Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 02-21-2018, 08:17   #1 (permalink)
Crazy Poster
Member: 2397479
Thanks Meter: 64
UFS Panel 2.3.0.8 upgraded and working good 21/2/2018
UFS HWK 2018 Full working.
Password: gsm.xraxx
Link1: https://www.4shared.com/s/fC6A_iLYEca
Link2: http://*******/2GvFPnr
Br,
Gsm_Flasher
The Following 26 Users Say Thank You to Arbelood For This Useful Post:
Old 02-21-2018, 09:53   #2 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 438
All panals with fresh win work
Sent from my PRA-LA1 using Tapatalk
The Following User Says Thank You to helpo For This Useful Post:
Old 02-21-2018, 10:47   #3 (permalink)
Member: 1738164
Sonork: 02582f199295e049a384ace29
Thanks Meter: 14
thank you for this
im waiting for so long .. now i try this to my hkw box
my hwk box its to long sock i never use when the server is offline i never been update. ever.
i hope is this is working
The Following User Says Thank You to nebres jren For This Useful Post:
Old 03-03-2018, 17:12   #4 (permalink)
m4m
Member: 126208
Thanks Meter: 52
Password: gsm.xraxx
Br,
Gsm_Flasher
can you upload it to mediafire or google drive please
thank you
The Following User Says Thank You to m4m For This Useful Post:
Old 03-04-2018, 10:47   #5 (permalink)
Member: 333298
Thanks Meter: 24
another link
UFS_PANEL_2708
The Following 5 Users Say Thank You to yago98 For This Useful Post:
Old 03-08-2018, 10:30   #6 (permalink)
Member: 1297331
Thanks Meter: 2
password prrotected plz password
The Following User Says Thank You to shadab0038 For This Useful Post:
Old 03-09-2018, 10:33   #7 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602
Thanks Meter: 1,349
Arrow Password: gsm.xraxx
here.............................................. ..
Password: gsm.xraxx
The Following 5 Users Say Thank You to vishnudatt For This Useful Post:
Old 05-01-2018, 06:46   #8 (permalink)
Member: 780451
Thanks Meter: 42
only hwk update where is setup
server always offline
pls help
The Following User Says Thank You to MDAKHAN For This Useful Post:
Old 05-07-2018, 11:14   #9 (permalink)
Member: 2482823
Thanks Meter: 2
good
now it is working with me
The Following User Says Thank You to b.k85 For This Useful Post:
Old 05-07-2018, 11:33   #10 (permalink)
Member: 2482823
Thanks Meter: 2
good
Old 05-07-2018, 12:10   #11 (permalink)
Member: 1723223
Sonork: 100.1649485asad297
Thanks Meter: 21
Error PLEASE REINSTALL HWK SUPPORT SUITE SHOW THIS PROBLEM
The Following User Says Thank You to asad297 For This Useful Post:
Old 05-07-2018, 12:25   #12 (permalink)
Member: 1723223
Thanks Meter: 21
show this problem https://ibb.co/iMKNjS
Old 05-07-2018, 16:43   #13 (permalink)
Member: 2754910
Thanks Meter: 76
Thumbs up Problem in Installation of UFS HWK Latest 2018? Solved :)
Dear Assalamu Aleikum Warahmathullahi Wabarakathuhi
to whom it's showing the error of (Please Reinstall HWK) or Bad Installation and or None Authorized /AuthonticPath Problem/ Use Original tool when connecting in to the box with software kindly follow my instruction below
Step 1.
Download the Software from this link.
Download Here
Step 2.
Extract the Download file and Run (UFSx_Support_Suite_Setup_v02.03.00.07) setup then finish the installation without ticked the run software (unticked the check box and click finish the installation).
Step 3.
Now Connect Your UFS Box and wait a little to install the Driver Automatically.
Step 4.
Now go back to the extracted folder and run (UFS_PANEL_2708) as an Administrator.
Step 5.
Wait until the Popup Message Appear something like (Cannot Find Saver1, Continue Without?) then Simply press (Yes).
Step 6.
Now Press on (Scan Boxes) and wait until appear your UFS Box appear.
Step 7.
Now Press on (Check Box) and wit until check the box and appear message.
Step 8.
Now Press on (Update Box) and wit until The box will update and show the message that
Authentication Successful.
Upgrade client is up-to-date.
Upgrade process completed.
Step 9.
Now Again Repeat the Step 7 and wait to complete the process.
the message will be
None Authorised Copy of Software Detected, Reinstall
Bad TX: AB1D
Failed : 100
Wrong Installation, Try to Use [Install / Auth.] in Software Page.
Also you can noticed in the Box Status it will show the Bad Software or Updated only
Step 10.
Now you have to Click or choose Software Tab (Located in Top Left). and then Click (Install / Auth.)
Once you click (Install / Auth.) The message will appear that.
Paths Updated
Software Authorised
Step 11.
Finally Repeat the (Step 6 and Step 7) then check your Box Status will be True. Now close the Ufs Panel and Copy the Extracted Nokia and Sarasoft Folder in to Drive C:\Program Files\ and Skip the Same folders Copying only.
Your Done
Only Press Thanks Button and Du'a/Pray for me Jezakallah
The Following 69 Users Say Thank You to UniverCellSoft For This Useful Post:
Old 05-07-2018, 16:45   #14 (permalink)
Member: 2754910
Thanks Meter: 76
pls help
Dear Find the Post #13
Old 05-07-2018, 16:45   #15 (permalink)
Member: 2754910
Thanks Meter: 76
Dear Find out the Post #13
The Following 2 Users Say Thank You to UniverCellSoft For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.19086 seconds with 8 queries
