Some bugs and problems Samsung SGH-P730 In Samsung module at cable its precised T_18 pin but need T_28 In support i downloaded P730XXDJ2.zip thre times to be shure (CRC check failed at extract or test) Testing ... Current Location part 1 offset 26938366 Archive: D:\uTorrent\full\P730XXDJ2.zip 26938388 bytes 2008-09-28 18:23:32 End central directory record PK0506 (4+18) ========================================== current location of end-of-central-dir record: 26938366 (0x019b0bfe) bytes expected location of end-of-central-dir record: 26938366 (0x019b0bfe) bytes based on the size of the central directory of 58 and its relative offset of 26938308 bytes part number of this part (0000): 1 part number of start of central dir (0000): 1 number of entries in central dir in this part: 1 total number of entries in central dir: 1 size of central dir: 58 (0x0000003a) bytes relative offset of central dir: 26938308 (0x019b0bc4) bytes zipfile comment length: 0 Current Location part 1 offset 26938308 Central directory entry PK0102 (4+42): #1 ====================================== part number in which file begins (0000): 1 relative offset of local header: 0 (0x00000000) bytes version made by operating system (00): MS-DOS, OS/2, NT FAT version made by zip software (20): 2.0 operat. system version needed to extract (00): MS-DOS, OS/2, NT FAT unzip software version needed to extract (20): 2.0 general purpose bit flag (0x0002) (bit 15..0): 0000.0000 0000.0010 file security status (bit 0): not encrypted extended local header (bit 3): no compression method (08): deflated compression sub-type (deflation): maximum file last modified on (0x00003147 0x0000aba3): 2004-10-07 21:29:06 32-bit CRC value: 0x7bcc7d72 compressed size: 26938266 bytes uncompressed size: 73066284 bytes length of filename: 12 characters length of extra field: 0 bytes length of file comment: 0 characters internal file attributes: 0x0000 apparent file type: binary external file attributes: 0x00000020 non-MSDOS external file attributes: 0x000000 MS-DOS file attributes (0x20): arc Current Location part 1 offset 26938354 filename:P730XXDJ2.s3 Current Location part 1 offset 0 Local directory entry PK0304 (4+26): #1 ------------------------------------ operat. system version needed to extract (00): MS-DOS, OS/2, NT FAT unzip software version needed to extract (20): 2.0 general purpose bit flag (0x0002) (bit 15..0): 0000.0000 0000.0010 file security status (bit 0): not encrypted extended local header (bit 3): no compression method (08): deflated compression sub-type (deflation): maximum file last modified on (0x00003147 0x0000aba3): 2004-10-07 21:29:06 32-bit CRC value: 0x7bcc7d72 compressed size: 26938266 bytes uncompressed size: 73066284 bytes length of filename: 12 characters length of extra field: 0 bytes Current Location part 1 offset 30 filename:P730XXDJ2.s3 Current Location part 1 offset 42 Testing P730XXDJ2.s3 CRC check failed At least one error was detected in D:\uTorrent\full\P730XXDJ2.zip. |
When i can download the P730XXDJ2.zip from support whitout crc problems ? |
