03-07-2022, 17:14 | #1664 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Pakistan Age: 39
Member: 693282 Status: Offline Sonork: 100.1602586 Thanks Meter: 41 | HWK Upgrade Server Status:- Online https://www.youtube.com/watch?v=qAK4bFlTpDE Welcome to MRGSM Solution Channel. This is Mobile science Hub for updating Mobile Flashing Rooting Download These Files For UFS HWk live again 1.UFSx_Support_Suite_Setup_v02.03.00.07.exe https://ouo.io/VAt8QJ7 https://depositfiles.com/files/1u0syjh29 2.UFS_PANEL_2.7.0.8 https://ouo.io/jJ8Qgou 3.UFS_HWK_UFST_Offline_by_localizator PAss:localizator256 https://ouo.io/eyOQAmz 1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Switch to the "Hardware" Tab 6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" - Make sure "Box Status" = "True" or "Bad Software" and "Server Status" = "Support Ok", before proceeding 10. Switch to the "Software" Tab 11. Amend "Application Install Path" and/or "Nokia Install Path", if required. 12. Click "Check Server" 13. Click "Install" 14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install atleast 1 item at step 13) How to install same UFSx+HWK to 2nd PC. Same as above and you must complete ALL steps. How to add further UFSx+HWK after initial install. Steps 4-13 as above DHLT Files Should be extracted and installed too:- C:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT for 32bit PCs C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\_DHT for 64bit PCs |
The Following User Says Thank You to malik_moon For This Useful Post: |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
