UFS HWK Latest 2019 100% Working Solution UFS HWK Latest 2019 100% Working Solution Step 1. Download the Software from Here UFS Offline Firmwares-Download Here UFS_PANEL - Download Here Step 2. Extract the Offline Firmwares copy and paste in C:\Program Files Step 3. Now install ufs Driver and connect your box Step 4. Now go back to the folder extract and run (UFS_PANEL_2.3.0.9) as an Administrator. Step 5. Wait until the Popup Message Appear something like (Cannot Find Saver1, Continue Without?) then Simply press (Yes). Step 6. Now Press on (Scan Boxes) and wait until appear your UFS Box appear. Step 7. Now Press on (Check Box) and wit until check the box and appear message. Step 8. Now Press on (Update Box) and wit until The box will update and show the message that Authentication Successful. Upgrade client is up-to-date. Upgrade process completed. Step 9. Now Again Repeat the Step 7 and wait to complete the process. Step 10. Now you have to Click or choose Software Tab (Located in Top Left). and then Click (Install / Auth.) Once you click (Install / Auth.) The message will appear that. Paths Updated Software Authorised Done:- Br Absar_Global https://i.postimg.cc/y6Qzhb8v/K8Fh2lgC.gif |
link not working plz avoid to fake post |
i am try link working |
Link Now Working But Solution Fake |
thanks bro..........100% done.. |
https://drive.google.com/file/d/1lWv...ew?usp=sharing |
Daily try But No luck for me |
for me also not working,after searching for server2 ,still check box and update box are hidden |
same issue i face means searching server 2...... https://pasteboard.co/Ic5W8Jg.jpg i think offline not work now |
*** bless you. working.. |
not work Box: 1 Location: 274 Serial: 73556 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 73556 HWK Preset 1 Error: 00, 0 BOX_AUTH_ERROR: 52 BOX: CORRUPTED or MANIPULATED -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use [Update Box] to authorise UFS. UFSx: UFS3 SarasSoft, USB S/N: 73556 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 73556 LIC5: False REQ FBI Failed ! |
thanks bro..........100% done! |
searching for server2, not working |
