Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 11-03-2018, 09:30   #4756 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,072
Samsung E1205T Write firmware Done :)
MCU File: E1205TJP.cla CRC32: 85B3BCAF
E1205TJP.cla
TFS File: E1205TJPLD2.tfs CRC32: 75336D48
CFG File: E1205TJPLD2.cfg 7445 byte(s)
CSC File: E1205TOJPLD1.csc CRC32: BC4C1CBB
Regions : Arabic
Language: ar,en,fr(fa,ur)
Release : 2012 April Rev: 1
CCF File: E1205TOJPLD1.ccf 9826 byte(s)
LPD File: E1205TOJPLD2.lpd CRC32: 85795C50
Connect Cable to Switched Off Mobile (with battery)
Preloader Ok F8, 921600 Baud
Flsloader Ok
FLASH Id: Fidelix, FM25M64A
Erase Done, 40 sector(s), Time: 00:10
MCU MSL Patched Ok, Time: 00:03
File CRC: 0xCF6BB109
MCU Write Done, 4041760 byte(s), Time: 03:19
File CRC: 0x6AA05149
LPD Write Done, 786432 byte(s), Time: 00:38
File CRC: 0x75336D48
TFS Initialised: 1
TFS Version: TFS4.0_CORONA_01
Directories: 20
Max_Files  : 91
Files_Count: 91/91
Files Closed
TFS Unmounted
TFS Write Done, 509015 byte(s), Time: 00:29
CSC Format Done, Time: 00:06
File CRC: 0xBC4C1CBB
Directories: 29
Max_Files  : 107
Files_Count: 107/107
Files Closed
CSC Unmounted
CSC Write Done, 229949 byte(s), Time: 00:24
Old 12-04-2018, 08:53   #4757 (permalink)
Member: 654997
Thanks Meter: 4,072
Nokia 1208 Write Flash Done :)
1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.3.0.3]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
Algorithm: u3_intel.fia, Ver: 4.80.0
Algorithm Ok, MSID: 8485B6FDF126EC259C814CCA40
Decoded MSID: 3E4EBAE9-00D7BB50-A8000000
Encoded FAID: 76207A67-80082CBC-9B8A2EA0
IMAGE: rh105_06.000
Erasing: 0x01000000-0x0100FFFF ...
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Erasing: 0x01010000-0x013AFFFF ...
Area2: 0x01010000-0x013AFFFF Erased, Time: 00:38
Erasing: 0x013B0000-0x013EFFFF ...
Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:20
IMAGE: rh1050_nai6.00ia
Erasing: 0x01380000-0x013AFFFF ...
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:02
CNT Flashing Completed, Time: 00:01
Extracting Contents Package ...
Running:  Server fake reply for CUI phone.
Contents Package Extracting Ok, Time: 00:10
Algorithm Ok, MSID: 84731DDC63B285305118F06EFF
Decoded MSID: 3E4EBAE9-00D7BB50-A9000000
Encoded FAID: 6E2D7D8F-70666477-6B792404
IMAGE: rh105_06.00ia
Erasing: 0x01240000-0x0124FFFF ...
Area1: 0x01240000-0x0124FFFF Erased, Time: 00:00
Erasing: 0x01250000-0x0137FFFF ...
Area2: 0x01250000-0x0137FFFF Erased, Time: 00:13
PPM Flashing Completed, Time: 00:10
Flashing Completed, Rebooting Mobile
Set UI Defaults ...
UI Defaults Ok, Time: 00:03
Set UI Factory Defaults ...
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults ...
Set Full Factory Defaults Ok, Time: 00:01
Set Software Upgrade Defaults ...
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security 12345 ...
Set Security Ok, Time: 00:00
MCU SW  : V 6.00 30-09-09 RH-105 (c) NMP
PPM SW  : V 6.00 30-09-09 RH-105 (c) NMP IA
Prd.Code: 0561971
Bpr.Code: 0571405
Prod.Sn : INM261745
HW Vers : 2602
UEM     : 1328
UPP     : 8850 [2292]
RFIC Ver: 0700
DSP Vers: ICPR62_08w31_UPP
LCD Type: TPO:NAXvD6 ST7628
IMEI    : 351956-03-793194-4
SL Conf : 234-00-00300000000
SL Prof : 800000000001000-2
SL Var  : 00003519560379319400
SL Aux  : 000B0000
HW Sig  : AF56E43E2DF9E291
Box Id  : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Virgin (some 3510i);United Kingdom
Old 12-04-2018, 14:44   #4758 (permalink)
Member: 2880485
Hi.. Can you assist to unlock a Samsung Galaxy S9?
Old 01-10-2019, 09:55   #4759 (permalink)
Member: 654997
Thanks Meter: 4,072
Samsung E1205T write firmware Done :)
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 1038xx
HID: 6754xxxxxxxx, HWK: A1.04-PRO1
Licence: True
AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft  Build 71
LogFile: .\_!_LOG\103896_2019_01_10_13_43_09_LOG.txt
Loaded Settings from: Sams.ini
E1205TJP.cla
Regions : Arabic
Flsloader Ok
Erase Done, 40 sector(s), Time: 00:11
TFS Initialised: 1
Directories: 20
Max_Files  : 91
Files_Count: 91/91
Files Closed
TFS Unmounted
TFS Write Done, 509015 byte(s), Time: 00:26
Directories: 29
Max_Files  : 107
Files Closed
CSC Unmounted
CSC Write Done, 229949 byte(s), Time: 00:23
Old 01-12-2019, 10:35   #4760 (permalink)
Member: 163036
Thanks Meter: 2
Unhappy It is possible ???
Licence: True
E1205TJP.cla
Regions : Arabic
Flsloader Ok
TFS Initialised: 1
Directories: 20
Max_Files  : 91
Files_Count: 91/91
Files Closed
TFS Unmounted
Directories: 29
Max_Files  : 107
Files Closed
CSC Unmounted
How is it possible to flash any phone. My HWK/Tornado does not work
How i can run it or update ???
Can you help me ???
Old 01-14-2019, 21:47   #4761 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
Can you help me ???
Download the offline installer for the UFS and follow the instruction to install.
Old 09-27-2019, 07:47   #4762 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,437
1st Boot: Ok, DCT4, UPP: 2292 [] [2.3.0.3]
Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF
Algorithm: u3_amd.fia, Ver: 4.79.0
Rebooting Mobile
MCU SW : V 5.80 14-11-08 RH-105 (c) NMP
PPM SW : V 5.80 14-11-08 RH-105 (c) NMP IJ
Prd.Code: 0549906
Bpr.Code: 0582127
Prod.Sn : HID770585
HW Vers : 1621
UEM : 1328
UPP : 8850 [2292]
RFIC Ver: 0700
LCD Type: SDI:NAXv89 S6B33BD
IMEI : 358243-03-576111-7
SL Conf : 001-01-00000000000
SL Prof : 000000000001000-2
SL Var : 00003582430357611100
SL Aux : 000B0000
HW Sig : 0ADFDF084120D828
Provider: GSM Test Equipment
Algorithm Ok, MSID: 84383598C4B9447B00F68DC9D6
Decoded MSID: 3E4EBAE9-00C94932-A8000000
Encoded FAID: 8ED4E755-2BED923B-F993DAFE
IMAGE: rh105_06.000
Area2: 0x01010000-0x013AFFFF Erased, Time: 00:23
Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02
MCU Flashing Completed, Time: 00:13
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01
CNT Flashing Completed, Time: 00:00
Contents Package Extracting Ok, Time: 00:06
Algorithm Ok, MSID: 845ABC05E492FFC194F19B7050
Decoded MSID: 3E4EBAE9-00C94932-A9000000
Encoded FAID: D636F63D-CD1F118A-B7C9319A
Area2: 0x01250000-0x0137FFFF Erased, Time: 00:07
PPM Flashing Completed, Time: 00:07
Set Full Factory Defaults Ok, Time: 00:04
Old 08-10-2020, 14:40   #4763 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Samsung gt-s3802 user lock read
Licence: True
LogFile: .\_!_LOG\79332_2020_08_10_19_03_49_LOG.txt
Software: S3802DDMC3/S3802ODDMC5
Regions : India
Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te)
Release : 2013 March Rev: 5
ProdCode: GT-S3802CWAINU
IME1: 355433-05-++++++
IME2: 355434-05-++++++
S/N : RZ1D62M9MG
BTID: 781FDB-70D170
ULCK: 0987
Level Of Lock: 00h
Error when Extracting Codes
Old 09-10-2020, 16:08   #4764 (permalink)
Slavonac's Avatar
Member: 27001
Thanks Meter: 32
Change box , buy another one :-)
Old 09-18-2020, 15:44   #4765 (permalink)
Member: 237256
Thanks Meter: 92
Can you help me ???
Yes, download offline installer but you must obtain box update and hwk license online first, while you do the rest manually with the offline installer.
Old 01-16-2021, 08:54   #4766 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Samsung e1207t blinking solve old box
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 79???
HID: D09CEAD7?????????, HWK: A1.04-PRO1
Licence: True
LogFile: .\_!_LOG\79???_2021_01_16_13_03_03_LOG.txt
LPD File: E1207TODDLJ2.lpd CRC32: AAB1BFA0
TFI File: E1207TODDLJ2.tfi CRC32: 32EA0040
MCU File: E1207TDDLL1.cla CRC32: E3719815
Regions : India
Release : 2012 December Rev: 1
Regions : India
1st Boot Failed: Preloader not Run
Flsloader Ok
File CRC: 0xB1D9CE24
MCU Write Done, 4856644 byte(s), Time: 04:25
File CRC: 0xC5166338
LPD Write Done, 1048576 byte(s), Time: 00:57
File CRC: 0x32EA0040
TFI Write Done, 1900544 byte(s), Time: 01:41
Successfully unlocked/repaired phones by Infinity-Box Infinity-Box Infinity-Box 76760 Today 07:50
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX kabirhossain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3969 10-05-2016 05:13
jazz t161l Successfully Unlocked/repaired Phones By infinity box honey_bbc2001 Chinese Models & Cloned Phones 0 07-07-2009 07:23
Page generated in 0.22921 seconds with 10 queries
