same problem. i can't use my box! any solution? |
PROBLEM ? what is this i use offline set up 2 years ago till 2 weeks ago " now " Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
same problem.. LIC: True Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
server on this time all ok |
server down............. |
Where is link plezzz |
Guys is there trusted way to install it offline all pervious ways is not successful Sent from my INE-LX1 using Tapatalk |
UFS Panel 2.3.0.9 Tested http://www.mediafire.com/file/3lp4nm804mfqj0z/%255BGrahaFlasher.COM%255D_UFS_PANEL_2.3.0.9.rar/file |
tested its working again :) great job |
please someone should tell me is the server down ? I cant download the setup everything about my box is ok App: UFSx (HWK) Control Panel v 2.3.0.9 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok All is Ok, not Need to Update Box or Support |
[QUOTE=albert maren;14166986]please someone should tell me is the server down ? I cant download the setup everything about my box is ok App: UFSx (HWK) Control Panel v 2.3.0.9 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok All is Ok, not Need to Update Box or Support[/QUO Albert you are almost done. Open support panel and do CHECK AND NEXT INSTALL/AUTH Your result should be: Paths Updated Software Authorised Once you get the above result know that your license has been dropped in to your pc registry. Next manually install software by unzipping(UFS3 PANEL 2.7.0.8 AND ALL SOFTWARE) into the path PROGRAME FILE/NOKIA/PHOENIX/PRODUCT and the second one PROGRAMME FILE/SARASOFT/UFS Now run any software of your choice and it will connect and work. |
