x,X68x,X8x x,.) IMEI challenger implemented, allows rebuild IMEI for new models. V 2.0.5.0 ------ COMMON Windows Vista(tm) 32bit OS support. Cut Power option (Restart - power on mobile) TRIDENT C140,C216,C240,C250,C260,C266,C268,C308,P310,P318, X166,X636 added. MSL1 bypass, allows direct unlock. OM635x E635 added. SWIFT E256,E376,E480,E488,E736,E750,E758 added. E25x direct unlock. Full TFS Read, TFS editor. Option to exclude E2P part from read MCU image. V 2.0.4.2 ------ COMMON Cables description added. TRIDENT MVN CTS flashing fixed (X830 'Unknown File System' error) FDI CTS flashing fixed (E570,X630,X680 Empty folders) Full Reset (*2767*3855#) is mandatory after CTS flashing ! X838 added. V 2.0.4 ------ TRIDENT C300,D830,D836,D838,D840,D848,E570,E906,S401i,X156 ,X160, X160b,X168,X461,X481,X510,X518,X520,X530,X680N,X81 0,X818, X830 added (Unlock works with battery only !) SWIFT E250,E258,E500,E780,E786,E788 added. Direct unlock for new models (D900,D820...) OM635x E420,E428 added. X65x - Unlock E2P feature added. S50x - Fixed "Full" flashing bug, E2P R/W added. V 2.0.3 ------ TRIDENT I300,I308,I320,X680,X688 added. CTS flashing (D520,D528,X680,X688) SWIFT E370,E378,E380,E388 added. Introduced Unlock E2P for MSL phones (D820,D900...) Read E2P shows info (IMEI, Lock Status, Unlock Codes) V 2.0.2 ------ COMMON Introduced E2P Read/Write. Allows easy backup/edit E2P areas to repair or rebuild CAL data for new models.(IMEI, Locks,..) TRIDENT C130,E900,E908,S500i,X210,X218,X500,X508,X630,X638 ,X820, X828 added (Unlock works with battery only) CTS flashing (E900,E908,X630,X638,X820,X828) SWIFT D900,D908,X670,X678 added. Corrected problems with TFS read. NOR Erase. Direct unlock for older models. OM635x X650,X658 added. NOR Erase. V 2.0.1 ------ TRIDENT S400i added (Unlock works with battery only) SWIFT E360,E368 added. v 2.0.0 (v1.4_y) ------ TRIDENT C120,C128,D520,D528,D800,D808,E770,E880,P300,P308, X300,X308 added. Read Flash - custom address range save fixed. OM635x X490,X495,X497 TFS flashing fixed. SWIFT D820,D828 flashing added. v1.4_x ------ TRIDENT D720,D730,X660,X668,X800,X808 added. OM635x X490 added. SWIFT X700 added. v1.4_w ------ TRIDENT E568,S410i,X150,X200,X208 added. BT Address Change. OM635x E108,E330N,E335,X495,X497,X628 added. SWIFT D500E,D600E,D608,E340E,E348,E350E,E358 added. M46 Models revised. v1.4_v ------ TRIDENT X140 added. NAND Erase (E530,E720,E728) to fix "Blinking LCD" Read Flash - custom address range support. OM6359 X620 added. SWIFT D600 support added for HWK customers. v1.4_u ------ COMMON Minor Bugs fixed. v1.4_t ------ TRIDENT E530,E620,E728 added. Individual BaudRate storage for each model in INI file. SWIFT E340,E350,E640,E648,E730,E738 added for HWK customers. v1.4_s ------ TRIDENT C210,C230 fixed. v1.4_r ------ COMMON OM platforms flashing bug fixed. Added new FLASH chips geometry and signatures. Ini file creation wizard for super-novice users. TRIDENT New products added: C210,C230,E315,E316,E610,E720,E850,X480. OM6359 New product added: X640. SWIFT D508 support added for HWK customers. v1.4_q ------ SWIFT D500 support added for HWK customers. TRIDENT New products added: S341i, S342i. OM6357 E630 flashing bug fixed. TFS 'spaced' filenames bug fixed. v1.4_p ------ TRIDENT C200 "Unknown Metrics" fixed for Fujitsu Flash chips. v1.4_o ------ COMMON Xprotector removed. v1.4_n ------ COMMON *.zip included to filter. TRIDENT New products added: C200,E300,E318,E718,P730,P738,X120,X426,X438,X458. OM6357 New products added: E330,E338,E630,E638,E808,X108,X460,X468. v1.4_m ------ Minor bugs fixed. v1.4_l ------ OM6357 S500, S508 support. v1.4_k ------ COMMON Updated INI file structure. Some minor and major bugs. TRIDENT TEST mode problems, without battery. 2nd Boot Error. E710 TONES problem. "Protect Reserved Regions" now works properly. OM6357 E800/E820 models support. Show all possible unlock codes. Auto Format NAND before flashing. Read TFS for E800/E820 (for educational purposes) ONE-C Bug with "New Flash Layout" mode. SkyWorks P510 model support. IMEI Rebuild. v1.4_j ------ Canceled. v1.4_h ------ COMMON Auto-Scroll Result window. Save/Load settings to INI file. Counter works now. Fixed some bugs. TRIDENT New products added D410, D418, E600, E608. OM6357 TFS flashing added. NAND format added. IMEI Rebuid added. Reset MMI added. Fixed TAT mode for some SW versions. Our Abbrevations: ----------------- FL - Flashing UFL - USB Flashing INF - Info DUNL - Direct Unlock CUNL - Unlock by Codes PUNL - Patched Unlock UNL - Unlock (Direct and by Codes) IM - Direct IMEI Rebuild PIM - Patched IMEI Rebuild SECT - Read/Write of Sections (Logical Parts of E2P) MCU - Main Software Part for MCU (Code) BRP - Boot Repair UNFR - Read Unfreeze Code QCDI - Qualcomm Diagnostics Interface DHLT - Distributed Hash Lookup Tables (used for fast Hash Reversing) FULL - Full Flash Memory Image File _RD - Files Readed from Mobile and Prepared for Flashing (not Affects E2P) One-C - VLSI BB Chipset Platform Trident - Agere BB Chipset Platform Vision - Agere BB Chipset Platform (Dual MCU Core) M46 - Conexant BB Chipset Platform OM - Philips (NXP) Sysol BB Chipset Platform Swift - Philips (NXP) Swift BB Chipset Platform SKY - SkyWorks BB Chipset Platform INF - Infineon BB Chipset Platform QC - Qualcomm BB Chipset Platform BCM - Broadcom BB Chipset Platform LSI - LSI Corp. Chipset Platform Common Abbrevations: -------------------- MMI - Man Machine Interface TAT - Test Mode (Test Auto Test) DLM - Download Mode UI - User Interface MSL - Mobile Security Layer (MSL, MSL2, MSL16, MSL3) from Samsung E2P - Nonvolatile Memory (Synonyms: NVM, EEP, EEPROM) MCU - Micro Controller Unit (CPU) TFS - File System from Samsung (Transactional File System) CSC - Customer Software Configuration Package CTS - Contents Package CSI - Call Stack Information LPD - Language Package Data AMSS - Advanced Mobile Subscriber Software (QualComm) APPS - Application Store (BREW, Bada, Qualcomm) APP - Application RSRC - Resources FS - File System FFS - Flash File System LFS - Large block flash File System PFS - Preset File Set FOTA - Firmware Over The Air PTT - Partition Table RAM - Random Access Memory PRAM - Phase Change Memory (Perfect RAM) New Flash Memory Technology from Samsung NAND - Flash Memory Type (Mass Storage, Block Read/Write/Erase) NOR - Flash Memory Type (Random Read/Write, Block Erase) IND - India SEA - South East Asia MEA - Middle East and Africa EMEA - Europe, Middle East and Africa E2P File: B3410_358575-03-xxxxxx-3_E2P.bin 1st Boot Failed: E2P File: B3410_358575-03-xxxxxx-3_E2P.bin MCU Id: 5B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] E2P IMEI Patched Ok: 358575-03-171657-3 File CRC: 0x20B28C12 E2P Write Done, 2097152 byte(s), Time: 00:32 |
100% orijanal flash file br prashant |
This problem is also eeprom problem use another box write a new eeprom and with hwk write the three flash file not 2 (mcu+tfs) |
plase help me how fllash samsung t339 |
