05-11-2009, 18:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | w850 flash problem with hwk MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 52 RED IMEI : 352401-01-436027-0 CD_PAF : 1 0 1 OTPCID : 49 RED CID_UP : 4952 P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 IMAGE : W850_R1KG001_MAIN_CXC1250200_CY_RED53.bin FLSH_ID: 897E [Intel SIBLEY] Certificate Warning, SSW_CID Mismatch: 53<>52 Certificate Error F.2: -10 FlashImage Certificate Rejected Flashing Failed, 00:05 SHUT DOWN FL ... |
05-12-2009, 12:55 | #6 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 98122 HID: E7D6D4E541600054 HWK: A1.04-PRO1 Licence: True, 00:11 MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 52 RED IMEI : 352401-01-436027-0 CD_PAF : 1 0 1 OTPCID : 49 RED CID_UP : 4952 P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 IMAGE : W850_R1KG001_MAIN_CXC1250200_CY_RED53.bin FLSH_ID: 897E [Intel SIBLEY] Certificate Warning, SSW_CID Mismatch: 53<>52 Certificate Error F.2: -10 FlashImage Certificate Rejected Flashing Failed, 00:05 SHUT DOWN FL ... MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 52 RED IMEI : 352401-01-436027-0 CD_PAF : 1 0 1 OTPCID : 49 RED CID_UP : 4952 CXC_NR : cxc1250489 R1EJ001 CDA_NR : CDA102568/1 R2A P_LOAD : 070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 FINISH CS ... Upgrade to CID 53 Done, 00:58 MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 52 RED IMEI : 352401-01-436027-0 CD_PAF : 1 0 1 OTPCID : 49 RED CID_UP : 4952 CXC_NR : cxc1250489 R1EJ001 CDA_NR : CDA102568/1 R2A P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 FLSH_ID: 897E [Intel SIBLEY] P_LOAD : 070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 U_LOCK Set to: 0000 SHUT DOWN CS ... USB Opened MCU_ID : 99000301FFFFFFFF P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 52 RED IMEI : 352401-01-436027-0 CD_PAF : 1 0 1 OTPCID : 49 RED CID_UP : 4952 CXC_NR : cxc1250489 R1EJ001 CDA_NR : CDA102568/1 R2A P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 IMAGE : W850_R1KG001_MAIN_CXC1250200_CY_RED53.bin FLSH_ID: 897E [Intel SIBLEY] Certificate Warning, SSW_CID Mismatch: 53<>52 Certificate Error F.2: -10 FlashImage Certificate Rejected Flashing Failed, 00:00 SHUT DOWN FL ... USB Closed |
05-12-2009, 14:12 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
02-13-2010, 17:57 | #10 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1235361 Status: Offline Thanks Meter: 0 | problem flashing and unlocking w850 with hwk hi all, i am new to this forum and also new to mobile software field. i just started a setup. ur cooperation is appreciated plz. i just unlocked and flashed se w850 using hwk but the problem did not solve and it showed insert correct sim card and a dull lcd. the box shows following msg: MSG AFTER FLASHING UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 91193 HID: 15677A2900270026 HWK: A1.04-PRO1 Licence: True, 00:12 MCU_ID : 99000301FFFFFFFF S_BAUD : 921600 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 49 RED IMEI : 352826-01-348918-0 CD_PAF : 1 0 1 OTPCID : 49 RED CID_UP : 4949 CXC_NR : cxc1250489 R1ED001 CDA_NR : CDA102677/51 R9A P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 IMAGE : W850_R1ED001_MAIN_CHINA_CY_RED49.bin FLSH_ID: 897E [Intel SIBLEY] WRITTEN: 455 Block(s), 08:33 IMAGE : W850_R1ED001_FS_HONG_KONG_RED49.bin FLSH_ID: 897E [Intel SIBLEY] WRITTEN: 241 Block(s), 04:31 Flashing Done, 13:07 SHUT DOWN FL ... MESSAGE AFTER UNLOCKING: U_LOCK SET TO: 0000 SHUT DOWN CS.... Plz advise. What is Shut down CS.... and Shut down FL... |
BB5 flashing problem with hwk ufs3 | dey mobiles | HWK | 2 | 09-30-2009 02:16 |
6630 Flashing Problem with HWK | kabirhossain | HWK | 2 | 11-12-2007 05:30 |
6280 Flashing Problem With Hwk | aseemvizag | Nokia Base Band 5 ( BB-5 ) | 4 | 03-21-2007 12:13 |
6630 flashing problem with HWK | gokul2005 | Nokia Base Band 5 ( BB-5 ) | 5 | 06-21-2006 10:28 |
