05-15-2017, 11:19 | #1 (permalink) |
Crazy Poster Join Date: Sep 2003 Location: Poland
Member: 40299 Status: Offline Thanks Meter: 3 | UFS HWK death suddenly I write this post a second time. Earllier was delete. When I want use box in UFSx (HWK) Control Panel v 2.3.0.7 i get this info: Check Box: App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 82 Serial: 78217 Boot Id: 62 CF Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] Update Box: Box: 1 Location: 82 Serial: 78217 Boot Id: 62 CF Box Login Failed Fatal LOGIN Error, Need Repair Box, Contact Distributor Box is oryginal product, I have it from 7-8 years. There was no problem with him until now. Please, guess what I have to do with him to raise him. |
05-16-2017, 07:52 | #3 (permalink) |
Member: 40299 Status: Offline Thanks Meter: 3 | Thanks Odia for you answer. I resolder all of component on ufs pcb and HWK pcb and letter clean all from flux and dry. But nothing change. I thought this is a server error with my box not working and not a hardware malfunction. But if you say this is a bug on the box then I'm going to look for a pcb vulnerability. Thanks for You help. |
05-28-2017, 22:48 | #5 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
06-02-2017, 05:12 | #6 (permalink) | |
Major Poster Join Date: Sep 2014
Member: 2255200 Status: Offline Thanks Meter: 9 | sir ji give me correct solution Quote: my ufst box working well but last ten days ufst box not started always box login failed here is screen log App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 1127010 Serial: TMA10845004 Boot Id: 54 4D Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] | |
06-02-2017, 05:17 | #7 (permalink) | ||
Member: 2255200 Status: Offline Thanks Meter: 9 | sir ji give me correct solution Quote: Quote: App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 1127010 Serial: TMA10845004 Boot Id: 54 4D Box Login Failed Bad IX: ABCD Failed: -102 HID Number Corrupted, Try to Use [Update Box] | ||
