05-19-2017, 10:44 | #1021 (permalink) |
Freak Poster Join Date: Jul 2006 Location: W-no
Member: 310418 Status: Offline Thanks Meter: 13 | UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXX HWK Preset 2 Error: 00, -4 HID: , HWK: NOT CONNECTED 45 Fatal: Bad HWK Module BOX: CORRUPTED or MANIPULATED Your IP: 89.XXX.0.6 Support: Bad HID, Cannot Access Support REST: Ok UFSx: UFS3 SarasSoft, USB S/N: XXXX NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: XXXX LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: XXXXX HWK Preset 2 Error: 00, -4 HID: , HWK: NOT CONNECTED 45 Fatal: Bad HWK Module BOX: CORRUPTED or MANIPULATED What can cause this problem ? |
05-19-2017, 11:18 | #1022 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Open the box, remove your HWK, clean the pins and socket and re-insert and try see if it works. If not then your HWK is dead and needs to be replaced. |
The Following 3 Users Say Thank You to Odia The Ultimate For This Useful Post: |
05-20-2017, 22:26 | #1024 (permalink) |
Freak Poster Join Date: Oct 2009 Location: Germany
Member: 1131303 Status: Offline Thanks Meter: 328 | App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 8513 Serial: 135xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 0 0 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 135xxx HWK Preset 1 Error: 00, 0 BOX_AUTH_ERROR: 156 BOX: CORRUPTED or MANIPULATED Bad IX: ABCD Failed: -5 Your IP: 37.xxx.xxx.45 Support: Bad HID, Cannot Access Support Something Wrong, Try to Use [Update Box] Box: 1 Location: 8513 Serial: 135xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 0 0 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 135xxx HWK Preset 1 Error: 00, 0 BOX_AUTH_ERROR: 207 BOX: CORRUPTED or MANIPULATED Your IP: 37.xxx.xxx.45 Support: Bad HID, Cannot Access Support REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 135xxx NVML: Ok INIT FBI Failed: 2 Whats wrong here ? |
05-21-2017, 16:26 | #1025 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Poland Pruszków-Warszawa-Warka
Member: 290272 Status: Offline Thanks Meter: 431 | I did restore settings on windows and it does not work now. Prior to restore everything worked. Code: Last Server Update: 2016/03/30 Active Panel Version: 2.3.0.7 App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 4641 Serial: 77xxx Boot Id: 62 CF Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 4641 Serial: 77xxx Boot Id: 62 CF Box Login Failed Fatal LOGIN Error, Need Repair Box, Contact Distributor |
05-26-2017, 18:44 | #1029 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 None of Boxes Detected, Use: [Scan Boxes] App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 4403 Serial: 91xxx Boot Id: 62 CF Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] |
05-27-2017, 10:00 | #1030 (permalink) | |
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | Quote:
Fixed by self. Thanks to me | |
The Following User Says Thank You to nomi_42us For This Useful Post: |
06-02-2017, 05:09 | #1032 (permalink) | |
Major Poster Join Date: Sep 2014
Member: 2255200 Status: Offline Thanks Meter: 9 | fake solution Quote:
my new box ufst box login failed before ten days working fine but now a days problemyour solution is not good pls correct solution ufst team App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 1127010 Serial: TMA10xxxxxx Boot Id: 54 4D Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] | |
06-03-2017, 06:22 | #1034 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1543115 Status: Offline Sonork: wawan gunawan Thanks Meter: 0 | Please master his solution Box: 1 Location: 135953 Serial: 10xxxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 10xxxx LIC: True Your IP: 101.255.86.42 Support: Bad HID, Cannot Access Support REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 10xxxx NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 10xxxx LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 10xxxx LIC: True -16please reinstall support suite Please master his solution |
06-06-2017, 20:18 | #1035 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2670269 Status: Offline Thanks Meter: 0 | i have my box ... ufs " orginal " for 8 years ... without any little dust ... but last month i connect ... " best " infinity key ... and use my lovley box .. as com ... may be for that my hwk damage ... i wait new panel version ,,, or buy new hwk .. if it still exists .. in market .... and iwill use old " fake ufs " as a " com " for infinty key ... this is safe for me and all ... take it like advice ... thanks . |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
