06-08-2009, 00:25 | #31 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 08/06/2009 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. UFS_DCTxBB5 v2.0.8.5 ---------------------- 1. New BB5 products: RM-412,RM-413,RM-443,RM-505,RM-506,RM-507,RM-570 (E75-1,E75-2,6303c,N97-1,N97-5,N97-3,6600i-1) 2. Introducing RAPU-YAMA ASIC: RM-368,RM-431,RM-432,RM-470 (6260s-1,5630d-1,5630d-1b,6700c-1) support added. 3. New DCT4+ products: RH-512,RH-513,RH-514,RH-515,RH524,RH-525,RH-543 (2330c-2,2330c-2b,2320c-2,2320c-2b,5030c-2,5030c-2b,2323c-2) 4. New DCT4+ UNL versions support: RH-99 v5.91, RH-100 v5.80, RH-105 v5.91, RH-106 v5.80, RM-305 v5.91 (1200, 1200b, 1208, 1208b, 1650) 5. Certificates write error in DL mode fixed. 6. Check is ASIC supported by firmware for DCT4 and WD2 products. 7. Read UEM IMEI or ESN for DCT-4/WD2 ASIC 2,5,6,11 when Rd UEM. 8. Added backup of PM 120 block when make Bk.308 (if exists) 9. Added [Skip Erase] option for BB5 products (for Experts Use Only) 10.Added [1331] option, to switch on/off NU48Fxxx Intel Chips Solution. Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. LG GSM V 2.0.8.5 ----------------- 1. MTK KG195,KP199,KP220 support added. 2. PCS files support added for MTK models. 3. Cable type indicator. SAMs V 2.0.8.5 --------------- TRIDENT B100K,C140i added (DUNL,IM,FL) TRIDENT VISION C3010,C3050,C3060R,C3110,C3110C,S3500 added (CUNL,IM,FL) M120,M128,E1040,S3030 added (DUNL,IM,FL) B520 Vodafone support added. (use B520B-V model, not mix with B520, filenames are similar) (Use [Reset MMI] if phone ask for password without SIM) New MSL bypass algo introduced (B220,..,C3050,E1410,S3500...) allows direct codes reading, unlock and IMEI repair. MSL Repair introduced, allows to repair or use alien E2P (Repair of "User Fault on Illegal Trial !!" and restore IMEI) OM(SYSOL) C160G added (DUNL,IM,FL,SECT) SWIFT B2100,C5212,E250i,F265L,F270,J700i,M158,P250,U800E ,X576 added (DUNL,IM,FL,SECT) SWIFT-AEROFONE B100i,B210 added (DUNL,IM,FL,SECT) C270,E1100,E1120,E1125W,E1125-SEA,E1210M,E1210S,E1310B, E1310M,E1310S,E1360B,E1360M,E2100,E2210 added (DUNL,IM,FL) (Do not mix B-C-M-L-S-T-EUR-SEA models! More info on support) B130S,B130T flashing fixed (blinking or frozen phone) (Must select target firmware as model, e.g. model is B130 and want to flash B130S, select B130S as the model.) SWIFT-3G P270 added (DUNL,FL,SECT,BT) QUALCOMM A777,M7600,M7603,M8800C,M8800L,S5600,S5603,S8300N added. [Write E2P] (NVM) added. UNLOCK and UNFREEZE added for these models: A411,A777,S7220, S7330,S8300,S8300C,Z230 (Use [QCDI Info] button to read keys) Old models UNLOCK and UNFREEZE: Z300,Z500,..,ZM60,.. (these are not in models list, select any model. Use [Mobile Info] button to read keys & [Unlock] to direct unlock) We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future. Conditions:- 1. Only 1 contributer per language. 2. You must know how to use the software and what each function does. 3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 Last edited by Odia The Ultimate; 06-08-2009 at 00:44. |
The Following 116 Users Say Thank You to Odia The Ultimate For This Useful Post: |
08-18-2009, 10:56 | #32 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 18/08/2009 Release Date: 18/08/2009 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite. You MUST update your HWK using client 2.0.9.0, old client versions will no longer work. You MUST be running HWK software 2.0.9.0 to access support. UFS_DCTxBB5 v2.0.9.0 ---------------------- 1. New BB5 products: RM-424,RM-465,RM-469,RM-481,RM-482,RM-483, RM-491,RM-504,RM-518,RM-547,RM-555,RM-561,RM-564,RM-566,RM-602 (6720c-1,5730s-1,E52-1,E52-2,E55-1,E55-2,6710s-1,5530c-2,3720c-2, 6730c-1VF,N97-4,2700c-2,6720c-1b,6730c-1,5800d) 2. New DCT4+ products: RM-519,RM-520 (2720a-2,2720a-2b) 3. New Samsung Flash Chip: 00EC2606 (K8S3215ETF) 4. Corrected VPL parsing for some models (N97) 5. Only NU48F256 left in [1331] option and moved to BB5 Tab. 6. SX4 bypass introduced using temporary NPC certificate erase. 7. [One Boot] option introduced (RAPx based One MCU products) 8. Enabled Files Multiselect, when Writing Certificates. 9. Erase Option for BB5 (for Experts Use Only !) Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. LG GSM V 2.0.9.0 ----------------- 1. Unlock Codes Display for Infineon EGOLD Voice added (Boot and See NCK Code for Instructions Press UNLOCK) SAMs V 2.0.9.0 --------------- TRIDENT T539 added (DUNL,IM,FL) TRIDENT VISION Fixed MSL algorithm for some models (C3050,...) SWIFT D606,D900E,E260,M2310,P220,S366,S5050,S5200 added(DUNL,IM,FL,SECT) SWIFT-AEROFONE B270i,C276,C276L,E1070M,E1070T,E1075,E1075L,E1105T ,E2100B, E2210B added (DUNL,IM,FL) QUALCOMM Manual Port Selection Added (Use Refresh, After Each Phone Reboot or Reconnect) (Untic QualComm Mode, Before Flashing) F480R,i6210,U900W added. UNLOCK and UNFREEZE added for these models: A736,A737,F490,G800,G800L,M7600,S5600,U900W,Z400,Z 540 We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future. Conditions:- 1. Only 1 contributer per language. 2. You must know how to use the software and what each function does. 3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 199 Users Say Thank You to Odia The Ultimate For This Useful Post: |
03-24-2010, 00:33 | #33 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 23/03/2010 Release Date: 23/03/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite. You MUST update your HWK using client 2.0.10.0, old client versions will no longer work. You MUST be running HWK software 2.0.10.0 to access support. UFS_DCTxBB5 v2.0.10.0 ----------------------- 1. New BB5 products: RM-381,RM-455,RM-468,RM-492,RM-529,RM-530,RM-570,RM-573,RM578,RM-579,RM-584,RM-599,RM-600,RM-635 (6750-1,6350-1b,5730s-2,6790s-1b,E72-2,E72-1,3208c,6760s-1,2730c-1,2730c-1b,E72-5,6790s-1c,E63-5,2690) 2. New DCT4+ products: RM-590,RM-591 (2220s-2,2220s-2b) 3. More DCT4+ added for unlock (ASIC 3168) see corresponding list. 4. McuSw tag fixed in vpl parser. 5. Fixed time-out bug for some RAPU models. 6. [Det.Log] CheckBox now active, can auto create LOG file. 7. [Info] Shows Camera DCC settings and Status (for both Cameras) 8. [PM Edit] Revised: Read/Write DCC, Simlock Data, Parallel Model. 9. Increased PM read default margins, to have DCC in read PM for DCT4+ 10.[Check Ask/Rpl] to Check Ask/Rpl files contents (Asic 2,5,6,7) 11.Fixed [Format] bug for new BB5 Symbian products. 12.ENO File flashing support (E63,E66,..,N97,..) 13.[Locks] for BB5 remade, now calculate codes for SLPA and SL20 14.[Check] Shows PASUBTOC SL related contents. Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. LG GSM V 2.0.10.0 ------------------ 1. MTK GB160,GB165,GB170,GB175,GB190,GB195,KG198 added. 2. Infineon GB101,GB109,GB110,GB125,GB130,KE858,KP108 added. 3. Infineon New Flash Chip SV7E3204UTA support. 4. ADI KG129,KG248,KG298 added. 5. " Cannot open file " Bug Fixed. SAMs V 2.0.10.0 ---------------- TRIDENT C158,C158B,C188L,C240L,C258,C260B,C260L,C260M,C300 B,E576,E758, X138,X180,X468P,X478,X568 added (DUNL,IM,FL) USB flashing introduced for HPE models (U600,.. Approx. 2x faster) TRIDENT VISION B3210,B3310,B3313,C3010S,C3050C,C3053,C3060,C3110H ,M620N, S3030C,S3500C,S3500H,S3500i,S3501C,S5150,S5150C added (CUNL,IM,FL) MSL3 bypass introduced (B3210,B3310,B3313,C3060,C3060R,...) USB UI functions introduced, allows to unlock USB only phones. USB flashing introduced (Approx. 5x faster) (Cannot use USB flashing of dead phones which have UL erased or damaged. RJ45 flashing can be used to recover from erased UL situation) SWIFT A177,A226,A227,A237,A257,B3410,B5702,B5712C,B5722, B5722C,C3212, C3510,C3518,C6112,C6112C,D980F,E200E,E208B,E250L,E 848i,F118, F278,J150B,M2710,M2710C,M2710L,M3510C,S3100,S3110, S3110C, S3600C,S3600H,S5200C,T219,T329,T729 added(UNL,IM,FL) Added ENG flashing for DUOS FOTA models (D988,B5712C,..) Auth. Boot and Firmware Sign. for Secure models (B5722,C3510,C6112,S3100) B5702,D988,F265L,S5050 (SECT) bug fixed. CSC Area format added. SWIFT-AEROFONE A137,CC01i,E1070C,E1100C,E1101C,E1107,E1113C,E1120 C,E1210, E1310C,E1310E,E1360,E1360C,E1360S,E2100C,E2210C,E2 210H added (DUNL,IM,FL) E1080,E1080C,E1080T,E1085,E1085L,E1085T,E1088C,E11 00H,E1150, E1150C,E1160,E2120,E2120B,E2120C,E2130 added (CUNL,FL) SWIFT-3G C5110,C5130,C5130S,C5130U,J800R added (CUNL,FL,SECT,BT) P270 (CUNL,SECT) bug fixed. E2P Write is supported only for C5130,C5130S and C5130U. QUALCOMM A551,A561,A637,A746,A747,A766,A767,A811,A821,A827, A836,A837, A867,C5220,C5510H,C5510U,G508,G508E,M7600B,M7600H, S5350, S5600B,S5600L,S5608U,S5510,S7120U,S7350C,S7350E,S7 350F, S7350H,S7350i,S7520U,S8300H,T469,T659,T749,T919,T9 29,U808 added. Fixed flashing of non page size aligned files (rc1,rc2,ffs) Added flashing support for QSC62xx models. UNLOCK and UNFREEZE added for these models: A551,A637,A767,A827,A837,C5220,F400,S5510,S7350,S7 350C, S7350F,S7350i,T639,Z170,Z240E,Z360,Z720,ZV40 BROADCOM QC Legacy BroadCom models introduced: i6220,S3650,S3650C,S3650M,S3650W,S3653,S3653W,S523 0,S5230G, S5230H,S5230M,S5230W,S5233A,S5233S,S5233T,S5233W,S 5560,S5560C, S7070 (CUNL,FL) To read codes use: [Mobile Info] button using USB Cable (Phone Switched-ON) and after [QCDI Info] button, using RJ45 Cable (Phone-OFF) QC Legacy BroadCom models Full Flashing (with BOOT Change) [BOOT Repair] for QC Legacy BroadCom models added. Boot Repair and Codes Read is possible only for phones with NM_20 pin USB/RJ45 connector ! COMMON Log to file added. CLONE error message fixed. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 220 Users Say Thank You to Odia The Ultimate For This Useful Post: |
03-24-2010, 23:04 | #34 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 24/03/2010 Release Date: 24/03/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. UFS_DCTxBB5 v2.0.10.1 ----------------------- 1. RM-392,RM-393 (2680s-2,2680s-2b) v6.17 unlock bug fixed. 2. Box Init bug after BB5 flash fixed. Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 128 Users Say Thank You to Odia The Ultimate For This Useful Post: |
03-27-2010, 15:36 | #35 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 27/03/2010 Release Date: 27/03/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. This release contains a new update client which you ONLY need to run if you have the message "None Authorised Copy of Software detected, Please Use Original Install Package:0" That means users without the message do not need to run this new update client, but if you do no harm will be done, you just lose 1 log. UFS_SAMs v2.0.10.2 -------------------- SWIFT-AEROFONE T239 added (CUNL,FL) BROADCOM Fixed UnFreeze Key Display. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 Last edited by Odia The Ultimate; 03-27-2010 at 18:09. |
The Following 140 Users Say Thank You to Odia The Ultimate For This Useful Post: |
05-12-2010, 21:11 | #36 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 12/05/2010 Release Date: 12/05/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. UFS_SAMs v2.0.10.3 -------------------- V 2.1.0.3 ------ TRIDENT M628N added (DUNL,IM,FL) SWIFT A256,J218,S3600i,S3601C added (UNL,IM,FL) SWIFT-3G B2703 added (CUNL,FL,SECT,BT) QUALCOMM A747,C5510,C5510U,T929 UNLOCK and UNFREEZE added. Improved Decryption algo, more models UNLOCK and UNFREEZE supported by Default. BROADCOM S5230K,S5230R added (CUNL,FL,BRP) B5310,S5620,S5628,S7070C added (FL) Use Samsung Kies drivers for these models (B5310,S562x) Fixed 'Cannot Find NandInfo !' on some models. COMMON Log to file fixed for Trident models. Introduced New Extremely Fast Key Calculation Algorithm (DHLT) Need few hours for Tables generation at First Software startup. But after, Key calculation for Qualcomm, Broadcom and Trident platforms will take few seconds. DHLT (c)SarasSoft. Users who not want to wait few hours for DHLT table generation can download the files from our Official Rapidshare mirror. The files should be placed into x:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 149 Users Say Thank You to Odia The Ultimate For This Useful Post: |
07-06-2010, 23:28 | #37 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 06/07/2010 Release Date: 06/07/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. LG GSM V 2.0.10.4 ------------------ 1. Infineon GB107,GB108,GB115,GS100,GS101,GS102,GS105, GS106,GS107,GS108,KG289,KP109 added. UFS_SAMs v2.0.10.4 -------------------- TRIDENT VISION B3210M added. Bug in E2P Filename Display fixed. OM(SYSOL) On the Fly E2P Patch added to keep Original IMEI number. SWIFT C3212i added(UNL,IM,FL) On the Fly E2P Patch added to keep Original IMEI number. SWIFT-AEROFONE E1080i,E1086,E1086L,E1170,T139 added (CUNL,PUNL,PIM,FL) On the Fly E2P Patch added to keep Original IMEI number. On the Fly MCU Patch added to bypass MSL security for MSL3 (MSLC16) products (E1080,E1080i,E1086,E1150,E1160, ...) after is possible Direct Unlock, Rebuild IMEI in normal way. QUALCOMM S3370,S5350M added (FL,CUNL,UNFR) S5350 added (CUNL,UNFR) Increased Speed in Communications (NVM Read/Write, RAM Read) BROADCOM B5310U added (FL) i6230,S3653M added (CUNL,FL,BRP) Combo Cable (USB+RJ45) Support added, not need Manipulations with Cable when use [QCDI Info] Corrected CSC,APP,PFS flashing for BCM2153 platform (B5310,..) [Boot Change] Product will Restart after success Boot Change, if Failed, will stay in Download Mode to Allow Retry. [Full Download] will Write All without Restart after Boot Change. COMMON [Refresh] will Show Avalaible Ports List with Full Names. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 113 Users Say Thank You to Odia The Ultimate For This Useful Post: |
08-09-2010, 23:03 | #38 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 09/08/2010 Release Date: 09/08/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. UFS_SAMs v2.0.10.5 -------------------- TRIDENT VISION M2513 added (UNL,CUNL,IM,FL) SWIFT Added MCU_Id and Type Display. Increased Preloader boot speed. QUALCOMM More Versions Support of Hidden Sysinfo models CUNL (S3370,..) A877,M7600H,M8800H,S5603T,S7120H,S8300T added. QUALCOMM+LSI M8910,M8910B,M8910H,M8910U,S8000,S8000B,S8000C,S80 00H,S8000U, S8003,S8500,S8500C added (FL) BROADCOM C3510T,M3710,S5560H added (FL) S3650H,S5230C added (FL,CUNL,UNFR,BRP) INFINEON Infineon Platform Introduced, See on [Sky/INF] Tab. E1151 added (CUNL,FL) DHLT Engine will ask about additional DHLT tables generation. COMMON [Refresh] will Auto Select Ports, be sure that Right Model and Mode is Selected (Untick [QualComm mode] when Flashing !) Users who not want to wait few hours for 3rd DHLT table generation can download the files from our Official Rapidshare mirror. The files should be placed into x:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 108 Users Say Thank You to Odia The Ultimate For This Useful Post: |
10-15-2010, 12:49 | #39 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 15/10/2010 Release Date: 15/10/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. LG_GSM v 2.1.0.6 (HWK Required) -------------------------------- 1. Added NSCK,SPCK,CCK,SIM codes Display for GS10x UFS_SAMs v2.0.10.6 -------------------- TRIDENT X427 added (DUNL,IM,FL) TRIDENT VISION M2520 added (UNL,CUNL,IM,FL) Display of USER LOCK Key for All Models. SWIFT E2550,E2550D,E2558 added (UNL,SECT,IM) Notes: 1.Chinese Versions E2550Zxxx select as E2558 for UNL,SECT,IM. 2.E255x PRAM Flashing not Supported yet, use Original Flasher. B3410C,E2510C,S5050C added (UNL,IM,FL) Note: Chinese Versions B3410Zxxx select as B3410C. SWIFT-AEROFONE C3300D,C3300K,C3303,C3303K added (UNL,SECT,IM,FL) use 530Kom Cable. E1107-DX,E1107L,E1117-MEA-IND,E1130,E1130B,E1150-MEA-SEA,E1153, E1160-DX,E1220,E2120i,E2120L,E2121,E1252,E2121B,E2210T,E 2152, E2370 added (CUNL,PUNL,PIM,FL) Note: Mixing of DX MEA SEA Models causes Blinking or Dead Sets. [Restart] Button now Exit TAT mode with Battery. Auto Exit from TAT Mode when Flashing, not need Cable or Battery Reconnect after UI functions (Info,IM,..) SWIFT-3G J808,S5550,S5550U added (CUNL,SECT,FL) B7722,B7732 DUOS added (CUNL,SECT,FL) Flashing only Master Part. C3630C,C3730C,S3930C TD-SCDMA added (FL) use 530Kom Cable. QUALCOMM A657,A887,A897,M7600L,S5530,T559 added. BROADCOM A697,B3410W added (FL,CUNL,UNFR,BRP) S5250,S5253,S530,S5333 added (FL) Boot Repair Enabled for All Broadcom models, use 530Kom Cable. Some Models have encrypted Boot2.img and don't have uart_boot, for these models use our released Boot_Repair packs. Note: S562x with OneNand Flash Chip, Cannot be Repaired. Added Unlock support(CUNL) for Hidden Sysinfo models (S5560,..) if have no succes in SysInfo search, need ReFlash, to have untrashed FS COMMON Reduced/Full Log of TFS file list progress for OM/Swift. Improved FileOpen dialog, to Override suggested path to last used on same model. Used Abbrevations List can be seen at the Bottom of this page. DOCUMENTS Samsung B7722 How to Rev.1 Samsung C3300_C3303 How to Rev.1 Samsung S523x Warning Rev.1 Samsung S7070 How to Rev.1 Samsung Swift-Aerofone MSL3 Models How to Rev.1 Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 56 Users Say Thank You to Odia The Ultimate For This Useful Post: |
10-26-2010, 10:42 | #40 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 26/10/2010 Release Date: 26/10/2010 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. UFS_SAMs v2.0.10.7 -------------------- SWIFT-AEROFONE E2152 FULL, _RD, E2P Write Bug Fixed. Note: E2152 DX Firmwares cannot be Properly Flashed. QUALCOMM B2710,S3370E added. QUALCOMM+LSI S8000L added (FL) BROADCOM S5620B,S5628i added (FL) COMMON Used Abbrevations List can be seen at the Bottom of this page. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 109 Users Say Thank You to Odia The Ultimate For This Useful Post: |
05-22-2011, 19:59 | #41 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 22/05/2011 Release Date: 22/05/2011 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite. You MUST update your HWK using client 2.2.0.0, old client versions will no longer work. You MUST be running HWK software 2.2.0.0 to access support. DCTxBB5 V 2.2.0.0 ------------------ 1. BB5 products: RM-576,RM-577 (6700s,6700s-1c) added. 2. Local RPL Service Fixed for ASIC 2,5,6,7,11 (UEM_PASW is Correct now) Note: Need Confirm [Readout and Use UEM IMEI] when do [Rd UEM]. 3. [Check Ask/Rpl] Renamed to [Calc Ask/Rpl] as can Calculate RPL now. 4. [Calc Ask/Rpl] Function will Generate Real RPL from ASK file (ASIC 2,5,6,7,11) Note: When Reading UEM, do not Forget Set Right [UEM Changed] Status ! 5. RSA Lock/Unlock for All DCT4+ products (not need Patch) 6. Life Timer added to [PM Edit] 7. DCT4 INFINEON Based Products USB Flashing / UI support added: RH-111,RH-125,RH-126,RM-607,RM-608,RM-643,RM-644,RM-647,RM-653, RM-669,RM-689,RM-704,RM-732,RM-733 (1202,1616-2,1616-2b,C1-01,C1-01.1, C1-02,C1-02.1,1280,1800,1800b,C1-00,C2-00,X1-00,X1-00.1) 8. BB5 RAP3Gv40 Based Products USB Flashing / UI support added: RM-509,RM-510,RM-511,RM-540,RM-598,RM-604,RM-615,RM-638,RM-721,RM-722 (3710a-1,3710a-1c,3711a-1,X3-00,7230-1c,7230-1,5330-1d,6303ci,C2-01,C2-01.5) 9. BB5 RAPU Based Products USB Flashing / UI support added: RM-582,RM-596,RM-601,RM-609,RM-610,RM-627,RM-629,RM-632,RM-634, RM-639,RM-640,RM-645,RM-648,RM-658,RM-659,RM-662,RM-675,RM-682, RM-688,RM-691,RM-697,RM-699,RM-707,RM-718,RM-719,RM-720,RM-749 (Vertu CQ,N8-00,C6-01,E6-00,E6-00.1,X5-01,5230-1d,E5-00,E5-00.2,X3-02,C3-01, C5-00.X5-01.2,E73,X7-00.1,C3-01m,C7-00,6702s,C5-00.1,C7-00b,C5-03,E5-00m, X7-00,C6-01.3,C5-03.2,C5-04.1,C7-00s) 10.BB5 RAPIDO Based Products USB Flashing / UI support added: RM-484,RM-485,RM-486,RM-551,RM-552,RM-559,RM-588,RM-593,RM-594, RM-612,RM-624,RM-625,RM-684 (N86-1,N86-3,N86-5,X6-00.1,X6-00m,X6-00,5230-1,5230-1c,5230-1b,C6-00, C6-00.1,5288,5250) 11.BB5 JUNO (BCM21351) Based Products USB Flashing / UI support added: RM-497,RM-586,RM-614,RM-618,RM-709,RM717 (7020a-2,2710c-2,C3-00,X2-00,X2-01,X2-01.1) 12.Original SX4 Card Support Added (Use Any PCSC Compatible Card Reader) LG_GSM v 2.2.0.0 ----------------- 1. Infineon: A110,A130,A133,A133GO,A170,A180,C100,C105,C300,C30 0GO,C305, C310,GB220,GB220nGO,GB230,GB280,GD350,GD510,GD510N ,GM360, GM360i,GM600,GS170,GS290,GS290GO,GS290N,GS390GO,GS 500,GS500g, GS500gx,GS500v,GT350,GT350GO,GT350i,GT360,GT365,GU 220,GU230, KC550,KC550d,KF510,KF510d,KF600,KF600d,KM380,KM380 c,KM380d, KM385d,KM386c,KP500,KP500N,KP501,KP502,KP502GO,KP5 05,KP550, KP570q,KS360,KS365,T300,T310,T310i,T310N,T315,T315 i,T320, T320e,T320g,T325 added. Notes: 1. To See Unlock Codes and Instructions, Press [BOOT] 2. To Flash Dead Phones, Tick [Emerg. Boot] 3. FLS and BIN files supported for Flashing. 2. USB Support for Infineon SGOLD3, SGOLDRADIO, XGOLD213. Note: To use USB Select USB in [Baud] ComboBox. 3. ADI: G210,G220,G232,G233,G259,G262,G263,G610,G622,G632, G635, G639,G660,G672,G677,C682,G688,G810,G822,G828,G912, GM200,GM205, GM205GO,GM210,KF245,KG296,LG8930,MG235,MG295,MG296 added. 4. TI: C1300i,C2000,G850,L1400i,MG191a,MG191b,MG200c,MG20 0d added. 5. MTK: A120,A155,A160,A165,GB160a,GB160b,GB161,GB190a,GB2 70, GS190,GS200,GS205 added. 6. BT Address Write Added for ADI, Infineon and MTK platforms. SAMs V 2.2.0.0 --------------- TRIDENT A127,i626,T719,X475 added (DUNL,IM,FL) OM(SYSOL) T209,T319 added (DUNL,IM,FL,SECT) SWIFT A436,A437,A516,A517,T229,T249,T339,T349-LTA-USA,T369, T409,T619,T739 added (DUNL,IM,SECT,FL) Added Multi Drive support for TFS Read. Fixed SLAVE Boot Bug on some models (D980,D980F,D988) TFS Extractor and TFS Builder added, Allows to Edit TFS files. SWIFT-AEROFONE Added [Patch MSL] Function to Patch without MCU Part Flashing. C3300i,T109,T119 added (DUNL,IM,FL) E1050,E1055G,E1055T,E1080F-IND-MEA-SEA,E1080W, E1081T-EU-IND-MEA-SEA,E1083C,E1085F,E1085F-MEA,E1087T,E1105F, E1150i,E1160i,E1170i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F, E1225T,E1225T-IND,E2121L added (PUNL,PIM,FL) Notes: 1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets. 2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA. 3.For Cross Flashing Select Model Name Extension by File type. 4.Before Unlock, Info to see Codes or Rebuild IMEI use [Patch MSL] Button or Flash with [Patch MSL] Option Enabled. C3222,C3222W added (DUNL,CUNL) Note: C3222 Flashing not Supported yet, use Original Flasher. TFS Extractor and TFS Builder added, Allows to Edit TFS files. SWIFT-3G C5010E,E3210 added (CUNL,SECT,FL) QUALCOMM A597,A847,A927,B2710D,C5180,S5520,S5580,S6700T,S68 88,T359,T479, T746,T749 added. More Versions Support of Hidden Sysinfo models CUNL and UNFR: A597,A706,A707,A717,A727,A847,A887,A897,A927,B2710 ,B2710D,S3370, S5530,T359,T469,T479,T559,T659,T746,T749 QUALCOMM+LSI S8500B,S8530 added (FL) BROADCOM S5230N added (FL,CUNL,UNFR,BRP) S3850,S5260,S5263,S5330L,S5560i,S5750E,S5753E,S723 0B,S7230E, S7230W,S7233E added (FL) S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP) [QCDI Info] Renamed to [BCMBL Info] for BroadCom Models. INFINEON B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2230,E223 0M,E2232, E2330,E2330B,E2330C,E2530,E2652,E2652W,S3310i,S335 0,S3353, S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL,UFL) Note: for USB Flashing select 'USB0' in [BaudRate] box. E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000) Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 |
The Following 127 Users Say Thank You to Odia The Ultimate For This Useful Post: |
07-04-2011, 23:44 | #42 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 04/07/2011 Release Date: 04/07/2011 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. Since this is a minor update release, there is no need to update your HWK if you have already updated on the v2.2.0.0 release. DCTxBB5 V 2.2.0.1 ------------------ 1. DCT4+ ASIC2 Unlock Bug Fixed (RH-92,RH-93,RH-94,RH-95,RM-189,RM-190,RM-225) 2. Wrong Locks Status Indicator Fixed (RH-86,RH-87) 3. Detail Description Message on Bad VPL File Exception. 4. BB5 RAPU Based Products USB Flashing / UI support added: RM-744,RM-745,RM-775 (C5-00.3,C5-00.2,X3-02.5) LG_GSM v 2.2.0.1 ----------------- 1. Infineon: A100,A100a,A175,A175a,A175b,A180a,A180b,GB102GO,GB 105a, GB107a,GB125a,GB126a,GS101a,GS101GO,GS107a,GS107b, GS117, GS155,GS155a,GS155b,GS500f,GU200,GU200a,GU200b,KF5 10c, KF600c,KF600d,KM570,KM570f,KP105a,KP106a,KP106b,KP 107a, KP107b,T325g,TE350GO added. 2. ADI: KP115a,KP130b,KP215a,KP260c,KP265d added. UFS_SAMs V 2.2.0.1 -------------------- SWIFT Some DUOS models Slave Boot bug Fixed. SWIFT-AEROFONE E1050,E1055T,E1080W,E1170i E2P Size Fixed. Max Section Size Increased. E1182 added (DUNL,PUNL,PIM,FL) C3303i,C3322,C3500 added (CUNL,DUNL,IM,SECT,E2P) Note: C3322,C3500 TFS and CSC Flashing not Supported yet, use Original Flasher. SWIFT-3G C5010B added (CUNL,SECT,FL) QUALCOMM A885,A886,F406,S3370B,S3370L added. INFINEON E2652,E2652W USB Flahing bug Fixed. E2152i added (CUNL,PUNL,PIM,FL,UFL) XGOLD213 BIF file Write bug fixed. XGOLD213 Patch bug fixed. BROADCOM B5310R,C6712,S3853,S5250W added (UFL) COMMON Used Abbrevations List can be seen at the Bottom of this page. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Rapidshare Mirrors:- http://rapidshare.com/users/VAY6Q3 Last edited by Odia The Ultimate; 07-06-2011 at 11:52. |
The Following 38 Users Say Thank You to Odia The Ultimate For This Useful Post: |
08-22-2011, 11:36 | #43 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 22/08/2011 Release Date: 22/08/2011 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. Since this is a minor update release, there is no need to update your HWK if you have already updated on the v2.2.0.0 release. DCTxBB5 v2.2.0.2 ----------------- 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-776 (C3-01.5) 2. DCT4 INFINEON Based Products USB Flashing / UI support added: RM-692,RM-693,RM-702,RM-713 (C2-02,C2-02.1,C2-03,X1-01) LG_GSM v2.2.0.2 ----------------- 1. Infineon: A108,A190,A190a,A190b,A210,A210b,GB125R,GC900fGO,G T350f, KS360GO added. 2. EGV V3-32 and EGV V3-64 Direct Unlock and IMEI enable added. Note: Use [Unlock] before IMEI rebuild. 3. EGV V3-64 new Flash Chips Support. SAMs v2.2.0.2 -------------- TRIDENT VISION <CODE CORRUPTED> for non 8 Digits PCK Fixed. SWIFT-AEROFONE E1050-CHN,E1050V,E1086i,E1150-CHN,E1155L,E1180,E1190,E1220i added (PUNL,PIM,FL) E1182L added (DUNL,PUNL,PIM,FL) E1225T,E1182 TFS Flashing bug Fixed. C3322 Unlock, IMEI, Sections bug Fixed. B7722,B7732 Slave Part Flashing/Read/E2P added. QUALCOMM T669 Added. INFINEON C3011,C3560,C3750,C3752 added (CUNL,PUNL,PIM,FL,UFL) E2232 Flashing bug Fixed. <CODE CORRUPTED> for non 8 Digits PCK Fixed. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Mirrors:- http://forum.gsmhosting.com/vbb/f311...rrors-1216246/ |
The Following 31 Users Say Thank You to Odia The Ultimate For This Useful Post: |
11-06-2011, 11:14 | #44 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | HWK Release 06/11/2011 Release Date: 06/11/2011 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. Since this is a minor update release, there is no need to update your HWK if you have already updated on the v2.2.0.0 release. DCTxBB5 v2.2.0.3 ----------------- 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-670,RM-679,RM-681V,RM-701,RM-730,RM-750,RM-763,RM-774,RM-779, RM-781,RM-814,RM-815,RM-816 (700,T7-00,Vertu Con.T,600,702T,500,303,701,603,300,C5-08,C5-05,C5-06) 2. DCT4 INFINEON Based Products Flashing / UI support added: RH-130,RH-131,RM-724,RM-725,RM-769 (100,100.1,C2-05,C2-05.1,101) 3. Vertu products names changed to RM-582V, RM-681V to keep compatibility with DataPackageManager application. 4. New Flashloaders included. 5. Fixed BSOD bug on W7 x64 when Connect Box. LG_GSM v2.2.0.3 ----------------- 1. Infineon: A190,A190a,A190b Read Lock Keys, Unlock, Dual IMEI Fixed. 2. Infineon EgoldVoice64_ULC2: KG370,KG375,KG376,MG370a,MG370b added (FL,CUL,DUL,IM) 3. Infineon XMM2130: LG500G,LG800G added (FL) 4. Infineon XMM2150: A200,A225,A230,A250,A255,A258,C330,T500,T505,T510, T515, T530 added (FL,DUL) S365 added (FL,CUL,DUL,IM) Note: Use [Unlock] before IMEI rebuild. 5. Fixed BSOD bug on W7 x64 when Connect Box. SAMs v2.2.0.3 -------------- SWIFT-AEROFONE E1080T-SEA,E1175T-MEA,E1190-CHN,E1195,E1195-CHN,E1230 added (PUNL,PIM,FL) E1055G info/unlock bug fixed. xx-DX models renamed to xx-SEA (note: DD is IND not SEA) E2222 (UNL,SECT,IM) SWIFT-3G (CUNL,SECT) fixed for C3630C,C3730C,S3930C E3213K,i6320C,i6330C,S3710,S3770,S3778,S3830U,S561 0, S5610K,S5630C added (CUNL,SECT,FL) INFINEON IMEI2 Rebuild added for DUOS models. Minor bugs in AT protocol fixed: (not read Codes and IMEI Rebuild fails on some models) Notes: Some S3550 units stucks on DFFS (CSC) Flashing, Solution: Untick [Use EBL from FLS Pack] CheckBox. COMMON Fixed BSOD bug on W7 x64 when Connect Box. Many thanks to all those who have supported us!!! Odia. www.sarasbox.co.uk www.gsm-solutions.co.uk Official SarasSoft Mirrors:- ★★ HWK Install Files Mirrors ★★ |
The Following 32 Users Say Thank You to Odia The Ultimate For This Useful Post: |
08-04-2013, 01:16 | #45 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | UFSx+HWK Release 22/07/2013 Release Date: 22/07/2013 The Official release is ready in our download area http://sarunasoftware.com. WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite. DCTxBB5 v2.3.0.0 ----------------- 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-754 (801T) 2. DCT4 INFINEON Based Products USB Flashing / UI support added: RM-694,RM-761,RM-799,RM-800 (X2-02,200,201,201.1) LG_GSM v2.3.0.0 ----------------- 1. Infineon Egold Boot Fixed (was broken in v 2.2.0.3) 2. Infineon E500,KM553,KM555,KM555e,KM555g,KM555R added (FL,CUL) 3. Infineon GT370,GU230GO,S367 added (FL,CUL,DUL,IM) 4. Infineon T370,T375,T385,T385b,T395,T500GO,T505GO,T565, T565b,T575 added (FL,DUL) 5. MTK: A290 added (FL,3xIM) 6. MTK: USB Support for UI Functions (Select COM on Phone) 7. WiFi MAC Address Write Added for Infineon and MTK platforms. SAMs v2.3.0.0 -------------- SWIFT T456-FIDO,T456-ROGERS added (UNL,SECT,IM,FL) SWIFT-AEROFONE [Patch MSL] fixed for DUOS Products. E1086W,E1153i,E1182-CHN,E1195L,E1200,E1200M,E1200M-CHN, E1200T,E1202,E1205,E1205L,E1205M-CHN,E1205T,E1207,E1207T-IND, E1207-MEA,E1220T,E1230T,E1232B,E1232D added (PUNL,PIM,FL) C3520,C3780,C3782,E2250,E2252 added (UNL,SECT,IM,FL) E2220,E2222L (UNL,SECT,IM) SWIFT-3G C3630,C5190,C5530,E3217B,E3217L,S5270K,S5270L,S568 0 added (UNL,SECT,FL) C5010,E3210,E3213,S5610 Direct Unlock Fixed. IMEI Repair Added for Almost All Models: C3630,E2310,E2313,S3710,S5270,S5610,.. INFINEON C3310,C3310R,C3312,C3312R,C3313K,C3330,C3332,C3350 ,C3350M, E2230L,E2350B,E2600,E2600M,S3800,S3802,S3802W,S522 0,S5220R, S5222,S5222R,S5229,S5292,S5296 added (CUNL,PUNL,PIM,FL,UFL) E1151 Missing boot fixed. E1151 IMEI Rebuild and Direct Unlock added (AT Mode) Note: Need make Boot Mode Info before use of AT Mode. QUALCOMM M210S,T356 Added. BROADCOM S5380B,S5380D,S5380F,S5380G,S5780D,S7250,S7250D added (UFL) Many thanks to all those who have supported us!!! Odia. Official SarasSoft Mirrors:- ★★ HWK Install Files Mirrors ★★ Last edited by Odia The Ultimate; 08-06-2013 at 09:37. |
The Following 26 Users Say Thank You to Odia The Ultimate For This Useful Post: |
